- #71
- 12,288
- 3,473
Here is your error. Only the L of the entire system must be constant. The L of the astronaut doesn't have to be constant.Andrew Mason said:L = constant
We are talking about the force ON the floor (the reactive centrifugal force), so of course it disappears if the floor completely dissolves. The deformation of the floor is in the outward direction which requires a force on the floor in the outward direction*. This force is the reactive centrifugal force.Andrew Mason said:? The reaction force completely disappears if the centripetal force disappears, which is what happens when the floor completely dissolves. So how can the reaction force cause the outward motion?
You are taking one specific case and making an incorrect generalization. In this case, we are dealing with a massive space station, not a hula hoop. The ω of the space station is nearly independent of the astronaut's r, even in the absence of an external torque. Thus, the formula I posted (F=mω²r) is the correct one for this situation. The centripetal force increases with increasing r.Andrew Mason said:I know it seems counter-intuitive, but with no external torque the centripetal force decreases as r increases.
Again, you are taking one specific case and making an incorrect generalization. In this case, we are not dealing with gravity and a 1/r² force, we are dealing with material deformation which essentially follows Hooke's law (a force proportional to Δr) up to the point where you start getting plastic deformation (a force independent of r).Andrew Mason said:We see this from the fact that gravity, which supplies the centripetal force for orbiting bodies, varies as 1/r^2.
The space station would have to apply a torque to the astronaut to increase his angular momentum effectively maintaining the astronaut's angular speed. So the space station would have to have a large moment of inertia compared to the astronaut: Iss >> R^2Mast. In that case you are right.A.T. said:Here is your error. Only the L of the entire system must be constant. The L of the astronaut doesn't have to be constant.
So you seem to be saying that the reason the astronaut makes the dent is, at least in part, because of his inertia. This would be shown by the dent itself. If the dent is not a perfectly radial dent then it has to be caused by inertia. I say the dent will be on an angle, indicating that with the momentary loss of force of the floor the astronaut simply continued moving in a straight tangential line until the solid part of the floor moved in and deflected him.DaleSpam said:We are talking about the force ON the floor (the reactive centrifugal force), so of course it disappears if the floor completely dissolves. The deformation of the floor is in the outward direction which requires a force on the floor in the outward direction*. This force is the reactive centrifugal force.
*EDIT: actually, on further thought I realized that I am making an incorrect generalization from statics. What is required is a shear stress in the radial direction and/or a tension in the circumferential direction. In this specific case the stress is caused, in part, by the reactive centrifugal force, but it is not a general requirement.
No, that is not what I am saying at all. A dent forms due to stresses in the material. In dynamics there can be stresses due to the floor's own inertia, but any stresses attributable to the astronaut will be through the reaction force.Andrew Mason said:So you seem to be saying that the reason the astronaut makes the dent is, at least in part, because of his inertia.
How do you propose that the astronaut's inertia will cause stress in the material? Please provide a reference to support the claim.Andrew Mason said:This would be shown by the dent itself. If the dent is not a perfectly radial dent then it has to be caused by inertia. I say the dent will be on an angle, indicating that with the momentary loss of force of the floor the astronaut simply continued moving in a straight tangential line until the solid part of the floor moved in and deflected him.
Thank you!Andrew Mason said:Actually, I should have said that Fc is proportional to 1/r^3, if angular momentum is conserved: Fc = L^2/mr^3. But your point is well taken: with a massive space station where Iss >> r^2Mast the angular speed would not decrease significantly with the astronaut's increase in r. So, AFTER the Astronaut's feet again reached a solid floor the centripetal force would be greater by a factor of Δr/r because ω does not change.
No. When the astronaut is co-rotating the reaction force is purely centrifugal, but if the astronaut is not co-rotating then the reaction force may have some tangential component as well (think about the Coriolis force in the rotating frame). Any deformation of the material due to the Astronaut will always be via the reaction force, whether that is purely centrifugal or otherwise.Andrew Mason said:Let's say there are 2 floors, the inner one being 10 cm thick and made of material that will turn to jello 1 cm at a time when someone presses a switch. Each time the astronaut completes a circle, someone presses the switch. What you will end up with is a series of dents in the jello moving at an angle opposite to the direction of rotation. Each time the floor turns to jello, the Astronaut keeps moving on a tangent until the next non-jello layer moves inward 1 cm to stop him. If it was the centrifugal reaction force that caused the dents, the dents would be completely radial would they not?
