Determining coordination sphere from UV, CFSE
  • Thread starter lat3ralus65
  • Tags
    Sphere Uv
If the absorbance spectrum matches more closely with the expected tetrahedral spectrum, then it is likely that your complex is tetrahedral. Conversely, if it matches more closely with the expected octahedral spectrum, then it is likely that your complex is octahedral. Ultimately, the key is to compare and analyze the absorbance spectrum of your unknown complex with the expected spectra from known complexes with the same ligands and coordination numbers.In summary, to determine whether a complex is tetrahedral or octahedral based on UV-Vis absorptions, you should first look up the literature for known complexes with the same ligands and coordination numbers. Then, compare the absorbance spectrum of your unknown complex to the expected spectra and see which one
lat3ralus65
Probably a stupid question, but for some reason I can't think of how to determine whether a complex is tetrahedral or octahedral given only UV-vis absorptions. We have [Co2(MIMT)2(NO3)2] and [Co2(MIMT)4(NO3)2], and I know (it's given) that the first one (absorption at 525 nm) is tetrahedral, so I can figure out the crystal field stabilization energy from there. The second one had an absorption at 545 nm. I have no idea how to take that number and determine whether the molecule is tetrahedral or octahedral (high-spin or low-spin). What do I do?
The first thing you should do is to look up the literature for UV-Vis absorbance spectra of known complexes with the same ligands and coordination numbers. This will give you an idea of what the expected absorbance spectra for a tetrahedral and octahedral complex with the same ligands would be. Once you have that information, then you can compare the absorbance spectrum of your unknown complex to the expected spectra and see which one is more closely aligned. This should give you a good indication of whether the complex is tetrahedral or octahedral.
There are a few ways to determine the coordination sphere of a complex using UV-vis spectroscopy and crystal field splitting energy (CFSE). One approach is to compare the observed absorption peaks with those of known tetrahedral and octahedral complexes. For example, tetrahedral complexes typically have a lower energy peak (longer wavelength) than octahedral complexes due to their smaller CFSE. In your case, the complex with an absorption at 525 nm is likely tetrahedral because it has a lower energy peak compared to the complex with an absorption at 545 nm.
Another approach is to use the Tanabe-Sugano diagram, which plots the CFSE as a function of ligand field strength. The position of the absorption peak on the diagram can indicate the coordination sphere of the complex. For example, a peak at 525 nm would correspond to a tetrahedral complex, while a peak at 545 nm would correspond to an octahedral complex.
In order to determine whether the complex is high-spin or low-spin, you can look at the shape of the absorption peak. High-spin complexes typically have a broader, more intense peak compared to low-spin complexes, which have a narrower, less intense peak. You can also calculate the CFSE using the absorption peak and compare it to the expected values for high-spin and low-spin complexes.
Overall, determining the coordination sphere and spin state of a complex from UV-vis and CFSE data can be challenging and may require additional information or techniques. It is important to carefully analyze the data and consider multiple factors before making a conclusion.
1. What is UV spectroscopy and how is it used to determine the coordination sphere?
UV spectroscopy is a technique used to analyze the absorption of ultraviolet light by a substance. In the context of determining coordination sphere, UV spectroscopy is used to measure the electronic transitions of metal ions in a solution. Based on the absorption patterns, the coordination sphere and ligand environment of the metal ion can be identified.
2. What is CFSE and how does it relate to determining coordination sphere?
CFSE, or crystal field splitting energy, is a measure of the energy difference between the d-orbitals of a transition metal ion in a complex. This energy difference is caused by the repulsion of the ligands surrounding the metal ion. By measuring the CFSE, the coordination sphere and ligand environment can be determined.
3. Can UV spectroscopy and CFSE be used for all metals and ligands?
No, UV spectroscopy and CFSE are most commonly used for transition metal ions and ligands, as these systems exhibit electronic transitions in the ultraviolet range. Other types of metals and ligands may not exhibit these transitions and would require different spectroscopic techniques for determination of coordination sphere.
4. What are some limitations of using UV spectroscopy and CFSE for determining coordination sphere?
One limitation is that these techniques only provide information about the coordination of the metal ion and not the overall structure of the complex. Additionally, UV spectroscopy and CFSE require pure solutions, so the presence of impurities can affect the accuracy of the results.
5. Are there any alternative methods for determining coordination sphere?
Yes, there are other techniques such as X-ray crystallography, NMR spectroscopy, and mass spectrometry that can also be used to determine coordination sphere. Each method has its own advantages and limitations, so the choice of technique will depend on the specific research question and sample being studied.
  • General Engineering
  • Math Proof Training and Practice
