Prove by definition the statement lim x->4 √x = 2
  • Thread starter roam
  • Tags
    Definition
In summary, Prove by definition the statement lim x->4 √x = 2Given ε>0, if x-4<ε^2 then x-2<√ε^2. This follows from the fact that if x-4<ε^2, then x-2<√ε^2<ε^2. So by definition, lim x->4 √x = 2.
roam
1,271
lim x->4 √x = 2
This is what I've done:
Given ε>0
|(√x)-2| = |√x-2|< ε if |x-4|< ε^2
I choose δ = ε^2
0<|x-4|< ε^2
=> |x-2|< √ε^2 = ε
Hence lim x->4 √x = 2
So, what do you think? Did I do the process correctly?
Well what you actually need to prove is that
[tex]\forall\epsilon>0,\exists\delta(\epsilon)>0[/tex] such that whenever
[tex]0<|x-4|<\delta=>|\sqrt{x}-2|<\epsilon \ \ ??[/tex]
[tex]\lim_{x\rightarrow 4}\sqrt{x}=2[/tex]
so
[tex]|(\sqrt{x}-2)\frac{\sqrt{x}+2}{\sqrt{x}+2}|=|\frac{x-4}{\sqrt{x}+2}|<\frac{\delta}{\sqrt{x}+2}<\frac{\delta}{2}=\epsilon=>\delta=2\epsilon[/tex]
Now since x-->4, it is safe to assume that
0<x<5 , now let's take the square root of both sides
[tex]0<\sqrt{x}<\sqrt{5} /+2=>2<\sqrt{x}+2<\sqrt{5}+2=>\frac{1}{\sqrt{x}+2}<\frac{1}{2}[/tex]
Now to be absolutely sure that this holds we choose [tex]\delta=min(2\epsilon, 1)[/tex]
This is all we needed. Do you understand how it goes now?
Yes, I understand it now. Thank you!
My other question is; consider: lim x->0 x^2sin(1/x)
What do you think of the limit (i.e. it exists or it's infinite) ?
How can we prove that this limit is/isn't infinite? What's the working?
Thanks.
lim x->4 √x = 2
Given ε>0
I choose δ = ε^2
0<|x-4|< ε^2
=> |x-2|< √ε^2 = ε
How does that follow? Surely you didn't take the square root of both sides! This is the crucial part of your proof and it is not at all obvious. It isn't even true without other conditions: if x= 5, [itex]\epsilon= 2[/itex], then 0<|x-4|= 1< [itex]\epsilon^2[/itex]= 4 but |x- 2|= 3 is NOT less than [itex]\epsilon[/itex]= 2.
Thanks.
Well, what are your thoughts on it? Show what you did so far, what have you tried?
If the sin(1/x) is bothering you, let y= 1/x and replace all xs with y.
Yes, I have also tried another question, I don't know if I'm right but I'll try it:
lim x->∞ (1+e^x)/e^x
I have sketched the graph and I think the limit is 1.
Now to prove the limit:
Let ε>0 be given.
We choose K = ln(1/ε)>0
so that;
x>k = ln(1/ε) => 1/ε<e^x => e^-x <ε
|((1+e^x)/e^x)|-1 = e^-x< ε
Please correct me if I'm wrong. I'd appreciate that.
Perhaps it would be simpler as (1+ ex)/ex= e-x+ 1.
1. What is the definition of a limit?
The definition of a limit is the value that a function approaches as its input (x-value) approaches a specific value.
2. How do you prove a limit statement using the definition?
To prove a limit statement using the definition, we must show that for any positive number ε, there exists a corresponding positive number δ such that if the distance between the input value x and the limit value a is less than δ, then the distance between the output value f(x) and the limit L is less than ε.
3. Why is it important to prove a limit statement?
Proving a limit statement allows us to show that a function has a specific limit value at a given point, providing evidence of the behavior of the function and helping us understand its properties.
4. How do you prove by definition that lim x->4 √x = 2?
To prove this limit statement, we must show that for any ε > 0, there exists a δ > 0 such that if |x - 4| < δ, then |√x - 2| < ε. This can be done by manipulating the inequality |√x - 2| < ε to find an expression for δ in terms of ε and then showing that this δ satisfies the definition of a limit.
5. What does the statement lim x->4 √x = 2 mean?
This statement means that as the input value x approaches 4, the output value of the function √x approaches 2. In other words, when x is close to 4, the value of √x will be close to 2.
  • Calculus
  • Calculus
  • Calculus
  • Calculus
