180 degree Compton Scattering: low versus high energy initial photon
In summary: Basically what you do is take the input energy and multiply it by the deflection angle to get the scattered energy. Then you take the scattered energy and multiply it by the deflection angle to get the recoil energy. In summary, at high energies the scattered energy is proportional to the input energy, while at low energies the scattered energy is proportional to the deflection angle.
ltarhab
So when you calculate the scattered electron energy and the scattered photon energy (for 180 degree deflection) you get roughly the following (in keV).
Photon(in)__Photon(scattered)__Electron(recoil)
27.5_______24.8______________2.7
81_________62_______________19
140________91_______________49
364________150______________214
511________170______________341
1330_______214______________1116
infinity_____255.5_____________~infinity
So as the Photon(in) energy increases, the scattered photon energy approaches 255.5 keV (aka half of an electron's rest energy). And as the Photon(in) energy decreases, the scattered photon energy approaches the input energy. Why is this so?
For the high energy case, the best explanation I could come up with is that this is due to the conservation of the relativistic energy and/or the invariant mass of the system. In sort of the same way that two 255.5 keV traveling in opposite directions would be equal to an electron at rest. But this doesn't necessarily explain what is going on at the lower energies.
I've run through the equations too many times now and am still having a little trouble conceptualizing exactly what is going on in the low energy case. Any input would be appreciated.
Science news on Phys.org
If you use wavelength as your definition for photon energy with wavelength scaled so that λ = 1 corresponds to the rest mass of an electron, then backscattering will give λ'=λ+2.
Right, you're basically just stating what Compton did in his original paper; the difference in wavelengths is equal to the Compton wavelength of the electron times 1-Cos(theta). So I guess if you want to deal with it in terms of wavelength, what is the significance of 2 times the Compton wavelength? Again, intuitively speaking with respect to photon-electron interaction.
It seems to me the low-energy limit is actually the easier one, because in that limit, the rest mass of the target electron might as well be virtually infinite. In other words, there is an ignorable parameter in this problem, which is the actual rest mass of the target-- all that matters is the ratio of the rest mass to the photon energy. So instead of lowering the photon energy and keeping the rest mass constant, you could imagine getting the same answer by keeping the photon energy constant, but raising the rest mass. In the limit of large rest mass, the target acts like a brick wall, that simply bounces back the photon at the same energy it came in at.
Since you are familiar with Compton's derivation, I suggest you look there. It arises from the conservation laws (energy and momentum).
As stated in the OP, I've already ran the math. About 5 pages back to back running the different conservation of energy/momentum/mass equations, and found all kinds of mathematical relations. The answer I was looking for was what Ken G gave (thanks BTW).
What is 180 degree Compton Scattering?
180 degree Compton Scattering is a phenomenon in which a high energy photon collides with an electron at a 180 degree angle, resulting in the photon losing energy and changing its direction of propagation.
How does low energy initial photon affect 180 degree Compton Scattering?
When the initial photon has low energy, the resulting scattered photon will have a longer wavelength and lower energy compared to the initial photon. This is because the electron is able to absorb more energy from the low energy photon during the collision.
How does high energy initial photon affect 180 degree Compton Scattering?
With a high energy initial photon, the resulting scattered photon will have a shorter wavelength and higher energy compared to the initial photon. This is because the electron is not able to absorb as much energy from the high energy photon during the collision.
What is the significance of 180 degree Compton Scattering in science?
180 degree Compton Scattering is important in understanding the behavior of photons and electrons, as well as in studying the properties of matter and energy. It has applications in various fields such as astrophysics, nuclear physics, and medical imaging.
How is 180 degree Compton Scattering different from other types of Compton Scattering?
180 degree Compton Scattering is unique because it occurs when the initial photon and the scattered photon are moving in opposite directions at a 180 degree angle. In other types of Compton Scattering, the photons are scattered at different angles.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
