Computation of Continued Fractions of irrational numbers
In summary, computer algorithms may produce false continued fraction expansions due to limited accuracy in floating point arithmetic. The conversation discussed the use of continued fractions in representing irrational numbers, such as square roots. Some examples of continued fraction expansions for different square roots were given and the connection to solving Pell's equation was explained. Rational arithmetic was suggested for more accurate evaluation of continued fractions. The conversation also touched on the properties of continued fractions for quadratic surds and other mathematical constants. Finally, the use of exact arithmetic was recommended for improved accuracy in calculations involving continued fractions.
RamaWolf
95
In this field, computer algorithms may produce false continued fraction expansions because of
the limited accuracy in the floating point arithmetic used. Who knows more?
Let [itex]\sqrt{2}[/itex] - 1 = [itex]\frac{1}{x}[/itex] for x > 0,
or - equivalently - [itex]\sqrt{2}[/itex] + 1 = x, we get the well-known
identity x = 2 + [itex]\frac{1}{x}[/itex], from which we have
[itex]\sqrt{2}[/itex] - 1 = [itex]\frac{1}{x}[/itex] = [itex]\frac{1}{2 + 1/x}[/itex]
Repeated replacement of x = 2 + [itex]\frac{1}{x}[/itex] in the denominator's 1/x
we get the Continued Fraction expression for [itex]\sqrt{2}[/itex] as
[itex]\sqrt{2}[/itex] = [1; 2, 2, 2, 2, 2, ,2 ,2 ...], or in short form [1; (2)]
To explain the short notation of a Continued Fraction here are two samples:
[b[itex]_{0}[/itex]; b[itex]_{1}[/itex], b[itex]_{2}[/itex]] = b[itex]_{0}[/itex]+[itex]\frac{1}{b_{1}+\frac{1}{b_{2}}}[/itex]
[b[itex]_{0}[/itex]; b[itex]_{1}[/itex], b[itex]_{2}[/itex], b[itex]_{3}[/itex]] = b[itex]_{0}[/itex]+[itex]\frac{1}{b_{1}+\frac{1}{b_{2}+\frac{1}{b_{3}}}}[/itex]
Other Continued Fraction expansions are:
[itex]\sqrt{3}[/itex] := [1; 1, 2, 1, 2, 1, 2, 1, 2, ...] or in short form : [1; (1, 2)]
[itex]\sqrt{5}[/itex] := [2; (4)] [itex]\sqrt{6}[/itex] := [2; (2, 4)] [itex]\sqrt{7}[/itex] := [2; (1, 1, 1, 4)]
[itex]\sqrt{8}[/itex] := [2; (1, 4)] [itex]\sqrt{10}[/itex] := [3; (6)] [itex]\sqrt{11}[/itex] := [3; (3, 6)]
[itex]\sqrt{12}[/itex] := [3; (2, 6)] [itex]\sqrt{13}[/itex] := [3; (1, 1, 1, 1, 6)] [itex]\sqrt{14}[/itex] := [3; (1, 2, 1, 6)]
[itex]\sqrt{15}[/itex] := [3; (1, 6)] [itex]\sqrt{17}[/itex] := [4; (8)] [itex]\sqrt{18}[/itex] := [4; (4, 8)]
The solution of Pell's equation is connected to the (periodic) expansion of a specific Continued Fraction by the following theorem due to Lagrange:
Theorem Let x[itex]^{2}[/itex] - N*y[itex]^{2}[/itex] = 1 for a non-square integer N,
let [itex]\sqrt{N}[/itex] have a periodic Continued Fraction expansion of length k,
and let [itex]\frac{s}{t}[/itex] be it's (k - 1)th convergent,
then (s, t) is a solution to the Pell's equation
As an example, we take N = 19 and we try to compute the Continued Fraction (CF) expansion
using different compiler's floating point accuracy:
SQRT(19) = 0.43588 * 10[itex]^{1}[/itex] -> CF = [4; 2,1,3,1,2,3,2,2,3,2,6,1,7,...]
SQRT(19) = 0.4358898 * 10[itex]^{1}[/itex] -> CF = [4; 2,1,3,1,2,8,3,1,2,52,2,3...]
SQRT(19) = 0.435889894 * 10[itex]^{1}[/itex] -> CF = [4; 2,1,3,1,2,8,2,1,3,1,3,396,...]
SQRT(19) = 0.43588989435 * 10[itex]^{1}[/itex] -> CF = [4; 2,1,3,1,2,8,2,1,3,1,2,7,1,5,..]
with no periodicity; only with 13 digits accuracy (or more) we finally have
SQRT(19) = 0.4358898943540 * 10[itex]^{1}[/itex] -> CF = [4; (2,1,3,1,2,8)]
The period length is 6, and for the computation of the 5-th CF convergent we use
the function Inv(q), which reverses numerator and denominator of a rational fraction:
C[itex]_{5}[/itex]([itex]\sqrt{19}[/itex]):=4+Inv(2+Inv(1+Inv(3+Inv(1+[itex]\frac{1}{2}[/itex]))))) := [itex]\frac{170}{39}[/itex]
and x=170, y= 39 is a solution to x[itex]^{2}[/itex] - 19*y[itex]^{2}[/itex] = 1
To avois any issues with the mssing accuracy of the floation point arithmetic, it is suggested
to use accurate 'rational arittmetic' to evaluate the Continued Fraction expansion of a
integer N, not a perfect square.
