Is an un-spannable vector space automatically considered infinite dimensional?
In summary, the process of finding a basis for a vector space can continue indefinitely, resulting in an infinite-dimensional space. Every vector space has a basis, so there is no need for the term "unspannable." If a set of elements cannot be labeled easily, notation can be used to define the set. However, in some cases, such as in the absence of the Axiom of Choice, there may be vector spaces without a basis. In these cases, alternative concepts like Schauder basis can be used to describe the space.
alemsalem
175
If you have a vector space you can find a set of elements and consider their span, and then look for elements that cannot be spanned by them and so add them to the set, if you can't add anymore then you have a basis.
My question is what happens if this process continues forever, do you automatically call it infinite dimensional or is there such a thing as an unspannable space.
Also what happens if there is a set but it cannot be labeled nicely such as {sin(nx)}..
Thanks!
Such spaces are said to be infinite-dimensional. Every vector space has a basis, so there's no need for terms like unspannable. You can use a notation like [itex]\{\mathbb R\ni x\mapsto \sin nx\in\mathbb R|n\in\mathbb Z^+\}[/itex], or be less formal and shorten it to [itex]\{\sin nx|n\in\mathbb Z^+\}[/itex]. You can also e.g. define, for each n=1,2,..., [itex]u_n:\mathbb R\rightarrow\mathbb R[/itex], by [itex]u_n(x)=\sin nx[/itex] for all [itex]x\in \mathbb R[/itex], and write the set as [itex]\{u_n|n\in\mathbb Z^+\}[/itex].
there's a theorem out there that says every finite dimensional vector space must have a basis ( and it uses Zorns lemma ) , so that should clear things up for oyu
In the finite-dimensional case, the existence of a basis follows immediately from the definition of "basis" and "finite dimensional". So you only need Zorn when the vector space is infinite dimensional.
Like Frederik has already said: using Zorn's lemma, we can show that every possible vector space has a basis. But this uses the axiom of choice and is highly unconstructive. If we do not assume the axiom of choice, then there may be some vector spaces without a basis (for example: consider [tex]\mathbb{R}[/tex] as [tex]\mathbb{Q}[/tex]-vector space).
So while we can show (using choice) that every vector space has a basis, there is something undesirable about this. Namely the fact that we can never write down the basis in any way. But the entire point of having a basis is so that we can use it to know more about the vector space. Thus having a basis of an infinite dimensional vector space seems to be a little useless.
That's why some people proposed things which weren't a basis, but which did have some desirable properties. For example, a Schauder-basis is a set of elements such that every element can be written as an infinite linear combination of basis elements. In infinite-dimensional (separable) spaces, the concept of Schauder basis is a good replacement for the concept of basis...
Thanks!
There is no general algorithm for finding the basis of an infinite dimensional vector space. In this case a basis means a set of independent vectors that span the entire space by finite linear combination. That means that an arbitrary vector in the space is a linear combination of finitely many basis vectors. Since there is no algorithm one must make a postulate that allows one to conclude that there is a basis. A typical such postulate is the Axiom of Choice.
If there is a metric then one can talk about infinite linear combinations of basis vectors that converge to an arbitrary vector in the space. The classic examples are L^2 normed function spaces. This is a different idea of basis.
It is an eye of the beholder thing. e.g. with the well-ordering theorem* in hand, the algorithm quoted in the opening post can be continued transfinitely to produce a basis. I wouldn't call it highly unconstructive, but I know opinion differs on such points.
*: For the OP, the well-ordering theorem is equivalent to the axiom of choice and to Zorn's lemma
More correctly, Zorn's Lemma shows that every vector space has a basis but isn't really needed for finite dimensional vector spaces. Did you mean to say "infinite dimensional"?
alemsalem, the definition of "finite dimensional" is that the space can be spanned by some finite set of vectors. So any "unspannable space" would be infinite dimensional.
Yes, there do exist spaces with uncountable bases. "What happens"? You avoid them like the plague!
every vector space spans itself, so strictly speaking "unspannable spaces" (with no mention of independence) do not exist.
Absolutely true. But since alemsalem said "If you have a vector space you can find a set of elements and consider their span, and then look for elements that cannot be spanned by them and so add them to the set, if you can't add anymore then you have a basis." I assumed he was referring to spanning by a finite set.
yes indeed halls, your answer was more useful whereas mine was just picky. but that's my strong suit!
1. What is an un-spannable vector space?
An un-spannable vector space is a vector space that cannot be spanned by any finite set of vectors. This means that there is no way to express all vectors in the space as a linear combination of a given set of vectors.
2. How is an un-spannable vector space different from a spannable vector space?
An un-spannable vector space differs from a spannable vector space in that it cannot be fully described or represented by a finite set of vectors. In a spannable vector space, all vectors can be expressed as a linear combination of a set of basis vectors.
3. What are some real-world examples of un-spannable vector spaces?
One example of an un-spannable vector space is the space of continuous functions. In this space, there are infinitely many functions that cannot be expressed as a linear combination of a finite set of basis functions. Another example is the space of irrational numbers, where no finite set of numbers can span the entire space.
4. How are un-spannable vector spaces used in mathematics and science?
Un-spannable vector spaces are used in advanced mathematics and science to study and understand complex systems that cannot be fully described by a finite set of parameters. They are also used in areas such as functional analysis, topology, and quantum mechanics.
5. Can an un-spannable vector space be transformed into a spannable vector space?
In some cases, an un-spannable vector space can be transformed into a spannable vector space through the use of techniques such as dimensionality reduction or basis expansion. However, this transformation may not always be possible or practical, and the resulting spannable space may still not fully represent the original un-spannable space.
  • Linear and Abstract Algebra
