Self-Induced Magnetic Field in a moving rod with current
In summary, the force on the bar is in the left direction if the original magnetic field is greater than the induced field. If the original field is smaller, the force is in the right direction.
shespuzzling
Hi,
In my book, they use an example to explain motional emf. The example consists of a rectangular circuit with a resistor on the left side and a moving bar on the right side. There already exists a magnetic field pointing into the paper and the bar is given an initial velocity to the right. I'm having some trouble determining exactly what is the force on the movable bar. I will explain what I think is happening, and then hopefully somebody can help me out!
1. Initially there is no current. As the bar moves to the right, the magnetic flux is changing, and thus an emf and a current is induced in the circuit. This current is in the counter clockwise direction.
2. Now that there is current in the circuit, a magnetic field is induced due to the current. My understanding is that the magnetic field will encircle the wire in the circuit and will come out of the page on the left and into the page on the right (**is this correct? the book says that the induced magnetic field is simply "out" of the page, but if it is a circle it has to go both ways, right?)
3. My understanding is that there are now two magnetic fields that come into play. There is the uniform magnetic field initially present that is directed into the page, and there is now the induced magnetic field due to the induced current that encircles the circuit. To me, this means that to the left of the movable bar, the induced magnetic field goes against the original magnetic field, but to the right of the bar, the induced field actually goes in the same direction as the original field. Thus, to the left the fields subtract and to the right they add. (**something tells me I'm wrong about this but I can't figure out why)
4. If there are indeed the two fields that come into play, then the total force on the bar from the magnetic fields is in the left direction (assuming that the original B field is much greater than that induced by the current). However, if you calculate it individually, to the left of the bar you have F=ILx(B1-B2) where B1 is the original field and B2 is the induced field. To the right you have F=ILx(B1+B2). Then, adding these forces you get the total force to equal 2*IL(B1).
If anybody can shed some light on this I'd be really appreciative! I'm trying to teach myself physics and it can be pretty confusing at times.
Thanks!
Good.
Not good. The induced current in the loop is no different from a current produced by a battery. This current generates a magnetic field that is perpendicular to the plane of the loop and out of the page (or screen) according to the right hand rule. Yes, magnetic field lines form closed loops, but here the closed loops cross the plane of the current loop perpendicularly over the entire area enclosed by the current loop.
That is correct. However, the induced magnetic field extends through the entire area of the moving loop whereas the uniform magnetic field goes through the part of the loop that has already entered the field. The rest of the loop is outside the uniform field area and has no uniform magnetic flux through it. In this particular case the induced field is out of the page and the uniform field is in the opposite direction, into the page.
The bar on the left is out of the uniform field region so there is no force on it due to B1. When you add the forces together, you get I L B1. I should add that when the left bar crosses into the field region, there is no more induced current and no more force on the loop. That's because the motional emfs from the two bars cancel each other.
1. What is the concept of self-induced magnetic field in a moving rod with current?
The concept of self-induced magnetic field in a moving rod with current refers to the phenomenon where an electric current flowing through a conductor creates a magnetic field around the conductor. This magnetic field then interacts with the current itself, causing it to produce an opposing magnetic field in the opposite direction. This is known as self-induction and is responsible for the production of a magnetic field in the moving rod.
2. How does self-induction affect the movement of a rod with current?
Self-induction creates a force that opposes the movement of the rod. This is due to the interaction between the magnetic fields created by the current and the rod itself. The opposing force can cause a decrease in the speed of the rod or even stop its movement altogether.
3. What are the factors that affect the strength of the self-induced magnetic field?
The strength of the self-induced magnetic field depends on several factors, including the current flowing through the rod, the length of the rod, and the speed at which the rod is moving. Additionally, the material of the rod and its shape can also affect the strength of the magnetic field.
4. How does the direction of the current affect the self-induced magnetic field?
The direction of the current is crucial in determining the direction of the self-induced magnetic field. If the current changes direction, the magnetic field will also change direction, resulting in a change in the force acting on the rod. This is known as Lenz's law and is a fundamental principle in understanding self-induction.
5. Can self-induction be used in practical applications?
Yes, self-induction has many practical applications, such as in transformers, motors, and generators. It is also used in electronic devices such as inductors and coils, which are essential components in circuits. By understanding and utilizing self-induction, we can harness the power of magnetic fields to create and control various electrical devices.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
