Fourth order Runge–Kutta in C# - two differential equations
In summary, the conversation is about implementing two non-linear differential equations in C# using the fourth-order Runge-Kutha method. The equations involve various constants such as ALFA, MU, BETA, LAMBDA, V, FI, TETA, QL, and H, and the code also includes functions for calculating the derivatives and running the equations. The conversation also mentions the use of ArrayLists to store the results of the equations.
  • #36
So if I get:
h AUC(after 2 hours)
0.01 335.40257585727842
0.005 335.87803342989893
Can I presume that 335 is accurate result? (without knowing the part after comma).
If h=0.01 does O(h5) mean that up to the 0.015 I get accurate digits?
And should I count O(h5) or O(h4)? Local/global error?
  • #37
It means that up to *a constant times* 0.015 you will get accurate digits.
This constant is unknown (and might be bigger than you think or suspect).
Itosu said:
So if I get:
Since the constant is unknown and you have a discontinuity in your function, you'll have to experiment a bit.
Try a step like 0.0025.
I expect that you'll see an AUC that starts with 335.8, and probably even 335.87 or 335.88.
That should give you "confidence" that 335 are indeed accurate digits, but there is no "guarantee" mathematically speaking.
The result to present, based on your calculation, would be 335.9 ± 0.5 or 335.88 ± 0.48.
Note that whenever you measure something and present a result, you are supposed to always include the margin of error in your result.
  • #38
Thank you, I understand.
Could you explain more deeply the idea of the error O(h5) or provide a link?
Thank you in advance!
  • #39
The errors of numerical algorithms are expressed with this big O notation:
http://en.wikipedia.org/wiki/Big_O_notation"
