Archimedes' Principle- Popping lid off of a barrel
In summary, the conversation discusses determining the necessary height of a column of water in a tube in order to create enough pressure to pop off the lid of a barrel. The method involves finding the pressure needed and then using the formula for pressure in a fluid to calculate the height. The final answer is 22.901cm.
mchesypoof
A barrel with diameter 80cm is completely full of water and sealed except for a piece of tube extending vertically through the lid with a diameter of 0.8cm. It's asking what height would you have to fill the small tube with in order to make the lid of the barrel pop off. The upward force required to do this is 450N.
Pressure=Force/Area
Boyant F= density (fluid) x A x h x gravity=density (fluid) x gravity x height
I tried finding the areas of both the barrel and the tube, but I may be getting confused with the units. I got: A(barrel)=10053.09; A(tube)=4.021 by using 2Pi x r^2, and from the P=F/A formula, i got the pressures to be: P(barrel)=.01119 and P(tube)=111.9. From here I'm kind of lost. I tried to plug these numbers into the density x g x h equation, but they came out wrong. Any help as to where I should go from here (or how to start it if it's that bad) would be much appreciated.
Forget Archimedes' principle for this one. Instead, just think in terms of pressure. What does the pressure have to be inside the barrel (at the top) to pop off the top?
Once you know the water pressure that you need, then figure out how high the column of water in the tube must be to create such a pressure.
Ok, I plugged the numbers into the Pressure=Force/Area [450/(.8m^2)(Pi)] for the barrel and got the necessary pressure to be 223.81 pa.
Then to find what force would be required in the tube to cause this, I used the same P=F/A formula, to solve for F [223.81=F/((.008m)^2 x Pi), and got it to be 0.04512N (required to cause enough pressure in the barrel, which sounds reasonable).
I plugged this into the classic F=ma equation to find the mass of the water needed to cause this force [0.045124901=9.8m] and got m to be .004604582kg.
Since the density of water is given as 1000 kg/m^3, I used density to find the V this water would take up [p=m/V] and got .000004605 M^3.
Using V=Area x height [.000004605 M^3= (.000201062 M^2) x h] and got h to be 0.022901M, or 22.901cm (what answer is supposed to be in).
I was wondering if this looked like a reasonable method for solving this problem (and if I made any simple errors) and if there is a simple way that I could check my answer?
OK, except that 80 cm is the diameter of the barrel, not the radius. Correct that.
That's the hard way. (Too many opportunities for error.)
All you need to do is find the height of the column of water needed to produce that pressure. How does pressure in a fluid depend on height?
Thanks, I used the P=density x height x gravity and got the same answer. Thank you very much!
FAQ: Archimedes' Principle- Popping lid off of a barrel
1. What is Archimedes' Principle?
Archimedes' Principle is a scientific law that states that the buoyant force acting on an object immersed in a fluid is equal to the weight of the fluid that the object displaces.
2. How does Archimedes' Principle relate to popping the lid off of a barrel?
The principle explains why it is easier to remove the lid of a barrel filled with liquid when the barrel is on its side, as the liquid exerts an upward force on the lid that helps to lift it off.
3. What factors affect the buoyant force according to Archimedes' Principle?
The buoyant force is affected by the density of the fluid, the volume of the fluid displaced by the object, and the acceleration due to gravity.
4. How did Archimedes discover this principle?
According to legend, Archimedes discovered this principle while taking a bath and noticed the water level rising as he got into the tub. This led him to realize that the weight of the water displaced by his body was equal to his own weight.
5. Is Archimedes' Principle applicable to all types of fluids?
Yes, Archimedes' Principle applies to all fluids, including liquids and gases. However, it is most commonly used in reference to liquids, as gases are compressible and their density can change with pressure.
