How are diamagnets repelled from high field regions?
  • Thread starter cf123
  • Tags
    Field
In summary: At the right edge, B points in the same direction as the M, and at the left edge, B points in the opposite direction of M. So the B field is weaker inside the diamagnet compared to the outside. H, on the other hand, is stronger inside the diamagnet compared to the outside. Therefore, the diamagnet will be attracted to the high-field region of the electromagnet, which is the pointed S pole. In summary, a diamagnet will be attracted to the high-field region of an electromagnet, even though its magnetization field, M, points in the opposite direction of the external magnetic field, B. This is due to the fact that the B field is weaker inside the diamagnet, making the
cf123
Imagine an electromagnet with two pole faces, one flat (N) and one pointed (S). If you put a diamagnet in between them, I know that it will be attracted to the high-field region (i.e. the S pole where the field lines are more concentrated).
On the other hand, they always say that diamagnets will have an induced moment that cancels the field inside of them. That would mean that the diamagnet in this example could be viewed as a dipole, with its N pole closer to the pointed S pole of the electromagnet, and with its S pole closer to the flat N pole of the external magnet.
I would, from this analysis, then expect my diamagnet to be attracted to both poles of the electromagnet, but more so to the pole with the higher field: the S pole. That is paramagnetic behavior, and obviously this is completely wrong. What am I missing?
A diamagnet would have its South pole closer to the South Pole of the electromagnetic. I think you may be confusing the relation between B and H. B will not simply equal mu H near the end of the object.
I understand that the diamagnet would have to have its SP closer to the SP of the electromagnet, in order to make the forces work out correctly in this example. What I do not understand is how having an induced moment in that direction would cancel the field inside the object, and not make it stronger... (The field lines from the electromagnet would run S-->N and the field lines inside the dipole would run parallel, not antiparallel to that...)
You have to distinguish between the 3 fields, B, H, M. When you say "field lines" which field do you mean?
In a rod with no magnetic properties, B and H are the same inside and out, and M=0. I am using Gaussian units so that we can compare B and H without mu0. If the rod has negative susceptibility (mu<1), with B = mu H,
B inside the rod will be less than it was before, and H inside the rod
will be greater. Since B-H=4pi M, M will be in the opposite direction.
Outside the rod, B equals H and both are weaker than they were with no susceptibility.
If you draw a picture of the rod with zero susceptibility, and then one for negative susceptibility, putting in all three fields on each I think the situation should be clear.
The B and H fields will always be in the direction of the external magnetic field in each case. The magnetization field, M, will always be in the opposite direction.
I hope this helps.
Alright, my understanding is this:
For a diamagnetic material, u<1 and B=uH = H+4piM.
Therefore, M must point in the opposite direction of H, whereas B and H point in the same direction.
Now, I draw a picture:
eN S----->N eS
eN=electromagnet north pole,N=diamagnet north pole, etc. That is, we place our diamagnetic dipole in between two poles of an electromagnet, with its moment opposing the field.
If, then we say that due to the shape of the electromagnet, the region near eS is higher field than the region near eN, won't this diamagnet be attracted to the high field region?
Thanks for your help!
Your picture is wrong. It should be eN N<----------------<S eS.
There is effective magnetic surface charge at each end of the diamagnetic given by ##{\bf M\cdot{\hat n}}##. This puts a S Pole at the right and a N pole at the left. It is M, not B or H that determines the effective magnetic poles.
I'm sorry for asking so many questions. How are B, H, and M not all pointing the same direction in your picture? Won't the vectors point in the same direction (S to N and eS to eN) in your picture?
B and H are to the right, but M is to the left in that picture.
This makes B<H in the diamagnet.
1. What is a diamagnet?
A diamagnet is a material that is not magnetic itself, but can be temporarily magnetized when placed in a magnetic field. It is repelled by both north and south poles of a magnet.
2. How are diamagnets repelled from high field regions?
Diamagnets are repelled from high field regions due to the interaction between the magnetic field and the electrons in the material. The electrons experience a force opposite to the direction of the magnetic field, causing the diamagnet to be pushed away from the high field region.
3. Why are diamagnets only repelled and not attracted to high field regions?
Diamagnets are only repelled from high field regions because they have no permanent magnetic dipole moment. This means that the electrons in the material cannot align to create a magnetic field that would be attracted to the high field region.
4. Can any material be a diamagnet?
Yes, any material can be diamagnetic to some extent. However, some materials are more strongly diamagnetic than others. Superconductors, for example, are very strongly diamagnetic and will completely expel magnetic fields from their interiors.
5. Are diamagnets used in any practical applications?
Yes, diamagnets are used in various applications such as levitation, magnetic bearings, and magnetic resonance imaging (MRI). They are also used in high-speed trains to reduce friction and in maglev trains to achieve levitation.
  • Electromagnetism
  • Electromagnetism
9K
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
