Connected vs. Path Connected Sets
  • Thread starter lmedin02
  • Tags
    Path Sets
In summary, a set S is connected if it is not disconnected, and a set is disconnected if it can be written as the union of two mutually separated sets. A set S is path connected if any two points in S can be joined by a chain of line segments contained in S which are joined end to end. This definition may differ from the standard definition of path connectedness, which requires the use of a continuous function. The topologist's sine curve is a common example of a connected but not path connected set. The concept of mutually separated sets is different from disjoint sets, as shown by the example of (-infty, 0] and (0,infty).
lmedin02
56
In general, if S is a connected set, can I conclude that S must be path connected?
Definition 1: S is connected if it is not disconnected. A set S is disconnected if it can be written as the union of two mutually separated sets, where mutually separated sets are two nonempty sets that do not contain any of each others boundary points.
Definition 2: S is path (or polygon) connected if any two points in S can be joined by a chain of line segments contain in S which abut (joined end to end), starting from one point and ending at the other.
Those definitions seem somewhat non-standard (especially 2). What is a line segment? If it has the elementary meaning consider the unitcircle [itex]\{(x,y) | x^2+y^2 =1\}[/itex] which doesn't seem to be path connected according to your definition 2 (but is path connected according to the standard definition of path connectedness which says that points can be joined by a continuous function [itex][0,1]\to S[/itex]).
A standard example for the normal definitions is the http://mathworld.wolfram.com/TopologistsSineCurve.html" .
Here's a cute problem connected with the "topologist's sine curve" that rasmhop refers to:
Find two set, P and Q satisfying:
1) Both P and Q are contained in the closed square in R2 with vertices (1, 1), (-1, 1), (-1, -1), and (1, -1).
2) P contains the diagonally opposite points (-1, -1) and (1, 1) and Q contains the diagonally opposite points (-1, 1) and (1, -1).
3) P and Q are disjoint.
4) P and Q are both connected sets.
The solution involves using the "topologist's sine function" to construct two connected but NOT path connected sets that satisfy these conditions.
By the way, if a set is path connected, then it is connected. If a set is either open or closed and connected, then it is path connected. But there exist sets, neither open nor closed, that are connected but not path connected so "path connected" is a stronger condition than just "connected".
I was trying to understand the topologists sine curve and see how this forms a connected set, but I am having a difficult time.
First the function sin(1/x) has an essential singularity at x=0, thus it cannot be extended to a continuous function in a neighborhood of the origin.
How can I convince myself that the topologists sine curve forms a connected set?
Intuitively this set looks disjoint in a neighborhood of the origin.
If it was disconnected you could find a separation A, B of it. Let A be the component containing (0,0). Clearly the ray y=0,x<=0 is connected so it must be in A. The graph of (x,sin(1/x)) for x>0 is also connected and so it must be B (since if it were in A, B would be empty). Now define a sequence,
[tex]a_n = (1/(n\pi),\sin(n\pi)) = (1/(n\pi),0)[/tex]
This sequence is in B, but converges to (0,0) so (0,0) can't be in A (since A is open and disjoint from B).
Ok, I think I'm getting somewhere. I followed your argument and define A as you stated. From B we can see that the origin is a boundary point of B contained in A. From the definition then A and B are not mutually separated. What confuses me is that A and B are disjoint, hence giving me an intuitive idea that A and B must be mutually separated; in other words, if two sets are disjoint they are not necessarily mutually separated.
Also, I do not agree with A being open. It looks like a half open interval; it is closed at the origin.
Sorry about stating that A is open. I switched back to an alternative definition of a separation that says that A and B are disjoint and both open which is equivalent to your definition. Anyway you don't need it by the argument you presented as you show that the limit of the sequence is in A and therefore a boundary point of B.
Also yes mutually separated and disjoint are different. Consider for instance (-infty,0], (0,infty) which are two disjoint subsets of the real line, but they are not mutually separated since 0 is in the first interval and a boundary point of the second.
1. What is the difference between connected and path connected sets?
Connected sets are sets where every pair of points can be connected by a continuous curve within the set. Path connected sets are sets where every pair of points can be connected by a continuous path within the set. Essentially, connected sets are subsets of path connected sets, but not all path connected sets are connected.
2. Can a set be connected but not path connected?
Yes, a set can be connected but not path connected. This means that there exists a continuous curve between any two points in the set, but not necessarily a continuous path. An example of this is the topologist's sine curve, where the set is connected but not path connected.
3. Why is the concept of connectedness important in mathematics?
The concept of connectedness is important in mathematics because it helps to define the structure and properties of sets. It is also used in various mathematical proofs and theorems. For example, the Intermediate Value Theorem uses the concept of connectedness to prove the existence of roots for continuous functions.
4. How do you determine if a set is path connected?
To determine if a set is path connected, you need to show that there exists a continuous path between any two points in the set. This can be done by explicitly constructing a path or by showing that the set is a continuous image of a connected set (such as an interval).
5. Are there any real-life applications of connected and path connected sets?
Yes, there are many real-life applications of connected and path connected sets, particularly in the field of topology. For example, in physics, the concept of connected sets is used to describe the properties of space and time. In engineering, the concept of path connected sets is used in control theory to determine the stability of a system.
  • Differential Geometry
  • Precalculus Mathematics Homework Help
  • Differential Equations
  • Topology and Analysis
