All Square Numbers Follow a Recursive Series?
In summary, the conversation discusses a recursive series that can generate every square number. The example given shows how the series works and there is a suggestion to use the Z transform to prove it. It is also mentioned that these sequences correspond to the natural responses of linear discrete-time systems.
IntegrateRSC
Sorry if this is a well known thing, but I've noticed this and decided to see how well known it is, also if there is a way to prove it other than the recursive series.
an=(an-1-an-2+2)+an-1
This recursive series will in fact generate every square number. Take in example:
a0=0
a1=1
So if you use the recursive series above:
a2=(a1-a0+2)+a1
a2=(1-0+2)+1
Any comments? I'm praying I used the 'sub' tags right
let's call sqrt(an-1) is x. Then we want to prove that 2x2=(x+1)2+(x-1)2-2. Simple algebra.
Look up the Z transform and it's inverse. You can form recursive solutions corresponding to polynomials of arbitrary order. These sequences correspond to the natural responses of linear discrete-time systems.
1. What is a recursive series?
A recursive series is a sequence of numbers where each number is calculated from the previous number using a specific rule or formula.
2. How do you know if a series is recursive?
A series is recursive if each number in the series follows a specific pattern or rule, such as adding a constant number or multiplying by a fixed value.
3. Are all square numbers recursive?
Yes, all square numbers follow a recursive series. Each square number is calculated by multiplying the previous number by 2 and adding 1.
4. Is there a formula for finding the nth term in a recursive series?
Yes, there is a formula for finding the nth term in a recursive series. It is often called the recursive formula and it involves using the previous term(s) to calculate the next term in the series.
5. Can recursive series be used in real-life applications?
Yes, recursive series can be used in real-life applications, such as in computer programming or financial calculations. They are also used in various fields of science, such as physics, biology, and chemistry, to model natural processes.
  • Linear and Abstract Algebra
