- #106
Dale
Mentor
- 35,631
- 13,986
Then please provide some references which demonstrate that this is the standard convention. Note, that being a standard convention is a much stronger claim than merely that it is one opinion or that it is an alternate terminology. I don't know how you can possibly support this, but then again, you haven't supported any of your claims.Andrew Mason said:I would suggest that the reason mainstream texts do not use the term "centrifugal reaction force" to describe the reaction force to a centripetal force is because it obscures the physics. If the direction of the force is determined by the direction of the acceleration of the centre of mass of the body to which the force is applied, which I would suggest is the standard convention, all forces are all centripetal.
Yes, it does. Between the sudden cutting of the bolts and the propagation of the shear wave to the feet of the astronaut there is still a centrifugal reaction force and this centrifugal reaction force accelerates the plate away from the center. I already explained this in detail, since you did not respond further I thought that you had understood it.Andrew Mason said:These are both good examples of why these do NOT cause centrifugal acceleration. We have discussed the bolt cutting example and all the bolt cutting does is STOP centripetal acceleration. It does not cause any acceleration away from the centre.
No other force is needed. Please analyze it in depth. If a rocket is spinning and burning its engines to produce a constant magnitude of acceleration then there exists some inertial reference frame where it is in uniform circular motion.Andrew Mason said:The rocket is quite a bit more complicated. I will need some time to think about it some more. But the situation described seems incomplete - there must be other forces involved in order for the centre of mass of the rocket to rotate about the centre of the space station with the centre of mass of the space station remaining inertial.
Where did you get this idea? The direction of the force is not automatically towards the COM. If you pull horizontally then the force is only directed towards the COM if it is vertically aligned with the COM. Otherwise the force could be directed above or below the COM.Andrew Mason said:When I pull on a box on a frictionless surface with a force F, the box pulls back on me with force F. Both forces are directed toward the same inertial point - the centre of mass.
Andrew, this continued discussion is pointless. The terminology exists, is well defined, and commonly accepted. You are absolutely correct that the centrifugal reaction force can cause centripetal acceleration in some circumstances, but that doesn't change a thing.
