Advice request - design a toy steam engine and do a pull event
The discussion centers on designing a modified Mamod toy steam engine for a pull event, where the engine must pull the maximum load over a 60-inch course within five minutes. Key considerations include the choice of wheels versus tracks for traction, the efficiency of using a commercial gearbox compared to Meccano gears, and the potential benefits of a heavier flywheel. The use of miniature bearings and lubrication for the drivetrain is suggested, while variable gearing may not provide a significant advantage. Additionally, the idea of incorporating a capstan or winch is proposed to enhance pulling capabilities.
Novice One
Advice request -- design a toy steam engine and do a pull event
Hello,
Please do forgive me if this is inappropriate use of this sight, I'm looking for general advice, any suggestions as to where I could get information and thoughts on the subject are welcome.
I've taken a challenge to build and enter a competition to modify a 'Mamod toy steam engine' and enter a pull event. The engine on one fuel fill will have to pull as much load as possible over a 5' or 60 Inch flat course, with a 5 min time limit. The cylinder assembly, burner and safety vale have to remain standard. I understand that around 2000 RPM is available.
The design apart from the above proviso's can be as outlandish / revolutionary as required. My perception of this is that this is a task around gearing. However I'm thinking in relation to other points and need answers advice and suggestions.
1 - Would this task be better performed with small wheels, larger wheels or tracks
2 - Should I use a small commercial gear box or use Meccano gears
3 - Updating the Flywheel to solid, much heavier, will that give me an advantage / benefit
4 - Should I consider using miniature bearings and lubrication on the drive train
5 - Would there be an advantage to having variable gearing / how could this be achieved?
At this time a competitor has a pull weight of around 30 Kg - on a trolley pulled by the engine, which I consider very interesting.
Again sorry if this is inappropriate
Thanks & Regards
Mark
Welcome to PF.
1. What is the surface it needs to grip?
2. Commercial box will be more efficient.
3. Flywheel is needed if single cylinder.
4. Commercial gearbox needs bearings but final axles can be simple shafts in bushes.
5. No advantage in mechanical variable gearing. Maybe torque converter?
If the rules allow, you might consider a capstan or winch to pull the engine along the course.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
9K
10K
