What is a Diffeomorphism and Its Existence in Starlike Sets?
In summary: Thanks for the pointers.In summary, U can map the intervall [-pi/2,pi/2] diffeomorphically to R via x\mapsto \tan x\, and for every line in U, apply the inverse function theorem to show it is a diffeo.
losiu99
133
While reading C.C.Pugh's "Real Mathematical Analysis" I've encountered a following statement:
"A starlike set [tex]U \subset \mathbb{R}^n[/tex] contains a point [tex]p[/tex] such that the line segment from each [tex]q\in U[/tex] to [tex]p[/tex] lies in [tex]U[/tex]. It is not hard to construct a diffeomorphism from [tex]U[/tex] to [tex]\mathbb{R}^n[/tex]."
It's little embarassing, but despite my best effort, I cannot figure out how to do it.
I appreciate any help.
Thanks in advance!
[tex]
x\mapsto \tan x
[/tex]
You can apply that to every line in your star-shapped set. It's just "blowing up" the set.
Thank you for your response.
I'm still not sure about how to make it work. Assuming bounded set, we can find the "ends" of the line and treat it like ends of [-pi/2, pi/2] interval with [tex]p[/tex] as 0, and "blow" the line to infinite length.
I'm more concerned about unbounded sets, where some lines doesn't have "end".
Probably U is assumed to be open? If n=2, you can use that star shaped sets (sorry, I am used to "star shaped" instead of "starlike") are simply-connected and then use the Riemann mapping theorem from complex analysis. For general n, I think it is much harder. E.g. see here at MathOverflow, and here. I am curious to hear if Pere Callahan has an easy proof!
I don't get it. If U isn't required to be open, then I don't think it's true. And if it is open, then wouldn't the identity function satisfy this?
Yeah, see the first sentence of my post :)
Huh? Are you asserting that the identity map is a diffeo? This is obiously not true since it is isn't even bijective (unless of course U happens to be R^n itself) ... :confused:
Ohhh, stupid me, you want the image of the function to be R^n I bet...
Why map P to the origin, and then for ray originating at p approaching a point on the boundary of U, map that to a corresponding ray originating at 0 (= f(p)) approaching infinity. Apply the MVT to projections of the line segments to show it has maximal rank everywhere. Then, I think, you can use the inverse function theorem to show its a diffeo?
Then find a way to reduce the general problem to the bounded problem.
It might be worth making sure your method really doesn't work in this case first...
Maybe you can first shrink every direction by applying an arctan function to get something bounded. It should even be possible to contract everything to a ball around the center of the star. Then expand it again. This would certainly (at least I think so:smile:) be a bijection. I don't know if there are exotic cases where this function would not be a diffeomorphism.
Thank you very much for your responses. At the first glance it looks like the links contain everything I need. I shall think about concracting-expanding idea as well, since it looks promising.
Thank you all once again.
These links are indeed quite interesting. I'm often surprised about how exotic objects of low dimensional topology can be. Maybe I just know too little about it.
1. What is a diffeomorphism?
A diffeomorphism is a smooth and invertible mapping between two differentiable manifolds. In simpler terms, it is a mathematical function that preserves the structure of a space.
2. How is a diffeomorphism different from a homeomorphism?
While both diffeomorphisms and homeomorphisms are types of mathematical functions, the main difference lies in the type of space they preserve. Diffeomorphisms preserve not only the topological structure, but also the smoothness of a space, while homeomorphisms only preserve the topological structure.
3. What is the significance of diffeomorphisms in physics?
In physics, diffeomorphisms are important for understanding the symmetries of physical systems. They play a crucial role in theories such as general relativity, where they represent the invariance of physical laws under coordinate transformations.
4. Can two different manifolds have the same diffeomorphism?
No, two different manifolds cannot have the same diffeomorphism. Diffeomorphisms are unique to each pair of manifolds and are determined by the specific structure of the manifolds.
5. What are some real-world applications of diffeomorphisms?
Diffeomorphisms have various applications in fields such as computer graphics, image processing, and medical imaging. They can be used to deform and transform objects or images, allowing for efficient data manipulation and analysis.
  • Topology and Analysis
  • Calculus
  • Math Proof Training and Practice
