Can LED's emit monochromatic light as efficiently as broad spectrum?
In summary: Many people want broad spectrum lighting for good color rendition. I wonder if they would agree to compromise with a three way mix of monochromatic red, green, and blue light, so they still get white light, but astronomers can filter out each of the three peaks. Our filters stand no chance against broad spectrum lighting. What if they had a mix of red, green, and blue LED's, which mix to white light by the time it hits the ground.Is there an efficient way to make those colors? I know low pressure sodium makes almost monochromatic yellow light, but it is not as efficient as the broad spectrum LEDs. Does anyone know how LED light is made and
Stargazer19385
49
I read that many high pressure sodium and high pressure mercury street lights are being replaced with much more efficient LED lights, which fortunately point downwards instead of sending light sideways at star gazers like me, or into the sky where it refracts back down and hazes over the stars and galaxies.
Is there an efficient way to make those colors? I know low pressure sodium makes almost monochromatic yellow light, but it is not as efficient as the broad spectrum LEDs. Does anyone know how LED light is made and if the compromise is efficiently possible?
Thank you.
Science news on Phys.org
I was told on an astronomy forum that LED's don't make monochromatic light. Well, even if they make a sort of tight bell curve, and we can cut off everything within 60% of the max peak, that would still greatly improve visual astronomy. I photographers can just subtract most of it out with software, but some of us still like to see the light with our own eyes.
LED light is made the same way as any other light - electron transitions between energy states.
It's just that the energy states in question can be carefully selected at manufacture - this makes single color LEDs quite specific with about 25nm FWHM each - you can filter them pretty effectively.
There are other ways and this is an area of active research.
Wikipedia has a set of spectra for the main ways of making white-light LEDs.
http://en.wikipedia.org/wiki/Light-emitting_diode
... you can use that to kick off a more detailed search.
Note: streetlighting is likely to use the cheapest version possible.
The below pdf document from the International Dark Sky Association discusses the negative effects of light pollution, and specifically addresses the spectral contributions.
Extract from the Abstract:
“Outdoor lighting is undergoing a substantial change toward increased use of white
lighting sources, accelerated most recently by developments in solid-state lighting.
Though the perceived advantages of this shift (better color rendition, increased “visual
effectiveness” and efficiency, decreased overall costs, better market acceptance) are
commonly touted, there has been little discussion of documented or potential
environmental impacts arising from the change in spectral energy distribution of such
light sources as compared to the high-pressure sodium technology currently used for most
area lighting. This paper summarizes atmospheric, visual, health, and environmental
research into spectral effects of lighting at night.”
http://www.darksky.org/assets/documents/Reports/IDA-Blue-Rich-Light-White-Paper.pdf
The human eye is most responsive at around 555 nanometers which is green or rather a slightly yellow green. So if you wanted to make a street light with maximum efficiency then guess that would be a reasonable colour to pick (although I can see reasons why a narrow spectrum might not be ideal).
Perhaps of interest..
http://en.wikipedia.org/wiki/Luminous_efficacy
Photopic luminous efficacy of radiation has a maximum possible value of 683 lm/W, for the case of monochromatic light at a wavelength of 555 nm (green).
It depends on what you want. An environment with monochromatic illumination is disgusting to work in. You have to consider the human factor when lighting a scene.
I don't think most people care about the concerns of astronomers.
Personally I am much more concerned about seeing what is in front of me when walking or driving at night.
You are probably right, there. Space-borne telescopes don't care too much about our light pollution. There are far more people who need reasonable light levels. It should be said that there are ways of illuminating roads and buildings that are more efficient and produce less light pollution than what we use today.
I was not suggesting we use one monochromatic frequency. I was suggesting we use three peaks: red, blue, and green, to give white light to those who need light, but three peaks that ground based astronomers can cut out.
If there were white light composed of three narrow peaks of red, blue, and greee/yellow, would most people be happy with that? Mercury vapor lights come close to what I'm talking about, but they have two blue peaks instead of one, and they have an orange peak instead of a red one.
On the face of it, that would seem a good solution. However, although the light source ( torch) could be made to look a good white, the light reflected from objects could make them appear very different colours from their colours in broadband white light.
I guess it might be a compromise to produce a suitable 'white' illuminant with a spread of single wavelengths with a few gaps in. This could give reasonable colour fidelity plus some suitable windows for astronomers.
FAQ: Can LED's emit monochromatic light as efficiently as broad spectrum?
1. Can LED's emit monochromatic light as efficiently as broad spectrum?
Yes, LED's can emit monochromatic light as efficiently as broad spectrum. LED's are known for their high energy efficiency and can produce light at specific wavelengths, making them ideal for monochromatic light emission.
2. What is the difference between monochromatic and broad spectrum light?
Monochromatic light is light that contains only one wavelength, while broad spectrum light contains a range of wavelengths. LED's are capable of producing both types of light, but their efficiency may vary.
3. How does the efficiency of monochromatic LED light compare to traditional lighting sources?
Monochromatic LED light is generally more efficient than traditional lighting sources. This is because LED's convert a higher percentage of energy into light, while traditional sources often waste energy as heat.
4. Are there any limitations to LED's emitting monochromatic light?
Yes, there are some limitations to LED's emitting monochromatic light. LED's are limited in the range of wavelengths they can produce, which may not cover the entire visible spectrum. Additionally, the efficiency of monochromatic light may decrease at higher power levels.
5. How is the efficiency of monochromatic LED light measured?
The efficiency of monochromatic LED light is typically measured in terms of luminous efficacy, which is the amount of visible light produced per unit of electrical power. This is usually expressed in lumens per watt (lm/W). The higher the lm/W value, the more efficient the monochromatic LED light is.
9K
19K
