NIH Factor in American Companies: Why Does It Exist?
In summary, the National Institutes of Health (NIH) Factor in American companies refers to the influence and impact that the NIH has on the development and success of businesses in the United States. This existence of this factor can be attributed to the significant funding and resources provided by the NIH to support research and innovation in various industries. The NIH's contributions have led to advancements in technology, medicine, and other fields, making it a crucial factor in the growth and competitiveness of American companies.
sid_galt
502
Has an otto cycle engine been developed which gives a non pulsed output?
What do you mean? A continuous-burn engine? That would appear to violate the definition of "Otto Cycle". That sounds more like a "Brayton Cycle" which is continuous burn. You can have a Piston Brayton Cycle engine. One of the "Mechanics " type magazines carried such an invention several years ago. If I can find it I'll let you know.
If I'm not mistaken, some defining characteristics of an Otto Cycle are:
1) Spark ignition.
2) Intake, Compression, Ignition, Power generation and Exhaust all occur from the same area.
3) Compression and Expansion volumes are the same - - - otherwise it would be Atkinson Cycle.
4) Burn is intermittent (Pulsed?).
FredGarvin, is this correct?
KM
I mean the ideal Otto cycle (which does not take into account the intake and exhaust strokes) which is essentially adiabatic compression, constant volume burning, adiabatic expansion and finally heat rejection at constant volume. Aside from the Wankel engine, is there any which uses this constant volume cycle and does not provide a pulsed output?
surely even the wankel engine is a pulsed output?
The only way that I can see it happening, if I'm understanding the question correctly, would be to have an essentially infinite number of combustion chambers (cylinders or lobes) firing sequentially so the explosions act like a wave. I don't think that it would fit in a Volkswagon.
I reckon that by definition, an Otto cycle must be used in some sort of reciprocating manner, in which case the output will always be pulsed to some extent.
The Wankel, as well as the piston Otto Cycle, must have pulsating outputs from each chamber/cylinder. It goes with the sequential nature of the way each stage of the cycle occurs within the same area (chamber/cylinder). These cannot occur at the same time within this area - - - thus the output must be "pulsed". It cannot happen in any other way with this configuration.
The same also is essentially true for the Diesel and Atkinson cycles.
KM
PS. Even the continuous burn Brayton cycle has some pulsation at the 'output' simply because of the presence of the 'buckets' or 'teeth', or whatever it uses to derive power. It's just a lot smoother than the others. Its burn is by definition, continuous and thus smooth (not counting internal turbulences, etc.).
You're right. My bad.
An electric car would have a constant energy output though wouldn't it?
Have had quite a few lessons on automotive engineering but have never touched into electric cars.
It seems any of us know what you mean by "pulsed". The pulsation in an Otto cycle engine- I will assume you are referring to something practical like an spark ignition engine- is produced by a pressure wave as exhaust valve opens. How the hell are you going to be able of not having any valve?. This would mean you have a continuous combustion process while burning a continuous flow of fuel as in a jet engine. If so it won't be an Otto cycle, but a Brayton one because it will be impossible the flow to be an adiabatic stream. This question makes no sense at all, but it is welcome because I made also one similar some time ago... :biggrin: .
Having read this post, I think that I might have misunderstood the original question. I thought that it referred to equalizing the combustion so as to eliminate the need for a flywheel, harmonic balancer, etc. in order to obtain a smooth mechanical output.
Having read your post, I think that I might have misunderstood the original question too :biggrin:. I don't know what Sidgalt meant. I am not saying previous responses are wrong at all. Moreover, through our mistakens I have given Sidgalt enough information yet. :wink:
Thank you all for the replies
I was referring to an otto cycle engine which had continuous combustion like the jet engine.
BTW, are the 2 stroke, 4 stroke and Wankel engines the only implementation of the Otto Cycle
edit: One more question, during the downward stroke of the piston in a piston engine, does the car feel an upward force?
As several of us have said, no. Any ICEs that have continuous combustion like a jet engine, also like a jet engine are Brayton cycle engines. To date that is the definition of Brayton Cycle (Who knows, in the future there may be a new ICE cycle discovered that is also continuous burn ), and it is the main differentiator from the timed-combustion engines, like the Otto and Diesel cycles.
