The diffrence between refraction of sound and light
In summary, according to the general rule, sound waves should refract away from water when entering it. However, this rule is not always accurate, and for sound waves passing from air to water, the angle of refraction is different.
Sjonsjon
I was thinking about refraction of waves and I´m a little unsure. I wanted to run my understanding through you guys to make sure I´m right.
So
The general rule is when a wave goes from a slower medium to a faster medium the wave should turn sligtly away from the faster medium when it enters it. And we can turn it around and say when a wave goes from a faster medium to a slower medium the wave should turn slightly towards the medium when it enters it.
Something like this:
http://hyperphysics.phy-astr.gsu.edu/hbase/geoopt/refr.html
So when a light wave goes from air to water the light should bend towards the water because it going from faster to a slower medium. But it should be the opposite with sound, when sound goes from air to water then the wave is going from a slower medium to a faster medium so it should bend away from the water when it enters it.
Am I right about this? And if I am right than this picture must be wrong which confused me alot.
http://learn.uci.edu/oo/getOCWPage.php?course=OC0811004&lesson=005&topic=003&page=14
Science news on Phys.org
Why? Sound is just like light in that respect.
It is different for matter waves, but that is quantum mechanics.
Sound refracts the opposite way as opposed to light because when sound is entering water from air it is going from a slower to faster medium, but when light is entering water from air it is going from faster to a slower medium and should refract the opposite way. Right?
That is why I said sound should be the opposite because i was referring to sound refracting in the opposite direction as opposed to light when entering water.
The image you show is indeed not realistic for sound waves.
When sound enters water from air the angle between the normal and the beam increases.
Here is a nice site where you can experiment (virtualy):
http://www.ndt-ed.org/EducationResources/CommunityCollege/Ultrasonics/Physics/refractionsnells.htm
I think the problem may originate in the author of the site reproducing an image from Dr Russell's site (they give a link to it, in blue) without realizing that that specific image illustrates refraction of light.
Ah ok, your remark was specific to water/air and not related to the general concept. Well, that is right.
Thanks for the reply. I think you are right, must have been an oversight on there part, but it confused the hell out of me.
So
The general rule is when a wave goes from a slower medium to a faster medium the wave should turn sligtly away from the faster medium when it enters it. And we can turn it around and say when a wave goes from a faster medium to a slower medium the wave should turn slightly towards the medium when it enters it. [..]
Hi Sjonson, welcome to physics forums! :smile:
It is the same for all waves. And instead of learning it with words, it is much more useful to understand it with the Huygens construction:
https://en.wikipedia.org/wiki/Huygens'_principle
The angles involved depend on the Wavelength - which, of course, relates to speed. In water, the wavelength of sound is about fifteen times the speed in air so it would be quite difficult to do a scale diagram what would make immediate sense. Of course, 'that diagram' is the wrong way round and, imo, a rather sloppy bit of presentation - if it is trying to be helpful.
There is another very important issue with the passage of sound from air into water. When waves pass from one medium to another, there is always some reflection of energy (a reflected wave). The greater the difference in refractive index, the more is reflected. In the case of Air into Water - or the other way, the mis-match is huge and most of the sound energy is reflected. That's one reason why it all goes quiet when we stick out heads under water.
This did not come out very well.
The speed in water is about 4 times the speed in air (a little more than 4).
So the wavelength in water is about 4-5 times larger than the wavelength in air (for the same frequency, of course).
Whoops - I was quoting the water speed in ft/s Durrrr. Why can we still encounter those pesky Imperial Units on the Webb?
The other bit was correct though!
FAQ: The diffrence between refraction of sound and light
1. What is the main difference between the refraction of sound and light?
The main difference between the refraction of sound and light is the medium through which they travel. Sound waves travel through a material medium, such as air, while light waves can travel through a vacuum. This means that sound waves are affected by the physical properties of the medium, while light waves are not.
2. How does the speed of sound and light affect their refraction?
The speed of sound and light also differs in their refraction. The speed of sound decreases as it travels through a denser medium, causing it to bend towards the medium. On the other hand, the speed of light increases in a denser medium, causing it to bend away from the medium. This is due to the different ways that sound and light waves interact with the particles of the medium.
3. Can the refraction of sound and light be observed in everyday life?
Yes, the refraction of sound and light can be observed in everyday life. The bending of sound can be observed when you hear a faint sound from a distance, as the sound waves bend to reach your ears. The bending of light can be observed when you see a straw appear bent in a glass of water, due to the refraction of light as it travels from air to water.
4. Do sound and light waves behave differently when they encounter a boundary between two mediums?
Yes, sound and light waves behave differently when they encounter a boundary between two mediums. Sound waves undergo a larger amount of refraction compared to light waves when they encounter a boundary, as they have a lower speed and are more affected by the properties of the medium. Light waves, on the other hand, undergo less refraction as they are less affected by the properties of the medium.
5. Are there any similarities between the refraction of sound and light?
Despite their differences, there are also some similarities between the refraction of sound and light. Both sound and light waves can be refracted, or bent, as they pass through different mediums. Additionally, the amount of refraction for both sound and light waves depends on the angle at which they encounter the boundary and the difference in the properties of the two mediums.
