Japan Earthquake: Nuclear Plants at Fukushima Daiichi
In summary: RCIC consists of a series of pumps, valves, and manifolds that allow coolant to be circulated around the reactor pressure vessel in the event of a loss of the main feedwater supply.In summary, the earthquake and tsunami may have caused a loss of coolant at the Fukushima Daiichi NPP, which could lead to a meltdown. The system for cooling the reactor core is designed to kick in in the event of a loss of feedwater, and fortunately this appears not to have happened yet.
  • #13,721
turi said:
Unfortunately the latest update is from March.
There is this press release - http://www.kit.edu/visit/pi_2012_9010.php
Perhaps interest in the subject has declined since German federal policy is currently rather against nuclear energy.
Nevertheless, it is of archival interest.
  • #13,722
The last time I wrote "NISA", it was a mistake. The regulation job is now done by the NRA (Nuclear Regulation Authority). Website : http://www.nsr.go.jp/
http://www3.nhk.or.jp/news/genpatsu-fukushima/20120926/index.html The NRA requests Tepco to write a report on the steel beam falling into pool problem by 3 October. The report shall include recurrence prevention countermeasures, and an estimate of the consequences and of the response, should a similar event cause pool damage and water leak.
  • #13,723
The 10th mid & long term meeting was held on 24 September 2012: http://www.meti.go.jp/earthquake/nuclear/20120924_01.html
1) Previous related topics:
The 9th meeting (27 August 2012) https://www.physicsforums.com/showpost.php?p=4051034&postcount=13635
The 8th meeting (30 July 2012) https://www.physicsforums.com/showpost.php?p=4020743&postcount=13588
The 7th meeting (25 June 2012) https://www.physicsforums.com/showpost.php?p=3979794&postcount=13512
The 6th meeting (25 May 2012) : https://www.physicsforums.com/showpost.php?p=3933442&postcount=13399
The 5th meeting (23 April 2012) : https://www.physicsforums.com/showpost.php?p=3881074&postcount=12979
The 4th meeting (28 March 2012) : https://www.physicsforums.com/showpost.php?p=3838108&postcount=12764
The 3rd meeting (27 February 2012) was translated into English on Tepco's website : http://www.tepco.co.jp/en/nu/fukushima-np/roadmap/conference-e.html
2) Translation:
24 September 2012 government-Tokyo Electric mid and long term response committee, steering committee (10th meeting)
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01a.pdf Agenda
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01b.pdf Participants
Document 1
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01c.pdf Abstract of the proceedings of 9th steering committee meeting
Document 2: Plant status
Document 2-1: Plant status
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01d.pdf Plant parameters
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01e.pdf Accumulated water storage status
Document 3 Study and execution of each special plan
3-1 Cooling by closed loop water injection
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01f.pdf Schedule
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01g.pdf High pressure flushing work and mock-up test results toward installation of alternative unit 2 thermometer
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01h.pdf Nitrogen injection into unit 1's suppression chamber
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01j.pdf Survey inside unit 1's PCV
3-2 Treatment of accumulated water
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01k.pdf Schedule
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01m.pdf Multinuclide removal facility (ALPS) progress status
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01n.pdf Ground water bypass executive plan
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01p.pdf Additional tank installation plan
3-3 Countermeasures to reduce environmental radiations
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01q.pdf Schedule
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01r.pdf Seawater radioactive concentrations inside harbor
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01s.pdf Results of evaluation of additional releases from reactor buildings
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01u.pdf Radiation dose decline at site boundaries: Status report as of September
3-4 Improvement of working conditions
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01v.pdf Schedule
3-5 Countermeasures for spent fuels pools
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01w.pdf Schedule
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01x.pdf Debris removal work, reactor building top part, unit 3
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01y.pdf Debris removal work, reactor building top part, unit 4
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01z.pdf Report on unit 4 fresh fuel survey
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01aa.pdf Underwater survey (survey No. 2) into unit 3 spent fuel pool for the purpose of inside pool debris removal
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01bb.pdf Common pool water quality management
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01cc.pdf Fukushima Daiichi unit 3 reactor building steel frame sliding and falling into spent fuel pool event
3-6 Preparations for fuel debris removal
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01dd.pdf Schedule
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01ee.pdf Survey of accumulated water inside unit 1 reactor building triangle corner
3-7 Treatment and disposal of radioactive waste
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01ff.pdf Schedule
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01gg.pdf Debris, cut down trees management status
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01hh.pdf Cut down trees (branches, leaves, roots) temperature monitoring status
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01jj.pdf Contaminated water analysis results
Document 4
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01kk.pdf roadmap progress (abstract)
24 September 2012 government-Tokyo Electric mid and long term response committee, technical development progress headquarters (9th meeting) ( http://www.meti.go.jp/earthquake/nuclear/20120924_02.html )
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_02a.pdf Agenda
Document 1
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_02b.pdf Abstract of proceedings of 8th meeting (draft)
Document 2
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_02c.pdf Abstract of progress status of "Grasping characteristics using mock-up debris, development of debris treatment technology"
Document 3-1
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_02d.pdf Status of technical study by the remote technology task force
Document 3-2
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_02e.pdf The NEDO's disaster unmanned-ization system
Document 4
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_02f.pdf Abstract of results of technical entry public appeal targetting mainly Fukushima Prefecture businesses, etc., concerning machinery and equipments development toward the decommissionning of Fukushima Daiichi nuclear power plant
  • #13,724
Tepconium-311 said:
According to water condensation visible in penetration and chamber fixture there probably was at least some moisture in the containment atmosphere.
