Ternary numeral system, how does it relate to binary issue
In summary: Thanks for the correction! In summary, the ternary numeral system uses trits as its digits and each trit contains approximately 1.58496 bits of information. This is derived using the logarithm function, which shows that n bits of information is equivalent to m trits when n = log(base 2) 3 * m. However, despite storing more information per trit, the complexity of three-state mechanisms makes binary a more efficient storage method in most cases.
Ledgeknow
Ternary (sometimes called trinary) is the base-3 numeral system. Analogous to a bit, a ternary digit is a trit (trinary digit). One trit contains log(base 2) 3 (about 1.58496) bits of information.
Source: http://en.wikipedia.org/wiki/Ternary_numeral_system
The last sentence in the quote from the Wikipedia has recently intrigued me. I understand that the logarithm function returns a value which when used as an exponent to the base n gives the original input value.
Can someone elaborate on the last sentence with a little bit more verbalization of why the log function was used to derive how many bits of information there is in a trit. What does it mean 1.58496 bits?
Mathematics news on Phys.org
1 bit of information can be either a 0 or a 1
1 bit of information can represent: 0,1
2 bits of information can represent: 0,1,2,3
3 bits of information can represent: 0,1,2,3,4,5,6,7
n bits of information can represent: 0,...,2n-1
1 trit of information can be a 0, 1, or 2 so
1 trit of information can represent: 0,1,2
2 trits of information can represent: 0,1,2,3,4,5,6,7,8
m trits of information can represent: 0,...,3m-1
n bits of information is the same amount of information as m trits when:
2n-1=3m-1
or rearranging for n shows us how many n bits of information are equivilent to m trits:
n=log23m
finally we wanted to know how many bits are equal to 1 trit, so we set m=1 and get:
log23=1.58496
Sounded like that answered the question perfectly, if nobody minds I have a similar question...
If a trit requires 50% more space and stores 58% more information surely it's a more efficient storage method?
Ledgeknow said:
Source: http://en.wikipedia.org/wiki/Ternary_numeral_systemThe last sentence in the quote from the Wikipedia has recently intrigued me. I understand that the logarithm function returns a value which when used as an exponent to the base n gives the original input value.
In binary, n bits is meant a string of n 0's and 1's. I'm guessing m trits seems to mean a strong of m 0's 1's or 2's. Per every m trits, its is stating there are 1.58m bits.
The "units of information" article, it explains why. To be able to store n possible states in binary, you need log_2(n) bits. Hence if you know your program will need to store a number up to 65, you'll need CEIL(log_2(65)) = 7 bits of information (1000001b = 65d). You will only need 3 trits (3^4d = 81d and 65d = 212t). That 1.58... proportion is log_2(3). All it is saying is that using m trits will store 58% more bits on average than m bits. In this example, its clearly much more than 1.58.
I don't quite know what you mean by "50% more space". As far as base 3 being a more efficient storage method, the answer is almost certainly no. Physicists and electrical engineers have come up with a slew of mechanisms that have two stable states. It's easy. Mechanisms with three stable states tend to be far more complex. Your computer uses binary at its heart, as does practically every digital computer ever made. There's a reason for that.
6510 is not 212. It is 21023: 2*27+1*9+0*3+2*1. (2123 is 2310.) The ratio of the number of bits to the number of trits needed to represent 65 is 1.75, so not a whole lot more than 1.585.
For any given non-negative integer, the ratio of the number of bits needed to represent that number to the number of trits needed to represent that number is always between 1 and 2. The extrema are hit at 0, 1, 2, 3, and 8. For all other numbers, the ratio lies between 1 and 2, exclusive of the end points.
Gotcha, I should have realized something was wrong with such a big difference.
1. What is a ternary numeral system?
The ternary numeral system is a number system that uses three symbols to represent numbers: 0, 1, and 2. This is different from the more commonly used binary system, which only uses two symbols (0 and 1).
2. How does the ternary system relate to the binary system?
The ternary system is closely related to the binary system because both systems use positional notation, where the value of a digit is determined by its position in the number. In ternary, the value of each digit is multiplied by powers of three, while in binary it is multiplied by powers of two.
3. Why would someone use the ternary system instead of the binary system?
The ternary system is useful for representing numbers in situations where three states or options are present, such as in computing or genetics. It can also be more efficient for certain calculations, as it requires fewer digits to represent a given number compared to binary.
4. How is data stored in ternary systems?
Data is stored in ternary systems using a combination of 0, 1, and 2 symbols. These symbols can be represented by different physical states, such as high and low voltages in electronic circuits, or different colors in optical storage devices.
5. Are there any other numeral systems besides ternary and binary?
Yes, there are many other numeral systems, such as the decimal system (base 10), octal system (base 8), and hexadecimal system (base 16). Each system has its own set of symbols and rules for representing numbers, and they all have their own unique applications in different fields of mathematics and computing.
  • General Math
  • General Math
  • General Math
