Magnetic dipole moment energy question
In summary, the formula for calculating the dipole energy of a dipole moment in an external field is U_m=\frac{1}{2}\int\vec{A}\vec{J}dr^3=\frac{1}{2}\vec{\mu}.\vec{B}. However, when calculating the force on a dipole using the equation \int\vec{J}\times\vec{B}dr^3, the resulting energy formula is -\vec{\mu}.\vec{B}. This difference is due to the 1/2 factor in the first equation accounting for double counting in the integral over all current distributions, while in the second equation, the B field is only due to external currents and does
facenian
436
25
Hello, I have this problem. I calculated the dipole energy of a dipole moment in an external field using the equation [itex]U_m=\frac{1}{2}\int\vec{A}\vec{J}dr^3=\frac{1}{2} \vec{\mu}.\vec{B}[/itex] however when the force on a dipole is calculated using [itex]\int\vec{J}\times\vec{B}dr^3[/itex] the formula obteined for the energy is [itex]-\vec{\mu}.\vec{B}[/itex]
I don't understand the difference, are they supposed to be defferent?
The 1/2 in your first equation arises because the integral is over all current distributions. The 1/2 takes care of double counting that takes place in that case.
The B field in the second equation is due to only external currents (not part of mu), so the 1/2 does not arise.
The + sign in the first equation is due to the fact that the current is kept constant by an EMF source that provides energy to keep the current constant. Then, the force is given by +grad U. In the second equation, no energy is supplied, so F= -grad U.
Each case thus gives the same force.
You can look at <http://arxiv.org/pdf/0707.3421.pdf>
Thanks, I will take a look
1. What is a magnetic dipole moment energy?
A magnetic dipole moment energy is a measure of the strength of a magnetic field created by a dipole, which is a pair of equal and opposite magnetic poles separated by a distance. It is a vector quantity that describes the orientation and magnitude of the magnetic field.
2. How is magnetic dipole moment energy calculated?
The magnetic dipole moment energy is calculated by multiplying the strength of the magnetic dipole moment (m) by the strength of the magnetic field (B), and the cosine of the angle between them (θ). This can be represented by the equation E = -mBcosθ.
3. What factors affect the magnetic dipole moment energy?
The magnetic dipole moment energy is affected by the strength of the magnetic field, the distance between the poles of the dipole, and the orientation of the dipole in relation to the magnetic field. Other factors, such as the material and shape of the dipole, can also play a role.
4. How does magnetic dipole moment energy relate to magnetic potential energy?
Magnetic dipole moment energy is a form of potential energy, specifically magnetic potential energy. It represents the potential of a magnetic dipole to do work due to its orientation in a magnetic field. The higher the magnetic dipole moment energy, the greater the potential for work to be done.
5. What are some real-world applications of magnetic dipole moment energy?
Magnetic dipole moment energy has various practical uses, such as in magnetic data storage devices like hard drives, in magnetic resonance imaging (MRI) machines for medical imaging, and in electric motors and generators. It is also used in the study of magnetic materials and their properties.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
16K