Acceleration of the centre of mass is a function of the net force, not of an individual force provided by something. An individual force has a point of attack, which together with its direction determines if it is centrifugal or centripetal. The net force doesn't have a physical point of attack, but can be thought of as acting on the center of mass. Therefore you can have one individual centrifugal force acting, and yet a centripetal acceleration of the center of mass.Andrew Mason said:The question is: what provides the centripetal force that causes the centre of mass of the space station to rotate about the geometric centre?
Read post #69.Andrew Mason said:So you seem to be saying that the reason the astronaut makes the dent is, at least in part, because of his inertia.
It seems to be about labeling and the problem that: You can have an individual force acting outwards and inward acceleration of the CoM of some arbitrarily chosen part of the system. But at the same time that outwards force can have real, physical outwards effects, like outwards acceleration/deformation of some other arbitrarily chosen part of the system.DaleSpam said:In A.T.'s drawing below, do you disagree about the existence of any of the forces, or is your disagreement entirely about the labeling?
A dent signifies that there has been movement. If the dent is due to a force overcoming stress, the motion results from that force exceeding the stress momentarily. That can never happen here. My point in using the jello was to eliminate the force and the stress and show that there would be a dent in the jello that essentially traces the inertial path of the astronaut.DaleSpam said:No, that is not what I am saying at all. A dent forms due to stresses in the material. In dynamics there can be stresses due to the floor's own inertia, but any stresses attributable to the astronaut will be through the reaction force.
Ok. Then you are saying that the reaction force causes centripetal acceleration but you still want to call it a centrifugal force. The centripetal acceleration multiplied by the mass of the spacestation is equal and opposite to the centripetal acceleration x the mass of the astronaut. So the astronaut's centripetal force and its reaction force are both "net" forces.A.T. said:Acceleration of the centre of mass is a function of the net force, not of an individual force provided by something. An individual force has a point of attack, which together with its direction determines if it is centrifugal or centripetal. The net force doesn't have a physical point of attack, but can be thought of as acting on the center of mass. Therefore you can have one individual centrifugal force acting, and yet a centripetal acceleration of the center of mass.
Read post #76. Learn to distinguish between an individual force and the net force.Andrew Mason said:We just disagree on what that reaction force does...it accelerates the space station ...
No. Read it again.Andrew Mason said:Ok. Then you are saying that the reaction force causes centripetal acceleration ...
Sure, Newton's 2nd law.Andrew Mason said:A dent signifies that there has been movement. If the dent is due to a force overcoming stress, the motion results from that force exceeding the stress momentarily.
Why not?Andrew Mason said:That can never happen here.
Even in jello there is a reaction force. Jello has a very low yield strength, so the force will be small, but it is still that reaction force which causes the deformation of the Jello. By using jello you have made the reaction force small (not zero), but you have also made it particularly sensitive to the force.Andrew Mason said:My point in using the jello was to eliminate the force and the stress and show that there would be a dent in the jello that essentially traces the inertial path of the astronaut.
OK. That force that we both agree exists is called the "centrifugal reaction force". It is how that term is defined. You may not like the name, and you may have excellent reasons for disliking the terminology (e.g. for extended bodies a centrifugal reaction force can cause centripetal acceleration), but nevertheless that is the standard terminology.Andrew Mason said:Our disagreement is not that there is a force between the astronaut and the space station. We don't disagree on its direction either.
I don't disagree about the acceleration which falls under Newton's 2nd law (although in A.T.'s example the space station's COM is not accelerating).Andrew Mason said:We just disagree on what that reaction force does. You say it is just a force that results in centrifugal tension in the space station. I say that it actually accelerates the space station in the direction opposite to the direction that the astronaut is accelerating. In other words, it accelerates the space station toward the centre of rotation.
Unless you include the other astronaut in the space station. So it depends on an arbitrary definition of objects, what the "effect" on an object's COM might be. That's why it is not a good idea to base a general naming on some object’s COM acceleration. The logic behind the centrifugal-name does not depend on how you cut the system into pieces.DaleSpam said:(although in A.T.'s example the space station's COM is not accelerating).
You have quoted only part of what I said. The "net" force IS ALWAYS the mass x its acceleration. The astronaut's entire reaction force is equal and opposite to its mass x its acceleration and that is exactly equal to the mass x acceleration of the space station. It is by its very nature a "net" force.A.T. said:No. Read it again.
No, it is not the same. They have a different point of attack. See post #76.Andrew Mason said:The astronaut's entire reaction force is equal and opposite to its mass x its acceleration and that is exactly equal to the mass x acceleration of the space station. It is by its very nature a "net" force.
