Casting 2x2 matrix with unit determinant in another form
In summary: Thanks everyone for your input! In summary, the minimal decomposition of a 2x2 real matrix with unit determinant into a rotation matrix and a scalar is the Iwasawa decomposition. This decomposition can be found in a reference called "Matrix Algebra" by Keith Conrad. Another decomposition that is relevant to SL(2,R) is the polar decomposition, which states that any A can be written as a product of a cosine and a sine. The Bruhat decomposition states that a matrix A in SL(2,R) can be either upper-triangular or can be decomposed into a product of a 1 and a scalar.
ivl
27
Dear all,
I have a simple question for you. Any help will be very appreciated.
==Assumptions===
I have a 2x2 matrix, with real entries:
|A B|
|C D|
Such matrix has unit determinant, AD-BC=1.
(For those of you in group theory: the above is a representative of SL(2,R)).
==Question===
The above matrix, due to the unit-determinant condition, has 3 independent parameters.
So, I would like to represent the 2x2 real matrix with unit determinant in a more convenient form: a form which depends on only 3 parameters.
For instance, I could try and relate the above matrix to a rotation matrix, that is, one of the independent parameters would be a rotation angle.
Any ideas on a convenient "minimal" representation?
Thanks a lot!
IVL
There are several such decompositions. Perhaps the most aesthetically pleasing one is the Iwasawa decomposition (also known as the KAN decomposition), which says that any A in SL(2,R) can be written as a product
[tex]A = \begin{pmatrix} \cos\theta & -\sin\theta \\ \sin\theta & \cos\theta \end{pmatrix} \begin{pmatrix} a & 0 \\ 0 & a^{-1}\end{pmatrix} \begin{pmatrix} 1 & n\\ 0 & 1\end{pmatrix},[/tex] where [itex]\theta \in [0, 2\pi)[/itex], [itex]a > 0[/itex] and [itex]n \in \mathbb R[/itex] are uniquely determined by A.
Wow! Thanks Morphism, that is precisely what I was looking for.
Do you have any good reference on the Iwasawa decomposition?
Cheers
IVL
Message to other users: for the sake of completeness, if you think there are other decompositions worth being mentioned, please add them to the thread. Thanks.
For the Iwasawa decomp of SL(2,R), these notes of Keith Conrad are nice.
I should mention that what's going on here is part of a bigger picture: the Iwasawa decomposition is really a statement about decomposing certain types of groups (e.g. semisimple Lie groups) of which SL(2,R) is an example.
For an example of another decomposition, you can refine the polar decomposition that you learned in linear algebra to obtain the so-called KAK decomposition, which also applies to a broad class of Lie groups. For SL(2,R), this states that any A can be written as
[tex]A = \begin{pmatrix} \cos\theta & -\sin\theta \\ \sin\theta & \cos\theta \end{pmatrix} \begin{pmatrix} a & 0 \\ 0 & a^{-1}\end{pmatrix} \begin{pmatrix} \cos\psi & -\sin\psi \\ \sin\psi & \cos\psi \end{pmatrix},[/tex]
where [itex]\theta,\psi \in [0,2\pi)[/itex] and [itex]a>0[/itex] are uniquely determined by A.
Yet another example is the Bruhat decomposition, which states that [itex]A \in \text{SL}(2,\mathbb R)[/itex] is either upper-triangular, or else can be decomposed as
[tex]\begin{pmatrix} a & b \\ c & d \end{pmatrix} = \begin{pmatrix} 1 & ac^{-1} \\ 0 & 1 \end{pmatrix} \begin{pmatrix} 0 & -1 \\ 1 & 0 \end{pmatrix} \begin{pmatrix} c & d \\ 0 & c^{-1} \end{pmatrix}.[/tex] Note that c is nonzero since we're assuming A is not upper-triangular, so it makes sense to invert it. Also note that b appears to have vanished, but of course it's still there as [itex]b = (ad-1)c^{-1}[/itex].
Veeery nice!
Thanks a lot!
Dear Morphism, and dear all,
thinking more on the above, I have two questions:
1. Doers there exist an AKA decompostion? (where A and K take the same meaning as in the KAK decomposition)
2. I am very interested in the Bruhat decomposition. Can anyone recommend a good reference for that?
For some reason, the matrix equations do not appear any more on the blog's page. Is anyone experiencing the same problem?
Cheers
IVL
1. No, there can be no such decomposition. If there were, we would be able to write
[tex]\begin{pmatrix}1 & 1 \\ 0 & 1\end{pmatrix} = \begin{pmatrix}a & 0 \\ 0 & a^{-1}\end{pmatrix}\begin{pmatrix}\cos\theta & -\sin\theta \\ \sin\theta & \cos\theta\end{pmatrix}\begin{pmatrix}b & 0 \\ 0 & b^{-1}\end{pmatrix} = \begin{pmatrix}ab\cos\theta & -ab^{-1}\sin\theta \\ a^{-1}b\sin\theta & a^{-1}b^{-1}\cos\theta\end{pmatrix}.[/tex] Equate the bottom left corners to get $$a^{-1}b\sin\theta = 0 \implies \sin\theta=0.$$ But then the top right corners imply that $$1 = a^{-1}b\sin\theta = 0.$$
2. There isn't really much to say about the Bruhat decomposition for SL(2,R) besides what I had already mentioned. If you're interested in the Bruhat decomposition for a general semisimple/reductive group, then if you tell me what your representation theory background looks like, I might be able to suggest a suitable reference.
Related to Casting 2x2 matrix with unit determinant in another form
What does it mean to "cast" a 2x2 matrix?
Casting a matrix refers to converting it into a different form or representation, usually for the purpose of simplification or solving a problem.
What is the significance of a 2x2 matrix with a unit determinant?
A unit determinant for a 2x2 matrix means that the matrix is invertible, meaning it has an inverse matrix that can be multiplied with the original matrix to give the identity matrix. This property is important in many mathematical and scientific applications.
Why would someone want to cast a 2x2 matrix with a unit determinant into another form?
Casting a 2x2 matrix into another form can make it easier to perform calculations or solve problems. For example, a matrix with a complex determinant may be easier to work with in polar form rather than Cartesian form.
What are some common forms that a 2x2 matrix with a unit determinant can be cast into?
Some common forms include using polar coordinates, finding the eigenvalues and eigenvectors, or using matrix decomposition techniques such as LU or QR decomposition.
Is it always possible to cast a 2x2 matrix with a unit determinant into another form?
Yes, it is always possible to cast a 2x2 matrix with a unit determinant into another form. However, the form that it can be cast into may depend on the specific properties of the matrix, such as its eigenvalues or determinant.
  • Linear and Abstract Algebra
