B Field Confinement for Toroidal Coils Driven by AC Current
In summary, the conversation discusses the concept of toroidal inductors/coils and their ability to confine B fields. It is suggested that perfectly axially symmetric toroids can completely confine B fields, with a nonzero and constant electric field wrapping around the outside. This applies to DC currents or steadily increasing ones. However, the question arises on whether this natural confinement can also be achieved with AC currents. The possibility of toroidal transformers taking advantage of this confinement is also mentioned, but the idea is questioned as the external B field would need to oscillate and have a non-zero curl, which goes against Faraday's and Ampere's laws. The presence of a secondary winding in transformers is also mentioned, leaving uncertainty on whether toroidal
-dove
24
It is said that toroidal inductors/coils (see http://fa.tu-sofia.bg/te/Brandisky/images/toroidal_coil.jpg ) that are perfectly axially symmetric will completely confine B fields. That is, the B field inside will be nonzero and will circle the toroid, but the B field outside the toroid will be zero. This makes sense for a DC current. The magnetic field inside will be constant and there will be a nonzero, constant, electric field wrapping around the oustide of the toroid that has no curl.
Now, from what I've read, this natural confinement is supposedly taken advantage of by toroidal transformers. However, transformers are driven by AC currents, and I can't figure out how a toroidal inductor driven by an AC current can possibly have zero external B field. The external E field would have to oscillate in order to obey Faraday's law (since the flux inside is oscillating), but then the external E field would be time varying. So, since there is no external current, Ampere's law would then imply that the external B field must have a non-zero curl (at least at some times) and thus at certain times the external B must be nonzero. Thus, I don't see how toroidal inductors could possibly confine B fields when driven by AC currents. Now, transformers are different from inductors; they have a secondary winding in addition to the first one. But the whole situation has left me suspect to whether or not anyone is even claiming that toroidal coils and transformers confine B fields when driven by AC.
Do 'ideal' toroidal transformers perfectly confine B fields (when driven by AC)? And if so is it just a result of the secondary winding cancelling out the external field? Or what?
EDIT: The end of that first paragraph should read
"This makes sense for a DC current or a steadily increasing one. In the former case, the magnetic field will be constant inside and zero outside; the electric field outside will be zero as well. In the latter case, the magnetic field inside will steadily increase, the magnetic field outside will remain zero, and the electric field outside will be nonzero, constant, have zero curl, and wrap around the toroid."The question regarding AC (or any case where the internal B has a nonzero second derivative w.r.t. time) remains the same.
Related to B Field Confinement for Toroidal Coils Driven by AC Current
1. What is "B Field Confinement" for toroidal coils driven by AC current?
"B Field Confinement" refers to a method of containing and controlling magnetic fields produced by toroidal (doughnut-shaped) coils when they are driven by alternating current (AC). This is typically used in fusion reactors and other plasma confinement devices.
2. How does "B Field Confinement" work?
In this method, the AC current flowing through the coils generates a magnetic field that is confined within the toroidal shape. This is achieved by carefully controlling the shape and strength of the coils, as well as the frequency and amplitude of the AC current.
3. What are the advantages of using "B Field Confinement"?
One major advantage is that it allows for greater control and stability of the magnetic field, which is crucial for maintaining a stable plasma in fusion reactions. Additionally, this method is more efficient and produces less heat compared to other methods of magnetic field confinement.
4. Are there any limitations to using "B Field Confinement"?
One limitation is that it requires precise and complex engineering of the coils and the AC current parameters, which can be expensive and difficult to maintain. Additionally, this method may not be suitable for all types of fusion reactors or plasma confinement devices.
5. What are some potential applications of "B Field Confinement"?
In addition to its use in fusion reactors, B Field Confinement has potential applications in other areas such as magnetic levitation for transportation systems, particle accelerators, and medical devices such as MRI machines.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