I don't see the significance of the point of attack.A.T. said:No, it is not the same. They have a different point of attack. See post #76.
It's a naming convention, not a matter of great significance. See post #85 for my reasons to prefer the common convention over yours.Andrew Mason said:I don't see the significance of the point of attack.
This is not generally true. If you take two parts which are near each other or two parts which are opposite but not equally massive then their change in momentum may not be equal and opposite.Andrew Mason said:The sum of the mass x (centripetal) acceleration of each of the two parts = 0.
This is true if you consider the opposite astronaut to be part of the space station (which is valid). In that case the centrifugal reaction force applied by the right astronaut to the space station is indeed equal to the mass x centripetal acceleration of the "space station & left astronaut".Andrew Mason said:5. Since the force applied by the space station to the astronaut = the mass x the (centripetal) acceleration of the astronaut, the equal and opposite force applied by the astronaut to the space station = the mass x (centripetal) acceleration of the rest of the space station = sum of all the forces acting on all the parts of the rest of the space station.
Since the extended body aspect seems to be a reason for confusion, I propose to use an even simpler example:DaleSpam said:for extended bodies a centrifugal reaction force can cause centripetal acceleration
I think that we should go ahead with the current example in your drawing. Andrew Mason has a valid point that in certain perfectly legitimate analyses of perfectly reasonable circumstances the centrifugal reaction force can cause centripetal acceleration.A.T. said:Since the extended body aspect seems to be a reason for confusion, I propose to use an even simpler example:
A spaceship is moving on a circular path, by firing its engines continuously to provide the centripetal acceleration. The astronaut inside the ship exerts a reactive centrifugal force on the ship's wall.
The ONLY effect that the centripetal force applied by a part of a rotating free body can have on the COM of the rest of the body is a centripetal acceleration of that COM. There is no other possible effect. It does not matter how you cut it or how the force is applied. There can NEVER be a centrifugal acceleration of the other part or ANY part of that other part.A.T. said:Unless you include the other astronaut in the space station. So it depends on an arbitrary definition of objects, what the "effect" on an object's COM might be. That's why it is not a good idea to base a general naming on some object’s COM acceleration. The logic behind the centrifugal-name does not depend on how you cut the system into pieces.
In any rigid body there are, by definition, static tension forces everywhere. We don't concern ourselves with those forces. We cannot possibly know what those forces are doing at any moment because they operate at atomic levels and the atoms are constantly undergoing thermal motion. We can only look at the forces that cause acceleration.And if more forces are acting, it is even more difficult to attribute a particular effect, to a certain force. That's why it is not a good idea to base the naming on effects in general. The logic behind the centrifugal-name does not depend on other forces, and what effects they might cause together.
Whose "naming convention"? Give me a cite. No physics text that I have ever read refers to "centrifugal reaction force". The only book that I have found that references it is Mook and Vargish "Inside Relativity" (1987):A.T. said:It's a naming convention, not a matter of great significance. See post #85 for my reasons to prefer the common convention over yours.
I think it is beaten to death. Everyone agrees what happens there. The disagreement about the naming convention (by force direction or by force effect) cannot be resolved. It is a matter of personal preference.DaleSpam said:I think that we should go ahead with the current example in your drawing.
Yes. It doesn't depend on how you define the objects. It doesn't depend on other forces that are eventually contributing to the acceleration. It is local and doesn't force you to analyze the acceleration of a larger part. It is more general and practical.DaleSpam said:The naming convention refers to its direction, and not to its effects.
It does. The COM of the space station doesn't accelerate, if you treat it as 3 objects. And your convention depends on this acceleration.Andrew Mason said:It does not matter how you cut it
What is "in the body" and what is an external force depends on how you cut it.Andrew Mason said:In any rigid body there are, by definition, static tension forces everywhere. We don't concern ourselves with those forces.
Acceleration of what? Where the COMs are, and how they accelerate, depends on how you cut it.Andrew Mason said:We can only look at the forces that cause acceleration.
Don't look at me. I call my forces: F1, F2... But if I had to choose, I would prefer this simple convention, over your effect reasoning.Andrew Mason said:Whose "naming convention"?
You are back to page one of the previous thread. Here the differences between FCF and RCF again:Andrew Mason said:There is absolutely no difference between this "reactive centrifugal force" ("rcf") and the "fictitous centrifugal force" ("fcf").
I should have made it clear that I was referring to any arbitrary division of the space station and contents into two parts.DaleSpam said:This is not generally true. If you take two parts which are near each other or two parts which are opposite but not equally massive then their change in momentum may not be equal and opposite.
