Force between two permanent magnets at an angle
In summary, the conversation is about calculating the force between two permanent magnets at different positions and angles. The question is regarding the appropriate equation to use and how to obtain the values m1 and m2 described in the Wikipedia article on magnetic moments. The person is trying to build a program to understand magnetics better but is stuck at the first hurdle. There is also a discussion about whether the force is between the two magnets or one magnet and the field it's in.
Starblaiz
Hay all, first post (ohai2u! ^_^), so hope this is in the right place. I feel really stupid for having to ask this, because I'm sure the answer is really trivial, but here we go...
Ok so, imagine the scene - You have two permanent magnets on a table. Let's (for argument's sake) call these "Mag1" and "Mag2" respectively.
Now let's say that Mag1 is at position [0, 0] (x, y that is) and Mag2 is at say [5, 7].
Now let's say that Mag1 is at an angle of 0º to the x axis, and Mag2 is at 315º to the x axis. Of course these angles would be with respect to a line drawn from the south pole to the north pole of the given magnet.
Finally, let's say that all we know about the magnets are their length L in meters and their strength B in Gauss.
So simple question - what on Earth is/are the equation(s) to calculate the force between these two magnets?
Calculating the force between two magnets when their poles are face-on is simple GCSE physics, but figuring out how to do it for any position / angle / orientation of the two magnets is proving elusive to me.
The one thing I have found is this article on magnetic moments on wikipedia:
http://en.wikipedia.org/wiki/Magnetic_moment#Forces_between_two_magnetic_dipoles
The diagram there (particularly the "local co-ordinates" part) appears to be pretty much exactly what I'm describing, but I'm unsure which equation would be most appropriate (if any), and I'm unsure how to get the values m1 and m2 described there (further up it mentions that m=pl, but what is p? Is p = B? Or is there some other equation somewhere to work it out from B?)
It feels like I'm close, I just need that extra nudge to get me over the hill lol. Hoping one of you can help me out here?
In case you're curious - I've always been a bit weak on my magnetics knowledge, but I've always found them interesting, so I'm currently trying to build a program to assit me in strengthening that understanding by letting me play with values and see what happens in response. The first step obviously is getting some basic / fundamental equations into it. Lol, stuck at the first hurdle, not a good start right? :P
Not really my subject but...
Perhaps consider that the force is not "between two magnets" but one magnet and the field that it's in. So you would need to work out the field at magnet 2.
I suspect it's horribly complicated for real world magnets. Might be easier if one was very small or a wire?
Lol sorry for my poor choice of phrase there - what you describe is exactly what I am after (the force vactor acting on one of the magnets. Doesnt matter which one as assumedly an equal but opposite force would be acting on the other), in appose to the force at some point between them as I may have implied =)
What is the force between two permanent magnets at an angle?
The force between two permanent magnets at an angle is a type of magnetic force that occurs when two permanent magnets are placed near each other at an angle, rather than directly opposite each other. It is caused by the interaction of the magnetic fields of the two magnets.
How is the force between two permanent magnets at an angle calculated?
The force between two permanent magnets at an angle can be calculated using the formula F = (μ0 * m1 * m2 * cosθ)/r2, where μ0 is the permeability of free space, m1 and m2 are the magnetic moments of the two magnets, θ is the angle between the magnets, and r is the distance between them.
What factors affect the force between two permanent magnets at an angle?
The force between two permanent magnets at an angle is affected by several factors, including the strength of the magnets, the distance between them, the angle between them, and the permeability of the medium between them (such as air or water).
Can the force between two permanent magnets at an angle be repulsive?
Yes, the force between two permanent magnets at an angle can be repulsive if the magnets are oriented in a way that their magnetic fields are in opposite directions. This can occur when the magnets have opposite poles facing each other.
How can the force between two permanent magnets at an angle be used?
The force between two permanent magnets at an angle can be used in various applications, such as in motors and generators, magnetic levitation systems, and magnetic sensors. It can also be used to separate magnetic materials in industries like recycling and mining.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
9K
