Calculation of Lorentz Force in Generator and its mass equivalence
The discussion focuses on calculating the Lorentz force exerted on a coil in a generator setup, using the formula F = BIL. A single coil with 300 turns and a wire length of 92 meters experiences an opposing force of 230 N when a current of 5 amps is applied, with a magnetic field strength of 0.5 T. Participants seek clarification on unit correctness and how to relate this force to a weight equivalent, specifically in terms of gravitational force. The conversion between Newtons and kilograms is mentioned, referencing the gravitational constant. Understanding these calculations is essential for relating electromagnetic forces to physical weight.
Alkemist
Greetings All -
Per F=BIL I can calculate quantity of Force on coil (or magnet), when I draw certain amount of current from the generator.
So I need help in calculating the Force and then weight equivalent of it. Let's say I have Single coil [with 300 turns] generator [wire length = 92 meter], when I move that coil over Magnets in short circuit condition, I sense the opposite force [F] as current [I = 5 amp] passes through the coil. I calculate the amount of opposite force, being exerted on coil for that current as: B = (0.5 T)
F = 0.5 * 5 * 92 = 230 N/Amp.m [Am I correct in Units?], this means I feel the force of 230 N/Amp.m continuously.
Now I want to know how can I relate this force to weight equivalent? I mean when I hold 1 kg weight in my hand I feel F = 9.8 kg.m/s.s
Any help?
If you are talking about 1 g Earth gravity, then the gravitational constant 6.67 × 10 −11 Newton-metre 2-kilogram −2 is the conversion between Newtons and kg.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