I was referring to the space station with one astronaut - eg. the single astronaut lying on the "floor" as described in my post #73. In this case there is just the space station itself whose centre of mass is not the centre of rotation (the centre of rotation being the geometric centre).This is true if you consider the opposite astronaut to be part of the space station (which is valid). In that case the centrifugal reaction force applied by the right astronaut to the space station is indeed equal to the mass x centripetal acceleration of the "space station & left astronaut".
The statement is not true if you consider the opposite astronaut not to be part of the space station (which is also valid). In that case the centrifugal reaction force applied by the right astronaut to the spact station is not equal to the mass x centripetal acceleration of the space station.
Perhaps you could provide a cite for where this term is used - please do not cite Mook and Vargish, Inside Relativity.DaleSpam said:The point remains that whenever a centripetal force has a 3rd law pair which is directed away from the center of rotation that force is called the "centrifugal reaction force". That is the definition of the term and it is a common enough term that people should know what it means.
A cite would be helpful.In some cases the centrifugal reaction force causes only centrifugal effects (material stresses, accelerations, etc.), but sometimes it causes centripetal effects. The naming convention refers to its direction, and not to its effects. Andrew Mason has every justification to dislike the naming convention (I dislike it for a different reason), but nevertheless it is well defined and well established.
So you demand the we:Andrew Mason said:I should have made it clear that I was referring to any arbitrary division of the space station and contents into two parts.
Andrew Mason said:Can you give us an example of how an the centrifugal reaction force cause anything to undergo centrifugal acceleration?
OK, under that restriction your statement is true, but no longer general. In fact, even requiring the system to be isolated makes it not general.Andrew Mason said:I should have made it clear that I was referring to any arbitrary division of the space station and contents into two parts.
Yes. Note however that the reaction force is applied to the space station and not the other astronaut. The 3rd law pair is the force on the astronaut from the floor and the force on the space station floor from the astronaut, not the forces on the two astronauts.Andrew Mason said:In the symmetrical station with 2 identical astronauts opposite each other, the reaction force applied by the right astronaut would be equal to the mass x centripetal acceleration of the other astronaut [+ 0 (which is the total centripetal acceleration of just the space station)].
Nonsense. The whole subject of statics is concerned with these forces. We know a great deal about them, and we can easily use strain gauges to know what they are doing at any moment even when there is no acceleration (i.e. constant strain).Andrew Mason said:In any rigid body there are, by definition, static tension forces everywhere. We don't concern ourselves with those forces. We cannot possibly know what those forces are doing at any moment because they operate at atomic levels and the atoms are constantly undergoing thermal motion. We can only look at the forces that cause acceleration.
You are completely misreading their statement. It is clearly not the same as the fictitious centrifugal force.Andrew Mason said:Whose "naming convention"? Give me a cite. No physics text that I have ever read refers to "centrifugal reaction force". The only book that I have found that references it is Mook and Vargish "Inside Relativity" (1987):
"As a result of the force acting on the ball, the ball deviates from uniform motion and follows a circular path, just as the planet docs when acted upon by the sun's gravity, But by Newton's third law, if you exert a force on the ball, the ball must exert an equal and opposite force on your hand, and it does. You feel this force as the " tug" of the ball on the string you hold. It is not necessary to posit a centrifugal force. What is sometimes called a "centrifugal force" is a reflection of the force you are exerting on the ball to keep it in a circular path. Similarly, the sun will feel such a reactive, centrifugal force from each of the planets that it holds in an orbit by its force of gravity."
There is absolutely no difference between this "reactive centrifugal force" ("rcf") and the "fictitous centrifugal force" ("fcf"). The rcf/fcf is the outward pull on the other end of the system (person) which is created to explain the fact that the guy is pulling the ball but the ball does not appear to be accelerating it toward him. The reaction to that fictitious force - the pull of the guy on the ball - is real. In actual fact, both bodies are accelerating about a common centre of rotation and there is no outward force.
Sure:Andrew Mason said:Perhaps you could provide a cite for where this term is used - please do not cite Mook and Vargish, Inside Relativity.
A.T. recently proposed an example with a rocket, the centrifugal reaction force of the engine on the exhaust causes centrifugal acceleration of the exhaust. I also previously proposed an example with rapidly cutting bolts on a section of the floor. I am sure other similar examples could be constructed. I don't know if you want to count your dent formation examples since in those cases the acceleration is only centrifugal in the rotating frame.Andrew Mason said:Can you give us an example of how an the centrifugal reaction force cause anything to undergo centrifugal acceleration? I don't see that.