Could visible "steaming" and condensation have been caused by (possibly relatively cold) nitrogen gas injection?
But, why didn it rain cats and dogs inside containment?
Is this good or bad?
I've yet to see a full analysis of that footage from reactor 1 containment yet. I didnt read too much into the lack of falling water compared to reactor 2, I was just assuming it means the path of the water being sprayed into the reactor doesn't go anywhere near where this camera went.
Its tempting to say that the most obviously notable thing about the video is the debris, but I don't really have any idea what I am looking at. Is the camera pointing down or towards the pedestal area? Are we seeing a square opening in the pedestal which is normally used during maintenance to replace control rods etc?
Anyway I wasnt expecting that video to exist as early as it did, going by the timetable there is further exploration of reactor 1 containment to be done in the first part of this month, so I hope to learn something more useful from that! What little we do now know about conditions in both the torus room and containment does have the potential to tell a story with dramatic new detail, but actually getting to a point where such a story is clear and likely may still take some time.
  • #13,725
http://www.tepco.co.jp/en/press/corp-com/release/2012/1221349_1870.html "As for the installation of Unit 2 RPV alternative thermometer, the RPV pressure was found to be higher than that measured during the mockup testing. At 10:33 PM on October 1, the flow rate of the nitrogen injected into Unit 2 PCV was changed from 5m3/h to 0m3/h (the amount of nitrogen injection into the RPV remains the same). As the amount of nitrogen injection into the RPV has been maintained at 15m3/h (the necessary minimum flow rate: 9m3/h), there should be no impact on safety. Due to the change in nitrogen injection amount, the monitoring of the hydrogen concentration in the PCV, PCV pressure, PCV ambient temperature and reactor pressure has been enhanced. As the RPV pressure has decreased (6kPa as of 5:00 AM on October 2), insertion of the coil guide (functions as a guide for thermometer installation) started at 9:39 AM on October 2. The insertion was completed at 11:57 AM on the same day."
http://www.tepco.co.jp/nu/fukushima-np/images/handouts_121003_01-j.pdf 3 October 08:30 Start of alternative thermometer insertion work. 11:03, same day, installation is completed. As of 11:00 the measured temperature on the said thermometer was 42.6°C. It is confirmed that it is roughly the same temperature as the 46.1° measured at 11:00 on the monitoring thermometer on the RPV lower part (TE-2-3-69H3)
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_121003_01-e.pdf Unit 2 RPV Alternative Thermometer Installation at Fukushima Daiichi Nuclear Power Station
  • #13,726
https://www.physicsforums.com/showthread.php?p=3934954#post3934954 6th meeting (25 May 2012) Execution of internal survey into unit 1 primary containment vessel (PCV)
https://www.physicsforums.com/showthread.php?p=4058562#post4058562 9th meeting (27 August 2012) Execution of internal survey into unit 1 primary containment vessel (PCV)
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_120927_02-e.pdf (27 September 2012) Punching an Access Hole at the Penetration (X100BPenetration) of Unit 1 PCV at Fukushima Daiichi Nuclear Power Station
2) Translation:
As most pages happen to be copies of August's presentation, I translate only the new materials found on pages 12-15 :
12/20
13/20
  • #13,728
2) Translation:
14/20
15/20
  • #13,729
I remain somewhat frustrated by the lack of articles about the initial footage inside reactor 1 containment.
