How does kinetic energy of gases relate to their volume?
In summary, the observation that at 300 K and 10 atm, the molar volume of C2H6(g) is less than that of H2(g) can be explained by the fact that the intermolecular attractions in C2H6(g) are stronger than they are in H2(g). This is supported by the statement that C2H6 molecules are smaller than H2 molecules, indicating a stronger attraction between the C2H6 molecules. While statement B may seem like a reasonable answer, it is not the best answer as it does not take into account the difference in intermolecular attractions between the two substances. Overall, the correct answer is E, which highlights the importance of understanding the concept of interm
Esoremada
52
Which of the following statements accounts for the observation that, at 300 K and 10 atm, the molar volume of C2H6(g) is less than that of H2(g)?
A C2H6 molecules are smaller than H2 molecules.
B The average kinetic energy of H2 molecules is greater than that of C2H6 molecules.
C The average kinetic energy of H2 molecules is less than that of C2H6 molecules.
D The intermolecular attractions in C2H6(g) are weaker than they are in H2(g).
*E The intermolecular attractions in C2H6(g) are stronger than they are in H2(g).
E is the correct answer, but it also seems like B is a reasonable answer, doesn't higher kinetic energy make a substance's volume increase? Isn't that why heating things causes them to expand?
Average KE is proportional to temperature right?
T is the same for each sample, therefore...
Oh, right. Thanks, idk how I missed that.
Lots of people would - that's why the question is asked that way.
The idea is to reward you for reading with brain engaged (almost nobody does that anyway) and for understanding physics.
The "understanding physics" part gives you two possible answers - B and E (which is how you can tell you are doing well BTW) and you have to do a bit more work to figure out what makes one better than the other. I suspect the actual test is whether you realize the relationship between KE and T.
You can do it the other way around, by memorizing stuff, though... but it's harder.
While it is true that higher kinetic energy can lead to an increase in volume, in this scenario, the intermolecular attractions play a larger role in determining the volume of the gas. At 300 K and 10 atm, both H2 and C2H6 have similar kinetic energies. However, the intermolecular attractions in C2H6 are stronger than those in H2, causing the molecules to be more tightly packed and resulting in a smaller molar volume for C2H6. This is consistent with the observation that at higher pressures, gases tend to have smaller volumes due to increased intermolecular interactions.
1. How is kinetic energy of gases related to their volume?
The kinetic energy of gases is directly proportional to their volume. This means that as the volume of a gas increases, its kinetic energy also increases.
2. What is the equation for calculating kinetic energy of gases?
The equation for calculating kinetic energy of gases is KE = 1/2 * m * v^2, where KE is kinetic energy, m is the mass of the gas, and v is the velocity of the gas particles.
3. Does the temperature of a gas affect its kinetic energy?
Yes, the temperature of a gas affects its kinetic energy. As the temperature increases, the kinetic energy of the gas also increases.
4. How does the volume of a gas affect its kinetic energy?
The volume of a gas affects its kinetic energy by determining the amount of space the gas particles have to move. A larger volume means more space for the particles to move, resulting in higher kinetic energy.
5. Is there a relationship between the kinetic energy of gases and the pressure they exert?
Yes, there is a relationship between the kinetic energy of gases and the pressure they exert. As the kinetic energy of a gas increases, the pressure it exerts also increases due to the increased collisions of gas particles with the walls of the container.
9K