Strain gauges do not measure the actual static forces between the molecules of the body. They measure the response of the material to an applied external force. For a steel beam floating in space the strain gauge would measure 0 strain. But we know that there are enormous forces holding the steel molecules together.DaleSpam said:Nonsense. The whole subject of statics is concerned with these forces. We know a great deal about them, and we can easily use strain gauges to know what they are doing at any moment even when there is no acceleration (i.e. constant strain).
Not only is it not "clearly" not the same as the fictitious centrifugal force, there is no clarity at all to the entire explanation of what "centrifugal force" means.You are completely misreading their statement. It is clearly not the same as the fictitious centrifugal force.
That is true in this case. You have been given other examples, where the force is centrifugal in an inertial frame of reference.Andrew Mason said:The pull of the Earth on the sun is NOT centrifugal in an inertial frame of reference.
No, that is nonsense in any case. A fictitious force is never part of a 3rd law pair.Andrew Mason said:That is the fictitious centrifugal force.
Are you talking about quantum mechanics here? I don't think that is relevant to the discussion which is essentially classical.Andrew Mason said:Strain gauges do not measure the actual static forces between the molecules of the body. They measure the response of the material to an applied external force. For a steel beam floating in space the strain gauge would measure 0 strain. But we know that there are enormous forces holding the steel molecules together.
And my point is that this is not generally true. Often you cannot assume perfect rigidity and often you will want to analyze the internal stresses of a rotating body, for instance, in turbine blade design. These internal stresses are well-characterized and understood despite your unsupported assertions to the contrary. I can provide a list of references for this if you wish, essentially any statics textbook, but it is simply not true that we can only know about forces which cause accelerations.Andrew Mason said:My point was that when analysing the physics of the rotating rigid body, we assume it is rigid and able to remain perfectly rigid as it rotates. We don't have to be concerned with the static forces within the body to analyse the physics of rotation.
Point well taken. "Clearly" is a matter of opinion. I should have said that it was clear to me, at least the part about the ball. I agree that the gravity example is wrong, but the ball example is correct and clear.Andrew Mason said:Not only is it not "clearly" not the same as the fictitious centrifugal force, there is no clarity at all to the entire explanation of what "centrifugal force" means.
A human is an extended body, even if the center of rotation is between the COM of the human and the COM of the ball the reaction force on the hand will still be centrifugal. At least, that is how it has been any time I have swung a ball (or any other object) using my hand.Andrew Mason said:As far as the swinging ball is concerned, the authors do no talk about the force of the ball on the rope. They talk about the force of the ball on the person. For a person to be swinging a ball the person has to rotate about the common centre of mass. For a small ball it may be hard to see this. But look at how an Olympic hammer thrower has to lean backward as he swings the hammer ball. The centre of rotation is between the thrower and the ball and both rotate around it.
DaleSpam said:Sure:
http://en.wikipedia.org/wiki/Reactive_centrifugal_force
http://en.wikipedia.org/wiki/Centrifugal_force#Reactive_centrifugal_force
http://physnet.org/modules/pdf_modules/m17.pdf
http://books.google.com/books?id=Qn...Ag#v=onepage&q="reactive centrifugal"&f=false
http://books.google.com/books?id=4G...AA#v=onepage&q="centrifugal reaction"&f=false
http://books.google.com/books?id=eF...nepage&q="reactive centrifugal force"&f=false
http://books.google.com/books?id=tv...BQ#v=onepage&q="centrifugal reaction"&f=false
http://books.google.com/books?id=xv...Bw#v=onepage&q="centrifugal reaction"&f=false
These are both good examples of why these do NOT cause centrifugal acceleration. We have discussed the bolt cutting example and all the bolt cutting does is STOP centripetal acceleration. It does not cause any acceleration away from the centre. The centres of mass of the astronaut and the spaceship both move at constant velocity in relation to an inertial point (although both would still rotate about their respective centres of mass).A.T. recently proposed an example with a rocket, the centrifugal reaction force of the engine on the exhaust causes centrifugal acceleration of the exhaust. I also previously proposed an example with rapidly cutting bolts on a section of the floor. I am sure other similar examples could be constructed. I don't know if you want to count your dent formation examples since in those cases the acceleration is only centrifugal in the rotating frame.
Also, in all cases the centrifugal force causes the object on which it is exerted to have less centripetal acceleration than if the centripetal force were unopposed. That in itself is a centrifugal effect although not centrifugal acceleration.