I think the most detail I've seen anywhere is in this article, which suggests that the lead plates that were supposed to be on the end of the penetration they used were missing, presumed melted.
http://www.yomiuri.co.jp/dy/national/T120928003442.htm
  • #13,730
Thanks. I was not aware of that.
Here is the transcript of the 27 September press conference:
http://genpatsu-watch.blogspot.com/2012/09/20129271730-1.html [Tepco spokesman, Mr Ono comments the video ( http://photo.tepco.co.jp/en/date/2012/201209-e/120927-01e.html )] : Yesterday the penetration hole opening work was completed without problem. A video is available. I would like to show it to you. This picture is the result of inserting a camera to see how the hole was opened and for checking the situation after the hole was opened in the penetration with a cutter. [...] [he explains as the camera passes the ball valve, then the hole in the penetration stop plate, etc...] We have come to the inner side of the PCV. [...] Here it was originally the flange's outer side where a lead plate is mounted for shielding, but it was understood that it fell down and it is removed. That's what it is, and there is no need to open another hole in the lead plate, and it was confirmed that the entry inside [PCV] is possible. [then he comments as the camera progresses further inside the PCV][...]
NHK's Yokogawa: [...] As there was no lead plate, is the schedule going to be advanced ?
Ono : As a whole, the work must progress carefully, so I think it will be carried out almost as expected in the schedule.
[That's all they say about the lead plate]
  • #13,731
May be lead plates are deformed by heat and one of them fall off when they worked on drilling through the wall to enter PCV with the endoscope ?
  • #13,732
Thanks very much for the press conference details :)
I don't know if the plate(s) fell down or melted completely, its certainly assumed that it got hot enough in containment for that sort of thing to happen I guess.
I will say that if we look at the photo taken in the reactor building which shows where the penetration is, there appear to be stains around the top of the equipment hatch plug which seem to support the idea of heat, smoke etc. I am talking about the photo that can be seen on the page labelled 3 of the translation tsutsuji did a while ago: https://www.physicsforums.com/showthread.php?p=4058562#post4058562
  • #13,733
I was curious about the picture, extracted from the unit 1 PCV video, captioned "scattered debris" by Mainichi at http://mainichi.jp/select/news/20120928k0000e040161000c.html and by Tokyo Shimbun http://www.tokyo-np.co.jp/movie/news/120928.html 's comment "very small scraps of inside-vessel steel members can be seen", so I read the press conference transcript where I had left it, after Mr Ono's comment on the disappeared lead plate :
http://genpatsu-watch.blogspot.com/2012/09/20129271730-1.html From there the camera progresses forward. Exactly now we are almost at the exact entrance of the PCV. The camera moved just a little forward into the inside of the PCV. Just after leaving the penetration, there is a structural part there, which is a rail. There are such things as platforms for a number of equipments installed inside the PCV or rails, and, although we don't know what they are, we found that things looking like very thin scraps have fallen on it. There is a rail located immediately after passing through the penetration, and it can be thought that these have fallen and accumulated on that rail. The situation is that a number of this kind of long-shaped objects are lying in it. If we try to change the angle of view by rotating the camera, it is quite clear that they are pretty thin, but we think that at this stage it is still difficult to confirm what they are. [then he explains that the purpose, this time, was to check that the camera and measuring instruments can be inserted into the PCV, and as the result for this is positive, the camera is now going to be pulled back]
  • #13,734
Those would be shrapnel, from a pipe most likely. Chemical analysis would tell us exactly what kind of steel, but I ain't holding my breath. There is still an evident unwillingness on the part of TEPCO to find out what has happened and what is happening, beyond the absolutely, immediately necessary.
  • #13,735
http://genpatsu-watch.blogspot.com/2012/09/20129271730-1.html From there the camera progresses forward. Exactly now we are almost at the exact entrance of the PCV. The camera moved just a little forward into the inside of the PCV. Just after leaving the penetration, there is a structural part there, which is a rail. There are such things as platforms for a number of equipments installed inside the PCV or rails, and, although we don't know what they are, we found that things looking like very thin scraps have fallen on it. [/QUOTE]
This sure looks like shavings from a machining operation, I wonder if it is from the boring
through of the hole.
Jon
  • #13,736
Yes, most likely from the drilling.
Certainly not shrapnel.
  • #13,737
Only there was no drilling. There was supposed to be drilling because there was assumed to be a lead plate in the way. Only, the plate had melted probably and in any case it's gone. Those splinters are not lead, either. Lead would have had plenty of time to oxidize and those are rather shiny.
  • #13,738
Not believing shrapnel.
