How is - (gravitational) potential energy and free fall compatible?
In summary, according to the author, the gravitational potential energy of an object is negative if the object is accelerating towards a planetary body. This question has really slowed down the author's studying, and help is greatly appreciated.
FieldvForce
30
I was having a few problems with Negative gravitational potential energy, I wasn't able to put my finger on why because it worked so well with everything else I had learned.
I tried to say it made sense because in space you don't free fall, but that's not actually true, though the gravitational energy is smaller you still accelerate (just very slightly) towards a planetary body.
If Ugrav is your store of potential KE, how can it be negative even in cases when you are accelerating towards a planetary body? This question has really slowed my studying down, help would be greatly appreciated.
All that matters is the change in gravitational PE. When you fall towards a planet,
you lose PE and gain KE. (The actual value of PE at any point is arbitrary and depends on what you chose as your reference point.)
I thought about this after I asked the question but I suspected that I had made another mistakeDo you mind confirming something for me.
The equation is derived (the way I learned it) by comparing the Ugrav of two positions and then making the second position (the final one) infinitely far from the center of the planetary object, does this mean that U is only 0 when r is infinity because there is no longer a difference between the Ugrav of the initial position and the final one?
And is U (as in Ui) always negative because the final position is made the reference position even though it's in the opposite direction of the centre if the planetary object.
It's cool that this equation has its reference point choosen as it forms, though this confused me as I thought the reference point was simply the centre of the Earth given the fact that the "work done" half of the equation was formulated using the centre as the ref.
Seems like there are two reference points one where U = minus infinity (r = 0) and U = 0 (r = infinity) however Ui being equal to minus infinity only means that it is inivity less than Uf right?
So for future reference the Ugrav of two or more objects are measured on a scale of 0 to infinity i.e relative to the position of the FINAL position from the deriving equation. God help me.
Also KE, when converted from U will move the object toward the Earth in the opposite direction of the reference point, thus it has potential to do negative work relative to the reference point.
You can choose any reference point and any finite value of U at that point. Choosing U = 0 when r = infinity is convenient for orbital mechanics, finding escape velocity, etc.
A reference point if "U = infinity when r = 0" doesn't really mean anything, because you can't do any sensible arithmetic with "infinity" (well, not without using some more devious math than you probably know about yet).
On the other hand, if you are dealing with motion close to the surface of the Earth and assuming gravitational acceleration is independent of altitude, it's simpler to take U = 0 at the surface of the Earth (or any other convenient altitude). That is where the formula "mgh" comes from, of course.
Thanks for all your help.
FAQ: How is - (gravitational) potential energy and free fall compatible?
1. What is gravitational potential energy?
Gravitational potential energy is the energy an object possesses due to its position in a gravitational field. It is the energy an object has when it is lifted against the force of gravity.
2. How is gravitational potential energy calculated?
The gravitational potential energy of an object is calculated by multiplying the mass of the object by the acceleration due to gravity (9.8 m/s^2) and its height above the ground. The equation for gravitational potential energy is PE = mgh, where m is the mass of the object, g is the acceleration due to gravity, and h is the height above the ground.
3. What is free fall?
Free fall is the motion of an object under the influence of gravity, without any other forces acting upon it. In free fall, an object will accelerate towards the ground at a rate of 9.8 m/s^2.
4. How are gravitational potential energy and free fall compatible?
Gravitational potential energy and free fall are compatible because as an object falls towards the ground, its potential energy decreases and its kinetic energy (energy of motion) increases. When the object reaches the ground, all of its potential energy is converted into kinetic energy.
5. Can an object have both gravitational potential energy and kinetic energy at the same time?
Yes, an object can have both gravitational potential energy and kinetic energy at the same time. This is known as the law of conservation of energy, which states that energy cannot be created or destroyed, only transferred from one form to another. In the case of a falling object, as its potential energy decreases, its kinetic energy increases, keeping the total energy constant.
