Solving Limits & Integrals with L'Hopital's Rule
In summary, we discussed the limit \lim_{x\rightarrow0^+}\frac{\sqrt{x}\sin\sqrt{x}}{1-e^{-x}}, which is a 0/0 type of expression. We explored using L'Hopital's rule and a substitution method to try to solve it. We also discussed the integral \int_0^{\pi^2}\sqrt{x}\sin\sqrt{x}dx and how we could use a substitution to solve it. Finally, we touched on the limit \lim_{x\rightarrow 0} \frac{\sin(x)}{x} and how it can be used to prove the derivative of \sin x. However, we noted that relying on such
broegger
257
Hi,
I'm having trouble determining this limit:
[tex]\lim_{x\rightarrow0^+}\frac{\sqrt{x}\sin\sqrt{x}}{1-e^{-x}}[/tex]​
It's a 0/0 type of expression, so it seems like L'Hopital's rule should be applicable, but no matter how many times I differentiate I keep getting 0/0-expressions. Any hints?
Also, the next question is to solve this integral:
[tex]\int_0^{\pi^2}\sqrt{x}\sin\sqrt{x}dx[/tex]​
I haven't tried solving it, but since I haven't yet been able to answer any question in this whole damn exercise, I think it's a safe bet that I can't do this either. Any hints here? :biggrin:
For [itex]\int \sqrt{x}\sin\sqrt{x}dx[/itex]
Try a substitution: [itex]y = \sqrt x \Leftrightarrow y^2 = x \Leftrightarrow 2ydy = dx[/itex]
Which would give: [itex]2\int {y^2 \sin \left( y \right)dy} [/itex]
For the limit, if L'Hopital doesn't work, you could do it with Taylor Series.
when i take the derivitive of 1 - e^-x i get e^-x
and when x approches 0 i get 1 so shouldn't you get f'(x) / 1 while using l'hopitals rule
which is not 0 / 0
[tex]\lim_{x\rightarrow0^+}\frac{\sqrt{x}\sin(\sqrt{x})}{ 1-e^{-x}}=\lim_{x\rightarrow0^+} \ \frac{-x}{e^{-x}-1} \ \ \frac{\sin(\sqrt{x})}{\sqrt{x}}}[/tex]
Do these limits look familar? pehaps something like
[tex]\lim_{x\rightarrow 0} \frac{\sin(x)}{x}[/tex]
and
[tex]\lim_{x\rightarrow 0} \frac{e^x-1}{x}[/tex]
the derivative of 1 - e^(-x) at x = 0 is 0?
It's 1. L'Hoptial works. So does lurflurf's suggestion, which goes back to some analysis theorems about limits of products.
Thanks for answering. But I can't see how L'Hopital works, since [tex]f'(x)=\frac1{2\sqrt{x}}\sin\sqrt{x} + \frac1{2}\cos\sqrt{x}[/tex] - you can't plug in x because of the sqrt(x) in the denominator, no?
L'Hospital does work:
[tex]\lim_{x \rightarrow 0 ^ +} \frac{\sqrt{x} \sin{\sqrt{x}}}{1 - e ^ {-x}}[/tex]
[tex]= \lim_{x \rightarrow 0 ^ +} \frac{\frac{\sin{\sqrt{x}}}{2 \sqrt{x}} + \frac{\cos{\sqrt{x}}}{2}}{e ^ {-x}}[/tex]
[tex]= \frac{\frac{1}{2} + \frac{1}{2}}{1} = 1[/tex]
Due to:
[tex]\lim_{x \rightarrow 0 ^ +} \frac{\sin{\sqrt{x}}}{\sqrt{x}} = 1[/tex]
Viet Dao,
It is a limit.
What is
[tex]\lim_{x\rightarrow 0} \ \frac{\sin(x)}{x}[/tex]
I know it's a limit :D
But this is a strictly mathematical course, and I'm only supposed to use the rules in our textbook, so I can't just use rules other than these (like lim(sin(x)/x)=1, x->0). I guess, though, the way you suggest is the only possible one, so I'll do it like that anyway. Thanks!
You can also prove:
[tex]\lim_{x\rightarrow 0} \ \frac{\sin(x)}{x} = 1[/tex]
using L'Hopital rule.
[tex]\lim_{x\rightarrow 0} \ \frac{\sin(x)}{x} = \lim_{x \rightarrow 0}\cos{x} = 1[/tex]
Viet Dao,
If you have covered L'hopital's rule, then you have certainly already covered
[tex]lim_{x->0}\frac{sin x}{x}= 1[/tex]!
(And if you haven't it is certainly simple to prove it using L'hopital's rule!)
"prove it" might not be the correct choice of words..
