badrie2004
- 4
Can somebody help me to find this kind of circuit.im really appreciete your help
Specification
Only one bjt,one opamp ua741 and asingle power supply of 12v must be used. A 10k ohm load and an input signal will be connected via capacitors to the amplifier. The max voltage gain is about -500.imput impedance is about 600 ohm.output impedance is about 10k ohm.the low cut off frequency is about 200hz and the high cutoff frequency is about 20khz(bandwith of 200-20khz ;2decades).the maximum pek-to-peak(mpp) output voltage without clipping is more or equal to 6v.make sure that the opamp must not produce a low rate distortion at less or equal 20khz.
Please I need this for final year project
Specification
