Direction when the magnitude of the instantaneous velocity is 0
In summary, the questioner is wondering about the behavior of an object at the point where its maximum height is reached in a straight-up throw and its velocity becomes zero. They are confused about the direction of the velocity vector at this point and whether or not it changes from up to down. The conversation includes different perspectives and explanations, but it is ultimately concluded that the velocity's function is continuous, but not its vector, and there is no discontinuity. The direction of a zero vector is indefinite, meaning it simply doesn't have a direction because it isn't moving.
Ikari
Hi guys, sorry to ask such a basic question, but I'm studying for the MCAT and need to get my fundamentals down!
Anyway, my question is this: Consider an object which has been thrown straight up into the air. It will rise, then at the very top of its ascent, it changes direction and comes back down. Now, I'm pretty sure that at the moment when the object reaches its maximum height, the velocity becomes zero, although there must still be an acceleration (due to gravity), or else the object wouldn't fall back down again.
So, on a velocity-time graph, we would see a point where the velocity drops to zero, corresponding to the moment the object reaches its maximum height, right? Let's call this point q.
But I am confused, because, since velocity is a vector, it has a direction. In this case, the direction would be up as we approach q from the left, and down as we approach q from the right. So what would the direction of the velocity vector be, when we are actually at that point? I am tempted to say that, since the magnitude of the velocity vector is 0m/s, the object isn't actually moving in *any* direction. But if that is the case, then *when* does the direction of the object officially change from up to down?
Again, sorry to ask such a newbie question. If someone could elaborate on the behavior of the object at this point I would seriously appreciate it!
Science news on Phys.org
When its acceleration vector switches direction, which happens instantaneously. That's my ignorant guess.
Keep in mind that the velocity changes magnitude, but the acceleration is constant. The only thing it does is change its direction. The velocity magnitude gets smaller and smaller, but not the acceleration.
The acceleration never changes direction. It always points down.
A vector of zero length can point in any direction.
Vanadium is absolutely correct.A zero vector has indefinite direction
Yes, I've got it backwards. I think this is a discontinuity question that doesn't have a satisfying answer. I guess Newton would have said when you move infinitesimally to the right in your graph. But infinitesimal is not zero.
There is no discontinuity here. Position is continuous. Velocity is continuous. Acceleration is not only continuous, it's constant.
The velocity's function is continuous, but not its vector.
Crudely :
velocity: [itex]\cup[/itex]
vector: [itex]\uparrow[/itex] ∅ [itex]\downarrow[/itex]
None of this is getting at the questioner's problem. There is at least a psychological discontinuity. The velocity vector was up, then it was indefinite, then it was down.
I would say, V(t) = (x(t), y(t), z(t)) is a vector function of t that is continuous.
It will of course remain continuous if you express it in spherical coordinates.
[tex] (r(t),\phi(t),\theta(t)) [/tex]
but [itex] \phi(t) [/itex] and [itex] \theta(t) [/itex], are not continuous functions of t.
I don't see there is any problem with that.
All functions in question here are continuous and differentiable on an open interval. There is no discontinuity. You could easily plot all three and they would all be smooth curves with no discontinuities or infinities or any sort (assuming the ball hits the ground at some point). The direction of a zero vector is indefinite but not undefined. It simply doesn't have a direction because it isn't moving.
Thanks for the help everyone! So from reading everyone's comments, I'm thinking that it works like this: No matter how close you get to the left of the point in time where the velocity becomes 0, the velocity vector points up. Then at this point, the direction changes to indefinite. Then infinitely close to this point, but on the right side, the direction changes to down. I was confused for the reason that danR said, this is kind of a confusing problem because the direction of the velocity vector seems to be a discrete quality of the vector, which abruptly changes at the point where the velocity becomes 0. Think about the limits on either side of this point. From the left, the limiting values would approach 0, but with a direction of up. Whereas from the right, the limiting values approach 0, but with a direction of down. This is why I was confused!
Hi.
At time t=0 the object is at the top q where where position x = 0.
Let tau be a small positive amount of time.
t=-tau; velocity v = g tau, x= -1/2 g tau^2.
t=0; v = 0, x=0
t= tau; v = -g tau, x= -1/2 g tau^2.
I find here nothing mysterious.
Regards.
The problem is, that has nothing to do with the continuity of the problem. In school, they tell you that a vector has magnitude and direction, but there is no quantity called direction that is inherent in a vector, just the number of coordinates. You can get infinitely close to zero from below and you are still negative and then you hit zero and you aren't, but that doesn't make it discontinuous. That is essentially what happens here. It is a one dimensional problem so it can be described by one number, the velocity. It passes from a positive number straight through the origin and continues on negative. There is no discontinuity, just a straight line. It is infinitely differentiable.
Haha true enough! Thanks guys. I totally get it. Like I said, its been a while since I took a physics course!
I will concede all that. The terms 'no direction', 'any direction', 'null direction' are rather confusing to me, but if it's called '0 direction', I have something numerical to specify in a vector operation. But computer programs have failed on 'discontinuous' shifts in wind direction gusts, for example, when vectors are involved.
You could choose to define the vector's direction as always upwards, and then the vectors velocity would transition from positive to zero to negative.
I think a better way to visualize this is to visualize the vector itself. It gets smaller and smaller and smaller and eventually disappears and then gets bigger again but going down. You will see that the vector smoothly transitions from pointing up to pointing down.
1. What does it mean when the magnitude of the instantaneous velocity is 0?
When the magnitude of the instantaneous velocity is 0, it means that the object is not moving at that particular moment. The velocity is the rate of change of an object's position with respect to time, so a magnitude of 0 indicates that the object is not changing its position at that instant.
2. Can an object have 0 magnitude of instantaneous velocity and still be moving?
Yes, an object can have a 0 magnitude of instantaneous velocity and still be moving. This can happen if the object is changing its direction but not its speed, resulting in a 0 magnitude of instantaneous velocity at certain points in its motion.
3. How is the magnitude of instantaneous velocity calculated?
The magnitude of instantaneous velocity is calculated by taking the square root of the sum of the squares of the object's velocity in the x and y directions. This is represented by the equation |V| = √(Vx^2 + Vy^2).
4. What is the difference between instantaneous velocity and average velocity?
Instantaneous velocity refers to the velocity of an object at a specific moment in time, while average velocity is the average rate of change of an object's velocity over a certain period of time. Instantaneous velocity can vary greatly throughout an object's motion, while average velocity gives a more general idea of the object's overall motion.
5. How does the magnitude of instantaneous velocity affect an object's acceleration?
The magnitude of instantaneous velocity does not directly affect an object's acceleration. However, changes in the magnitude and direction of the instantaneous velocity can result in changes in the object's acceleration. Acceleration is the rate of change of an object's velocity, so if the magnitude of the instantaneous velocity is changing, the object's acceleration will also be changing.
  • Classical Physics
