Random sequence - full alphabet run length
The discussion revolves around calculating the average run length of reading a random sequence of digits from 0 to 9 until all digits have been seen at least once. This problem is related to the "coupon collector's problem," which provides a framework for understanding the expected number of trials needed to collect all unique items from a finite set. The average run length can be derived using a geometric series, leading to a calculated value of approximately 29.29 for the complete sequence. The conversation highlights the complexity of the calculation and suggests that Monte Carlo simulations may have been used to estimate an average run length of around 27. The thread emphasizes the mathematical intricacies involved in determining these expected values.
Monte_Carlo
Hi,
Suppose we're looking at a random sequence of digits from 0 to 9. We start off reading the digits until every digit from 0 to 9 has been seen at least once and we mark the count of digits read up to that point (run length). We then reset the run length and continue until the whole random sequence has been read. In the end, for every finite random sequence, there is a corresponding sequence of run lengths.
How would we be able to analytically arrive at average length of such these runs? What is the formal mathematical name given to such a run? What branch of mathematics concerns itself with this?
Monte
Mathematics news on Phys.org
Let me know if I am in the wrong place
Just want to make sure this forum is appropriate for the question above - I've seen some people have looked at the problem but so far I garnered zero responses. This is not a homework problem.
Again, basically, given finite alphabet and a finite sequence composed using that alphabet, we start reading the sequence until every symbol in the alphabet has been at read least once. We then record how many symbols it took us to reach that point. We repeat, until we've read the whole sequence, thus finishing with sequence of run lengths. The question is, what is average (expected) length of these runs (looks like around 27 for random sequence of digits from 0 to 9).
I suspect that you haven't gotten any response because it appears to be a very difficult calculation. Did you use some sort of Monte Carlo simulation to get 27?
I believe that your question is equivalent to what's known as the "coupon collector's problem." You should be able to find an answer using that information.
Once you've seen n digits, the next digit has a probability of n/10 of already been seen, so there is a probability of n/10 that a second digit is needed, n^2/100 that a third digit is needed etc. the sum of this is 1 + n/10 + n^2/100 + ... = 1/(1 - n/10). (sum of geometric series). This is the average number of digits you need to read until you get a new digit.
To get the average run length until all the digits are seen you need to sum 1/(1 - n/10) for n ranging from 0 up to 9, so you get 1 + 10/9 + 10/8 + 10/7 + ... . + 10/2 + 10/1 which is 29.2896...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
