Rotational Dynamics about an axis parellel to the axis at the center of mass
In summary: Is my assumption correct?In summary, a uniform sign with a mass of 69 kg, length of 1.6 m, height of 2.2 m, and a moment of inertia of 170 kg · m2 about its upper-left corner begins to rotate about its remaining nail in the upper-left corner when the upper-right nail breaks. To find the moment of inertia about an axis parallel to the upper-left nail but passing through the center of mass, the weight of the sign was used to calculate the torque. This torque was then set equal to the equation for torque, τ = I*α, to solve for the angular acceleration. The magnitude of the tangential acceleration of the center of mass can also be
kchurchi
39
A uniform sign is nailed into a wall at its top two corners. The nail on the upper-right corner breaks, and the sign begins to rotate about the remaining nail in the upper-left corner. The mass of the sign is 69 kg, L (length) = 1.6 m, H (height) = 2.2 m, and the moment of inertia of the sign about the upper-left corner is 170 kg · m2.
What is the moment of inertia about an axis that is parallel to the one through the upper-left nail but passes through the center of mass of the sign?
What is the angular acceleration of the sign just after the nail breaks?
Icm (rectangular sign) = [m*(H^2] + L^2)]/12
I(p) = I(cm) + m*d^2
Where d is the perpendicular distance to the axis of rotation
Ʃτ = I*[itex]\alpha[/itex]
So I am just confused on the second part. Using the first equation that I provided I was able to find the moment of inertia about a parallel axis at the center of mass. For the next part though, I tried using the equation for a mass rotating about a "point" at a certain distance from the center of mass to find this distance. From there I stopped. I don't really know what to do now? I thought of maybe using torque but wasn't sure how.
Any help is appreciated! Thanks :)
The gravitational force can be thought of as acting at the position of the centre of mass. Since the sign is uniform (i.e. its density is constant), the centre of mass corresponds to the geometric centre of the sign. So, you have a force equal to the weight of the sign acting at its centre. What torque does this force produce around the pivot point?
So torque is equal to Force crossed with the distance.
τ = F x d
And in this case we would want the perpendicular distance from the center of the sign to the pivot point, which is 1/2 the length. The force, as you said, will be the weight, which is perpendicular to this distance. So we can simplify the cross product.
τ = F*d = (m*g)*(1/2*L)
Then can I set this torque equation equal to this one?
τ = F x d
Yeah, of course. If one expression 1 is equal to the torque, and expression 2 is also equal to the torque, then expression 1 must be equal to expression 2.
Sweet! Thanks so much for your help. I was getting all mixed up.
Now I have to find the tangential acceleration. This is fairly easy. However, I just wanted to double check one point. In the equation where a (tan) = [itex]\alpha[/itex] * r, is r the distance from the center to the point of rotation? Or is it the perpendicular distance as I used in my last part of the problem? Just a clarification would be helpful.
The problem as stated in your original post doesn't ask for the linear (tangential) acceleration at any point, it only asks for the angular acceleration, ##\alpha##. The angular acceleration is the same for every point in the rigid body, whereas the tangential acceleration will be different at different radii from the axis of rotation. Since the problem as you've stated it doesn't ask for a tangential acceleration, I can't really advise you on the radius at which you should compute it.
Oops! Sorry, I didn't copy the full problem. Here is the part referring to the tangential acceleration. Feel free to contribute or not.
What is the magnitude of the tangential acceleration of the center of mass of the sign just after the nail breaks?
So I am assuming that I am using the distance from the point of the center of mass to the point of rotation...
Yeah. It asks for the acceleration of the centre of mass, so you have to use the 'r' of the centre of mass. The linear acceleration is different for different points in the sign, so you can't use some other 'r' corresponding to some other point. You have to use the radial distance of the point whose acceleration you're interested in.
Hmmm that was a bit confusing to me. So basically am I going to have to manipulate the equation pertaining to the parallel axis theorem to solve for the radial distance?
(i.e. I (p) = I (cm) + m*r^2)
Then let me give a less confusing answer:
YES.
Of course you have to use the radius of the point whose acceleration you are trying to compute. That's all I was trying to say in my previous post.
What the heck does the parallel-axis theorem have to do with this part of the problem?
I really appreciate your help. I am sorry if I have aggravated you. I will stop posting.
No, you haven't aggravated me, just puzzled me quite a bit. If you still are having trouble solving the problem and don't know what to do, then keep posting.
Thank you. I think I can handle it from here. I really do appreciate your patience, and sorry for puzzling you. Sometimes it takes a while to wrap my head around even the simplest physics concepts. It's very frustrating. I completely understand what you were trying to say now. I don't know where the heck the parallel axis theorem came from. My bad.
Thanks!
FAQ: Rotational Dynamics about an axis parellel to the axis at the center of mass
1. What is rotational dynamics about an axis parallel to the center of mass?
Rotational dynamics about an axis parallel to the center of mass refers to the study of the rotational motion of an object around an axis that is parallel to the axis passing through the center of mass. It involves understanding the forces and torques acting on the object and how they affect its rotational motion.
2. What is the difference between rotational dynamics and linear dynamics?
Rotational dynamics deals with the motion of objects around a fixed axis, while linear dynamics deals with the motion of objects along a straight line. Rotational dynamics also involves the concept of torque, which is not present in linear dynamics.
3. How is rotational inertia related to rotational dynamics?
Rotational inertia, also known as moment of inertia, is a measure of an object's resistance to change in its rotational motion. It is an important factor in rotational dynamics as it affects the amount of torque required to change an object's rotational motion.
4. What is the role of angular velocity in rotational dynamics?
Angular velocity is a measure of how fast an object is rotating around an axis. In rotational dynamics, it is used to calculate the angular acceleration of an object, which is directly proportional to the net torque acting on the object.
5. How does the distribution of mass affect rotational dynamics?
The distribution of mass in an object affects its rotational dynamics by influencing its moment of inertia. Objects with more mass distributed farther from the axis of rotation have a higher moment of inertia, making them more resistant to changes in their rotational motion.
