Electric potential distribution in a volume of varying conductivity
In summary: If you vary the measuring point along the y-axis, you will get a vector V(x,y) that is not a function of x only.
eman3
Hey,
Assume I have a very large tank of some liquid with uniform but medium conductivity.
I now insert two fine wires into the tank some distance (D) apart, and create an electrical potential difference between them (V).
1) If I were to take my voltmeter (input impedance very high, so we assume it draws no current itself), with its two fine-tipped probes fairly close together (<<0.1 * D), what would the voltage readings look like in different parts of the tank?
2) Now, let's say I drop a flat bar of metal (much more conductive than the liquid) somewhere in the tank between the original probes. How does it affect the voltmeter readings from 1) if the bar is very short? If the bar is long enough to occupy some significant fraction of D?
You can calculate the potential distribution by solving Poisson's equation in the tank and fixing the potential at the metal wires. Without the metal bar, you get a nice, analytic solution, and you can calculate the potential everywhere. The voltage depends on the positions of the probes.
With the metal bar, it is more complicated, and I think a numeric simulation of the system would be the easiest way, unless the bar follows some area of constant potential or has some other special positions. If it is very short, it might be negligible.
Thanks. Having failed DiffEq twice when I took that class, is there e.g an online tool that will generate a nice graphic showing how the solution looks?
I don't need a precise solution, just an order of magnitude estimation...
If your system is two-dimensional (or does not have significant variations in the third dimension) and the wires are identical, the potential V(x) should be approximately [tex]V(x) = c\, \left( ln(|x-x_1|) - ln(|x-x_2|)\right)[/tex] where x1 and x2 are the positions of the wires and c is chosen to get the correct potential at the wire surfaces. You will need the diameter of them. The approximation assumes that the wire diameter is << D.
Excel can produce nice color gradients, and I don't know any online tools.
mfb -- thanks, but I'm looking to figure out V(x,y). Your equation gives me an idea of what voltage measurement I might get as I vary the measuring point along the x-axis (assumed to be a straight line between the two wire probes). But what happens if I vary the measuring point along the y-axis as well?
x has two components in my equation. [itex]|\vec{x}-\vec{x_1}|[/itex] is a short version for [itex]\sqrt{(x-x_1)^2+(y-y_1)^2}[/itex] and I dropped the vector arrows. That was a bit sloppy.
1. What is electric potential distribution?
Electric potential distribution refers to the variation in electric potential throughout a given volume or space. It is a measure of the electric field strength at different points within the volume.
2. How is electric potential distribution affected by varying conductivity?
The conductivity of a material determines how easily electric current can flow through it. In a volume with varying conductivity, the electric potential distribution will also vary, as the electric field strength will be different at different points depending on the conductivity of the material at that point.
3. What factors can influence the electric potential distribution in a volume of varying conductivity?
Aside from conductivity, other factors that can influence the electric potential distribution in a volume include the presence of external electric fields, the geometry and shape of the volume, and any boundary conditions that may be present.
4. How is electric potential distribution measured or calculated?
Electric potential distribution can be measured using specialized instruments such as voltmeters or multimeters. It can also be calculated using mathematical equations, such as Gauss's law, which relates the electric field to the charge density within a given volume.
5. Why is understanding electric potential distribution important?
Understanding electric potential distribution is important in many fields, including electrical engineering, physics, and materials science. It allows us to predict and control the behavior of electric currents and to design and optimize electronic devices and systems.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
