Prime numbers from infinite prime number proof
In summary, there are two types of primes that come from adding or subtracting 1 from the product of the first n primes: Euclid numbers and Kummer numbers. The prime versions of these numbers do not have a special name and it is unknown if there are infinitely many of them.
jfizzix
Insights Author
355
I imagine most everyone here's familiar with the proof that there's an infinite number of primes:
If there were a largest prime
you could take the product of all prime factors
add (or take away) 1 and get another large prime (a contradiction)
So what if you search for larger primes this way?
(2,3,5,7,11,13)
(2*3) +-1 = 6 +-1 = {5,7}
(2*3*5) +-1 = 30+-1 = {29.31}
(2*3*5*7)+-1 = 210+-1 = {209,211} (209 is not prime)
(2*3*5*7*11)+-1 = 2310+-1 = {2309,2311}
(2*3*5*7*11*13)+-1 = 30030+-1={30029,30031} (30031 is not prime)
I have two questions:
Do prime numbers of this sort have a special name? (like Marsenne primes are (powers of 2) +-1?)
Are there infinitely many of them?
This was just an odd thought I had. You can keep going and find products where neither one above or one below is a prime.
Mathematics news on Phys.org
I don't know a name of primes of the form [itex]\pm1+\prod_{p\in P} p [/itex] for [itex]P[/itex] a finite set of primes.
One comment, though. I'm not sure whether primality/non-primality of numbers of the above form is that interesting ("interesting" being too subjective for my comment to make any sense :P). The argument to which you're referring generates primes like that based on a hypothesis we know to be false: namely, that [itex]P[/itex] can be chosen to be the finite set of all primes.
The products of the first n primes are called the primorials.
If you add 1 to these, you get the Euclid numbers.
If you subtract 1 instead, you get the Kummer numbers.
The prime Euclid numbers (or prime Kummer numbers) don't have special names. They are just the "prime Euclid numbers." I guess you could call them "Euclid primes" (or "Kummer primes") if you wanted to be fancy, but this is not widely-used terminology. You can find a list of the first few prime Euclid numbers on OEIS. I believe the question of whether this list goes on forever is unsolved.
As far as I know, the combined list of prime Euclid numbers and prime Kummer numbers has no name (and isn't even on OEIS as far as I can tell).
Likes 1 person
Does this mean there are infinitely many primes in between?
I find this thought experiment interesting and thought-provoking. The proof that there are infinitely many primes is a fundamental result in mathematics, and it has been studied and proven by many mathematicians throughout history. It is a powerful and elegant proof that relies on the fundamental properties of prime numbers and their relationship to each other.
To answer your questions, prime numbers of the form (product of primes) +- 1 do not have a specific name, but they are often referred to as "near-primes" or "almost-primes." These numbers have been studied extensively and have applications in cryptography and number theory.
As for your second question, it is still an open problem whether there are infinitely many near-primes. Some mathematicians believe that there are infinitely many, while others believe that there are only finitely many. This is still an active area of research and has not been proven definitively.
Your thought experiment raises an interesting question about the distribution of primes and whether there are infinitely many primes in between these near-primes. This is also an open problem in mathematics and has been studied by many mathematicians. It is a complex problem that has not been fully understood yet, but it is an exciting area of research.
In conclusion, the concept of near-primes is a fascinating one that has been studied and explored by mathematicians. Your thought experiment adds an interesting perspective to this topic and highlights the ongoing research in this area. It is a reminder that there is still much to discover and understand about the mysterious and beautiful world of prime numbers.
FAQ: Prime numbers from infinite prime number proof
1. What is the concept of infinite prime number proof?
The concept of infinite prime number proof is a mathematical theory that states there are an infinite number of prime numbers. This means that no matter how high you count, there will always be another prime number that follows.
2. How is the infinite prime number proof proven?
The infinite prime number proof is proven using a mathematical proof called Euclid's proof. This proof shows that if you assume there is a finite number of prime numbers, you can always find another prime number that is greater than the largest one assumed.
3. Are there any practical applications of the infinite prime number proof?
Yes, there are several practical applications of the infinite prime number proof. For example, it is used in cryptography to create secure encryption algorithms, and in computer science to generate random numbers.
4. Can all prime numbers be represented in a formula?
No, not all prime numbers can be represented in a formula. While there are formulas that can generate some prime numbers, there is no known formula that can generate all prime numbers.
5. Are there any unsolved questions or mysteries surrounding prime numbers and the infinite prime number proof?
Yes, there are still unsolved questions and mysteries surrounding prime numbers and the infinite prime number proof. For example, it is still unknown whether there is an infinite number of twin primes (prime numbers that are 2 apart), and whether there is a pattern or formula to predict when a number will be prime.
