Can an object travelling in a straight line have angular momentum?
In summary, the conversation discusses the concept of angular momentum for an object moving in a straight line. The solution presented utilizes the conservation of angular momentum, but there is confusion about how the ball can acquire angular momentum when not moving in a curved path. It is explained that the angular momentum is not just mvr, but also includes the angle between r and v. The conversation also touches on the relationship between angular momentum and rotation, and how it can be derived using symmetries. Additionally, it is noted that the value of angular momentum depends on the origin of the coordinate system.
khoivu
I have seen solutions of many problems in which an object going in straight line has angular momentum, especially those use conservation of angular momentum. For example, a person throws a ball at a rod that is hung vertically at one end. The solution says that at the moment before the ball hits the rod, the ball's angular momentum is L=mvl. However, how can the ball acquire such angular momentum when it's not traveling in a curve path which has a fixed radius to the origin? In my understanding, when an object goes in a straight line, it can not maintain a fixed value for r with respect to the origin on its way. So the r would be changing constantly and becomes a variable. Also, as the r changes its magnitude and direction, so do the angle θ between r and v.
Can anyone help me with this question? Thanks :)
The angular momentum isn't just mvr, it's mvr sinθ, where θ is the angle between r and v. That quantity actually remains constant for an object moving in a straight line. As r increases, sinθ decreases. If you want to get a bit more technical, angular momentum is a vector quantity, and is given by L=mr×v. But the magnitude of that cross product depends on sinθ as described above.
Angular momentum isn't really jut about rotation. It's easier to understand in cases with rotation, but any kind of vector field has a moment around a fixed pivot. If you take momenta of various particles, the moment of momentum is the angular momentum. And it works out that both the total momentum and the total angular momentum are conserved quantities. In fact, you can derive one from the other using some symmetries.
Hello.
Value of angular momentum depends on where the origin of the coordinate you set.
For example the origin is on the line of straight motion, the value is zero.
However, the origin is off the line, the value is positive or negative constant.
Regards.
1. Can an object travelling in a straight line have angular momentum?
Yes, an object travelling in a straight line can have angular momentum. Angular momentum is a measure of the rotational motion of an object, and even though the object may be moving in a straight line, it can still have rotational motion around its center of mass.
2. What factors affect the angular momentum of an object travelling in a straight line?
The angular momentum of an object travelling in a straight line is affected by its mass, velocity, and distance from the axis of rotation. An increase in any of these factors will result in an increase in angular momentum.
3. Can an object have both linear and angular momentum while travelling in a straight line?
Yes, an object can have both linear and angular momentum while travelling in a straight line. Linear momentum measures the straight-line motion of an object, while angular momentum measures its rotational motion. An object can have both types of motion at the same time.
4. Why is angular momentum important in physics?
Angular momentum is important in physics because it is a conserved quantity, meaning it remains constant in a closed system. This principle is essential in understanding the behavior of rotating objects, such as planets and galaxies, and is also used in various technologies, such as gyroscopes and motors.
5. Can angular momentum of an object travelling in a straight line be zero?
Yes, the angular momentum of an object travelling in a straight line can be zero if the object is not rotating around its center of mass. In this case, the object's linear motion cancels out any rotational motion, resulting in a total angular momentum of zero.
  • Mechanics
  • Classical Physics