To this end we use the following
Theorem on rational convergents of a square root: Let N be an integer, not a perfect square,
c[itex]_{0}[/itex] := 1/1 and define recursively, c[itex]_{i+1}[/itex] := [itex]\frac{c_{i}+N/c_{i}}{2}[/itex], we have [itex]\underbrace{lim}_{i->\infty}[/itex] c[itex]_{i}[/itex] -> [itex]\sqrt{N}[/itex]
As an exampel, the rational convergents of [itex]\sqrt{19}[/itex] are:
c[itex]_{1}[/itex] := 10/1, c[itex]_{2}[/itex] := 119/20, c[itex]_{3}[/itex] := 21761/4760, c[itex]_{4}[/itex] := 904035521/207164720
c[itex]_{5}[/itex] := 1632707426270631041 / 374568531156038240,
c[itex]_{6}[/itex] := 5331463645914715901021239526856398081 / 1223121644931491741401139604654015680
Using c[itex]_{6}[/itex] the CF expansion of [itex]\sqrt{19}[/itex] was compute as [4; 2,1,3,1,2,8,2,1,3,1,2,8,2,1,...], establishing this expansion as [4;(2,1,3,1,2,8)]
The rational arithmetc was done using the 'Q' package of my long-integer arithmetic VAR16
Any root of a whole number, or root of a rational for that mater will have a repeated continued fraction as you described. That's true for any quadratic surd ( http://en.wikipedia.org/wiki/Quadratic_surd ). The converse is also true, so if it has repeated coefficients it's of the form (a+b[itex]\sqrt{}c[/itex])/d for some integer values a,b,c and d.
The continued fraction representations for square roots of integers also have an interesting property that the repeat sequence is a palindrome (same forward as backward). The last term of the repeated sequence is always twice the integer part of the square root.
[itex]\sqrt{46}[/itex] = CFS([6L, 1L, 3L, 1, 1, 2L, 6L, 2L, 1, 1L, 3L, 1L, 12L],[0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0L])
[itex]\sqrt{71}[/itex] = CFS([8L, 2L, 2L, 1, 7L, 1, 2L, 2L, 16L],[0, 0, 0, 0, 0, 0, 0, 0L])'
[itex]\sqrt{94}[/itex] = CFS([9L, 1L, 2L, 3L, 1, 1, 5L, 1, 8L, 1, 5L, 1, 1L, 3L, 2L, 1, 18L],16)
Other mathematical constants also have interesting representations in continued fractions.
For example e = [ 2; 1, 1, 2, 1, 1, 4, 1, 1, 6, 1, 1,8, ...] = CFS([2,1,2,1],[0,2,0] = CFS([1,0,1],[0,2,0])
[itex]\sqrt{e}[/itex] = [ 1; 1, 1, 1, 5, 1, 1, 9, 1, 1, 13, 1,...] = CFS([1,1,1],[0,4,0])
[itex]\sqrt[n]{e}[/itex] = [ 1; (n-1), 1, 1, (3n-1), 1, 1, (5n-1), ...] = CFS([1, (n-1), 1],[0, 2*n,0])
While [itex]\pi[/itex] does not have a simple 'simple continued fraction' form it does have several nice 'generalized continued fraction' forms.
There are some nice algorithms that deal with calculations using continued fractions. Check out Bill Gosper's algorithm in the unpublished Hakmem http://www.inwap.com/pdp10/hbaker/hakmem/hakmem.html .
Nothing says accuracy like exact arithmetic.
1. What is a continued fraction of an irrational number?
A continued fraction is a way of representing a real number by expressing it as a sequence of integers, with each integer representing a partial quotient of the number. In the case of irrational numbers, the sequence of integers is infinite and non-repeating.
2. How is the computation of continued fractions of irrational numbers done?
The computation of continued fractions involves a recursive algorithm that continually divides the current partial quotient into the remainder of the previous division. This process is repeated until the remainder reaches zero, at which point the sequence of partial quotients is considered complete.
3. What is the significance of computing continued fractions of irrational numbers?
Computing continued fractions allows for a more precise representation of irrational numbers compared to decimal or other numerical representations. It also provides insights into the properties and relationships of different types of numbers.
4. Are there any practical applications of continued fractions of irrational numbers?
Yes, continued fractions are used in many fields such as cryptography, number theory, and engineering. They are also used in approximating irrational numbers for computational purposes.
5. Can all irrational numbers be represented as continued fractions?
No, not all irrational numbers can be represented as continued fractions. For example, numbers such as pi and e have infinite and non-repeating decimal representations, making it impossible to find a finite continued fraction for them. However, almost all irrational numbers can be approximated by continued fractions to any desired degree of accuracy.
  • Calculus
  • Quantum Physics
