Power problem, to use net force or work energy theorem?
In summary, the problem discusses a helicopter accelerating straight up from rest and the average power generated by the lifting force. There were two different methods used to solve the problem, one using the net force and the other using conservation of energy. The latter method is the correct one and it was determined that the acceleration was not constant, leading to different answers.
deblimp
A helicopter, starting from rest, accelerates straight up from the roof of a hospital. The lifting force does work in raising the helicopter. An 720-kg helicopter rises from rest to a speed of 7.5 m/s in a time of 5.0 s. During this time it climbs to a height of 7.9 m. What is the average power generated by the lifting force?
Gpe=mgh KE=1/2MV^2
Ok so we had a test today and afterwards we were discussing how to do one of the problems. Me and a classmate had two different ways to do this problem. He determined the net force acting on the helicopter by calculating the average acceleration and from there using the equation W=Fcos*X. I used conservation of energy to determine that the total energy in the problem using Gpe=mgh KE=1/2MV^2. From there we both divided by time to get teh power, not the work. Using these two methods does end up with two relatively different answers, so I was wondering which is the right method to use?
Hi deblimp. Welcome to PF!
The work-energy approach should give the correct answer.
Why isn't the other method valid? Note that the formula W = F*x*cosθ requires using the force averaged over the distance x. But when you use a = Δv/Δt for the average acceleration, you get the acceleration averaged over time from which you can get the force averaged over time. But the time-average of the force doesn't necessarily equal the distance-average of the force.
For example, suppose you push a block along a frictionless surface a total distance of 2 meters such that during the first meter you push with 10 N of force and the second meter you push with 20 N of force? The distance-average of the force would clearly be 15 N. Would the time-averaged force be greater than, less than, or equal to the distance average?
While both methods should give the same result, you are looking for the average power generated by the lifting force. It appears from your wording that your classmate was using the net force to determine the net work done, then dividing the net work done by the time to get the average power. This would be incorrect. I don't know what energy equation you were using either, for that matter. You might want to show your work, and that of your classmate also, if you have it.
How did he calculate the acceleration?
Method 1 (using the height and velocity data):
V2 = U2 + 2as
a = V2/2s = 7.52/(2 *7.9) = 3.5ms-2
Method 2 (using the height and time data):
s = ut + 0.5at2
a = 2s/t2 = (2 * 7.9)/52 = 0.53ms-2
Different answers suggests the acceleration wasn't constant and that's a requirement for using these equations. He made a wrong assumption I believe.
Your approach using energy is correct.
There is no right or wrong method to use in this scenario. Both approaches, using net force or work-energy theorem, can be used to solve the problem and will yield the same answer as long as all the necessary variables and equations are used correctly. It is important to understand the concepts behind both methods and be able to apply them appropriately in different situations. In this case, using the work-energy theorem may be a more straightforward approach since it takes into account both the work done by the lifting force and the change in kinetic energy of the helicopter. However, using net force can also be a valid approach as it considers the acceleration of the helicopter and the angle at which the force is applied. It is ultimately up to the individual to choose which method they are more comfortable with and can use effectively to solve the problem.
FAQ: Power problem, to use net force or work energy theorem?
1. What is the definition of power?
Power is defined as the rate at which work is done or energy is transferred. It is measured in watts (W) and is calculated by dividing the amount of work done by the time it takes to do the work.
2. What is the difference between net force and work energy theorem?
Net force is the overall force acting on an object, taking into account all individual forces. Work energy theorem, on the other hand, states that the work done on an object is equal to the change in its kinetic energy. It does not take into account individual forces, but rather focuses on the overall change in energy.
3. When should I use net force to solve a power problem?
You should use net force when you need to calculate the overall force acting on an object. This is useful in situations where there are multiple forces acting on the object and you need to determine the resulting force.
4. When should I use work energy theorem to solve a power problem?
You should use work energy theorem when you need to calculate the work done on an object or the change in its kinetic energy. This is useful in situations where you want to determine how much energy is required to move an object or how much energy an object has after a certain amount of work is done on it.
5. Can I use both net force and work energy theorem in the same problem?
Yes, you can use both net force and work energy theorem in the same problem. They are two different approaches to solving power problems and can be used depending on the specific information and quantities given in the problem.