Basically yes, but it's a bit more complex than that. For example, the Wankel Otto cycle can also be 2 stroke or 4 stroke. Or, You could make a piston or Wankel Brayton Cycle engine. (It's not the "shape" of the engine's parts that make the difference, but how you use them. This determines their thermodynamic characteristics.) For that matter, even the Brayton Cycle (At least piston versions) could have 2-cycle or 4-cycle equivalents. It appears to me however that 2-cycle equivalent might be less efficient, but then I could be wrong about that.
No! Whereas the detonation pushes upwardly on the head, it also pushes equally down on the piston and thus the crankshaft. Both of these forces go equally into the block, thus cancelling any net translative forces, though they'll twist and vibrate the engine like mad.
KM
Right... I misunderstood. What you're asking about is impossible within the parameters of an Otto cycle.
No. The only other one that comes to mind immediately, because I love the thing, is the 'K-cycle'. It was developed in Saskatchewan or Manitoba by a fellow in his home shop, and I don't know if it ever went into commercial production. It was based upon sets of counter-acting pistons angled something like 160º from each other and pushing on a swash plate between them. What made it especially peculiar was that the pistons remained essentially where they were and the block rotated around them. It was all housed within a case that looked a lot like 2 small garbage cans fastened together at an angle. It would burn just about any fuel, and the one demonstrated was producing approximately 500hp from 350ci. Tonnes of torque too, if memory serves.
Shouldn't, I suspect, because the downward force is still contained within the physical limitations of the vehicle. With it being an enclosed system, the forces should balance out.
I should point out, that though these are the only commercial implementations of the Otto cycle, they are not by any means the only possibilities of it. For example, there is the (in development) http://www.machaon.ru/tetra/veselo.htm Rotary engine, and several past designs (most of which had pistons of some type).
KM
There have been several similarly intriguing designs. They have all suffered from the same flaw, the NIH factor! Another particular example is the http://www.saintjohn.nbcc.nb.ca/Heritage/bricklin/Rotary.htm engine.
That is exactly the motor that I was reffering to, which was called the 'K-cycle' when I saw it. Since the report was on CBC or CTV national TV here, and the production facilities were here, I misunderstood and thought that the motor itself was developed here. Thanks for the link!
What's the NIH factor
NIH means "Not Invented Here". It refers to the dismissive reception that anything not designed within a company (or even within a particular division or section of a company) virtually always gets within the organization. In the past this attitude always puzzled me, I couldn't see why people would always look for fault in a new concept, even when it could bring big profits.
Now I think that I'm beginning to understand the politics of the matter, and why this destructive trend is so prevalent in America, and far less so in Far East countries (Europe, I don't know, though I suspect British behavior is similar to that in America.)
KM
PS: This has been around and discussed for decades, and probably throughout the twentieth century, so it's not new.
Related to NIH Factor in American Companies: Why Does It Exist?
1. What is a non pulsed otto cycle engine?
A non pulsed otto cycle engine is a type of internal combustion engine that operates on the otto cycle, which is a thermodynamic cycle for spark-ignition engines. Unlike a pulsed otto cycle engine, which has a single power stroke for every two revolutions of the crankshaft, a non pulsed otto cycle engine has a power stroke for every revolution of the crankshaft.
2. How does a non pulsed otto cycle engine work?
In a non pulsed otto cycle engine, the intake stroke draws in a fuel-air mixture into the cylinder. The compression stroke compresses the mixture, and then the spark plug ignites the mixture, causing a rapid expansion of gases and driving the piston down. The exhaust stroke then expels the burned gases out of the cylinder. This process repeats for every revolution of the crankshaft, generating power.
3. What are the advantages of a non pulsed otto cycle engine?
Compared to a pulsed otto cycle engine, a non pulsed otto cycle engine has a smoother operation due to having a power stroke for every revolution of the crankshaft. This results in less vibration and noise. Additionally, a non pulsed otto cycle engine can produce more power and torque due to the increased number of power strokes.
4. What are the limitations of a non pulsed otto cycle engine?
One limitation of a non pulsed otto cycle engine is that it requires a more complex engine design with additional parts such as an extra set of valves and a camshaft. This can increase the weight and cost of the engine. Additionally, a non pulsed otto cycle engine may have lower fuel efficiency compared to a pulsed otto cycle engine.
5. What are some common applications of non pulsed otto cycle engines?
Non pulsed otto cycle engines are commonly used in passenger vehicles, motorcycles, and small aircraft. They can also be found in lawn mowers, chainsaws, and other small engine applications. In general, they are used in any vehicle or equipment that requires a lightweight and compact engine with relatively high power output.
  • Aerospace Engineering
  • Mechanical Engineering