I really hope
is in you textbook
even if it were not you should be able to show it the way you show any limit.
It seems you like the theorem that for a continuous function
[tex]\lim_{x\rightarrow a} f(x)=f(a)[/tex]
so here you go
let f(x)=sin(x)/x when x is not 0
and f(x)=1 when x is 0
then
lim(sin(x)/x), x->0=f(1)=1
also f can be written
[tex]f(x)=\int_0^1 \cos(x t) dt[/tex]
in this form it's continuity is obvious.
or if you like power series
f(x)=1-x^2/3!+x^4/5!-x^6/7!+...+(-1)^n x^(2n)/(2n+1)!+...
I know. That's why I asked the question!
Is that right to say? You're assuming the derivative of [tex]\sin x[/tex] is [tex]\cos x[/tex] to prove [tex]\lim_{x \rightarrow 0} \frac{\sin x}{x} = 1[/tex] but actually the limit (together with the AoL) is normally used to prove the derivative of [tex]\sin x[/tex]. Normally one would use the sandwich rule to find the limit.
You are assuming a specific definition of sin(x). It is possible to know sin'(x)=cos(x) without knowing lim x->0 sin(x)/x=1 and the reverse. What is important is that knowing either makes it easy to find the other. What would be bad (and some books do this) would be to try to prove one of these, then get the other as a step then say it follows from what you are trying ti prove. The "Normally" you use is of course the resolution. By normally I presume you mean "How it is done in the large number of popular calculus texts that are very much alike". We need not do things as they are done normally.
"Calculations" of this kind possesses no conclusive power.
For example:
[tex]\lim_{x\rightarrow0}\frac{e^x-1}{x}[/tex]
Differentiating the numerator and the denominator gives:
[tex]\lim_{x\rightarrow0}\frac{e^x}{1}=1[/tex]
But to know that [tex]D(e^x) = e^x[/tex] we must master [tex]\lim_{x\rightarrow0}\frac{e^x-1}{x}[/tex]
No, that doesn't follow: as lurflurf said, there are different ways of defining sine and cosine x. For example, it is perfectly valid to define y= sin x as:
The function satisfying the differential equation y"= -y with initial value conditions
y(0)= 0, y'(0)= 1.
Then define y= cos x as:
y(0)= 1, y'(0)= 0.
That isn't normally done in basic calculus books, of course, but it is more rigorous than the usual definitions of sine and cosine functions.
It is then easy to prove that (sin x)'= cos x and then use L'hopital's rule to derive [itex]lim_{x\rightarrow0}\frac{sin x}{x}= 1[/itex].
Indeed, since you mention ex, many calculus texts first define ln (x) by
[itex]ln(x)= \int_1^x \frac{1}{t}dt[/itex]. It's easy to show that that function has all the properties we expect of ln(x) including, obviously, that its derivavative is [itex]\frac{1}{x}[/itex] as well as the fact that it is a one-to-one function and so has an inverse.
If you then define exp(x) to be the inverse of ln(x) it follows easily that exp(x) is differentiable and has derivative equal to exp(x) itself. One could then use L'hopital's rule to show that [itex]lim_{x\rightarrow0}\frac{e^x-1}{x}= 1[/itex].
Once can also, by the way, prove that exp(x)= (exp(1))x.
What is L'Hopital's Rule?
L'Hopital's Rule is a mathematical technique used to evaluate limits and integrals involving indeterminate forms, such as 0/0 or ∞/∞. It states that for certain types of functions, the limit can be found by taking the derivative of the numerator and denominator separately and evaluating the limit again.
When should L'Hopital's Rule be used?
L'Hopital's Rule should be used when evaluating a limit or integral that results in an indeterminate form. This typically occurs when the limit of a function approaches 0 or infinity. Additionally, the function must be differentiable in the given interval.
What are the steps to solve a limit using L'Hopital's Rule?
The steps to solve a limit using L'Hopital's Rule are:
  1. Identify the indeterminate form of the limit.
  2. Take the derivative of the numerator and denominator separately.
  3. Evaluate the limit again with the new derivatives.
  4. If the new limit still results in an indeterminate form, repeat the process until a definite answer is reached.
Can L'Hopital's Rule be used for all limits and integrals?
No, L'Hopital's Rule can only be used for certain types of limits and integrals. It can only be applied when the limit or integral results in an indeterminate form. Additionally, the function must be differentiable in the given interval for the rule to be valid.
Are there any limitations to using L'Hopital's Rule?
Yes, there are a few limitations to using L'Hopital's Rule. It cannot be used to evaluate limits at infinity or limits involving infinity. Additionally, it may not work for more complex functions with multiple variables. It is important to check the conditions for L'Hopital's Rule before using it to solve a limit or integral.
  • Calculus
