Flame temperature when heavy fuel oil is burnt
In summary, when burning heavy fuel oil, the flame temperature can range from 1200°C to 1500°C and can be affected by factors such as the type and quality of fuel oil, oxygen availability, and burner design. The flame temperature also has a significant impact on the efficiency of a boiler, as a higher temperature can result in better combustion and increased efficiency. However, the flame temperature can be controlled through precise burner design and combustion control systems. It is important to consider safety concerns, such as the risk of fire and explosions, when operating at high flame temperatures.
wendyv007
i need to calculate the surface area of a furnace for a firetube boiler. do anyone know what is the temperature of the gas inside the furnace when Heavy fuel oil is burnt?and also what is the temperature of the furnace wall.
thank you in advance
The flame temperature when heavy fuel oil is burnt can vary depending on several factors such as the type and quality of the fuel, the air-to-fuel ratio, and the design of the furnace. However, on average, the flame temperature can reach up to 2,200-2,500 degrees Fahrenheit (1,200-1,400 degrees Celsius).
To calculate the surface area of a furnace for a firetube boiler, you will need to consider the heat transfer rate, the heat flux, and the heat transfer coefficient. These factors will help determine the required surface area for efficient heat transfer. It is recommended to consult a professional engineer or refer to the boiler manufacturer's specifications for accurate calculations.
The temperature of the gas inside the furnace when heavy fuel oil is burnt can also vary, but it is typically around 1,800-2,000 degrees Fahrenheit (980-1,100 degrees Celsius). This temperature is necessary for proper combustion of the fuel and to achieve the desired heat output.
The temperature of the furnace wall will also depend on the design and materials used. Generally, the furnace wall can reach temperatures of 1,500-1,800 degrees Fahrenheit (820-980 degrees Celsius). It is important to ensure that the materials used for the furnace wall can withstand these high temperatures to prevent damage and ensure safe operation.
I hope this information helps. It is always best to consult a professional engineer for accurate and specific calculations for your specific furnace and boiler setup.
What is the flame temperature when heavy fuel oil is burnt?
The flame temperature when heavy fuel oil is burnt can vary depending on the type of fuel oil and the combustion conditions. Generally, it ranges from 1200°C to 1500°C.
What factors can affect the flame temperature when heavy fuel oil is burnt?
The flame temperature can be affected by several factors such as the type and quality of fuel oil, the amount of oxygen available for combustion, and the design and efficiency of the burner.
How does the flame temperature when heavy fuel oil is burnt impact the efficiency of a boiler?
The flame temperature plays a crucial role in the efficiency of a boiler. A higher flame temperature can result in better combustion and increased efficiency, while a lower flame temperature can lead to incomplete combustion and decreased efficiency.
Can the flame temperature be controlled when burning heavy fuel oil?
Yes, the flame temperature can be controlled by adjusting the amount of fuel oil and oxygen supplied to the burner. This can be done through precise burner design and combustion control systems.
What are the potential safety concerns with a high flame temperature when burning heavy fuel oil?
A high flame temperature can pose safety concerns such as increased risk of fire and explosions. It is important to ensure proper ventilation and safety measures are in place when burning heavy fuel oil at high temperatures.
  • General Engineering
