- #1
fluidistic
- 263
The problem can be found in Jackson's book, I think in chapter 1 problem 3 or something like this.
I must determine the charge distribution of a uniformly charged disk of radius R in spherical coordinates (I've done it in cylindrical coordinates and had no problem). The total charge is Q.
I've found a solution on the internet but the answer is different from mine.
I forgot to mention that I have to use Dirac's delta.
[itex]\int _{\mathbb{R}^3} \rho (\vec x )=Q[/itex].
Since the charges are over a 2d surface, there will be 1 Dirac's delta in the expression for rho, the charge density. I will use Heaviside's step function because the surface is limited.
Let [itex](r, \theta , \phi )[/itex] be the coordinates. I make the ansatz/educated guess that [itex]\rho[/itex] is of the form [itex]C \delta \left ( \theta - \frac{\pi }{2} \right ) \Theta (r \sin \theta -R)[/itex].
Integrating this distribution in all the space, I reach that C is worth [itex]\frac{3Q}{2\pi R^3}[/itex].
Therefore [itex]\rho (r, \theta )=\frac{3Q\delta \left ( \theta - \frac{\pi }{2} \right ) \Theta (r \sin \theta -R)}{2\pi R^3}[/itex].
However the solution provided on the internet is [itex]\rho (\vec x )=\frac{q }{\pi R^2r} \delta \left ( \theta - \frac{\pi }{2} \right ) \Theta (r -R)[/itex].
Are they both equivalent (I doubt it), if not, did I do something wrong? If so, what did I do wrong? Thanks a lot!