Maybe you could provide pictures of shrapnel that looks even remotely like the material from the video.
  • #13,739
http://www3.nhk.or.jp/news/genpatsu-fukushima/20121010/index.html "Unit 1's PCV water level is 2.80 m" The PCV was inspected on 9 October and a video was released on 10 October. Falling drops of water (rain) were not observed like in unit 2. It is believed that the humidity is less than in unit 2. A working platform [the grating, I guess] is rusted over a large area. On that platform, an about 30 cm long rod was found. The accumulated water surface is seen shining below the platform. Tepco measured the water surface as being 2.80 m above PCV bottom. The highest measured radiation was 11.1 Sv/h, which can cause death in about 40 minutes. Tepco said the water level is almost as expected, the melted fuel at the bottom of the PCV is sufficiently cooled, and the finds have no impact on the decommissioning plans.
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_121009_01-e.pdf " Investigation Results of the Inside of Unit 1 PCV at Fukushima Daiichi Nuclear Power Station" (9 October)
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_121010_01-e.pdf Investigation Results of the Inside of Unit 1 PCV at Fukushima Daiichi Nuclear Power Station (10 October)
http://photo.tepco.co.jp/en/date/2012/201210-e/121010-01e.html pictures and videos
  • #13,741
zapperzero said:
And so we get to ask another round of questions.
The measured dose rate decreases with height, which makes zero sense to me. Any ideas?
If the models are correct then there are only a relative small amount of core debris still in the RPV and the rest, slumped down to the slump pit on the bottom of the PCV (and even lower than that as it burned some hole in the concrete) is shielded by water.
So for first look it looks OK for me.
Ps.: can't wait for the water sample. The low dose measured in the water can indicate that the corium has little direct connection with the cooling water.
  • #13,742
Or that a year-and-a-half of flushing with fresh water has washed away most of the water-soluble substances and only the less soluble material remains in place.
  • #13,743
Or most of the core is still in the bottom of the RPV
  • #13,744
That would be a miracle... For the other two cores the models are not necessarily suggests the RPV-damage, but for unit 1...
I wonder if flushing through the turuses would reduce the radiation levels in the basements?
The contamination of the water in the basements are continuously falling, but the toruses are most likely still full with the stuff from the first days.
  • #13,745
What would be found in the torus would have to be mostly insoluble. The radioactivity decreases with time, or otherwise the radionuclides have been transported either to collection systems or to the environment.
http://www.world-nuclear-news.org/RS-Unit_1_containment_vessel_investigated-1110124.html
An investigation is underway into the internal conditions of the primary containment vessel (PCV) of the reactor at unit 1 at the damaged Fukushima Daiichi nuclear power plant. Tokyo Electric Power Company (Tepco) said that the water level in the vessel has been found to be higher than previously estimated.
Some retrospective - old news
http://eetd-seminars.lbl.gov/sites/eetd-seminars.lbl.gov/files/Fukushima1_Technical_Perspective_LBL_EEDT_04052011-1.pdf
  • #13,746
  • #13,747
Just a guess but shiny metal in the drywell could be mirror insulation. There's a fair amount of it. It's not out of the realm of possibility that the dynamic forces that resulted from the breach of the RPV by core debris also tore up some of this insulation and deposited some of it where the picture shows.
  • #13,748
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01n.pdf Ground water bypass action plan
https://www.physicsforums.com/showthread.php?p=3882136#post3882136 23 April 2012 Plan to reduce volumes of groundwater seeping into units 1~4 buildings by groundwater bypass
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_120618_05-e.pdf 18 June 2012 Progress status of ground water bypass
2) Translation:
As pages 08/11 to 11/11 happen to be copies of older presentation, I translate only the new materials found on pages 01-07 :
01/11
  • #13,749
2) Translation:
02/11
03/11
04/11
  • #13,750
2) Translation:
05/11
06/11
07/11
  • #13,751
http://www.meti.go.jp/earthquake/nuclear/pdf/120924/120924_01ee.pdf Survey of accumulated water inside unit 1 reactor building triangle corners
Translation:
01/06
02/06
03/06
  • #13,752
Translation:
04/06
05/06
06/06
  • #13,753
So the idea, if I understand it right, is to lower the local water table level to that of the water inside the reactors?
  • #13,754
The idea is to enable lowering the water level inside the buildings (and ultimately to pump them dry) without causing an increase in the groundwater inflow.
  • #13,755
So they are meant to keep the inflow?
  • Nuclear Engineering
46K
51
418K
17K
259K
14K
11K
