Where do "Other" Frequency's Come From when Multiplying Cos Waves?
  • Thread starter CraigH
  • Tags
    Cos Waves
In summary, when multiplying two cos waves with similar frequencies, the resulting graph will show other frequencies due to the product to sum trig identities. These additional frequencies can be found in the Fourier transform of the wave.
CraigH
222
When you multiply two cos waves together, where do all the "other" frequency's come f
When you multiply two cos waves with similar frequency's you get a graph that looks like this:
http://www.wolframalpha.com/input/?i=(cos(2*pi*0.8*x))*(cos(2*pi*0.9*x))
With equation y=(cos(2*pi*0.8*x))*(cos(2*pi*0.9*x))
Now if you analyse this wave with a Fourier transform to see the the frequency domain there are lots of other frequency's as well as the 0.8HZ and the 0.9HZ that seem to have come from no where.
Can someone please show me the maths that shows where these frequency's come from?
Thanks
Mathematics news on Phys.org
The frequencies you see are .8+.9=1.7 Hz and .9-.8=.1 Hz. See the product to sum trig identities:
http://www.cliffsnotes.com/study_guide/ProductSum-and-SumProduct-Identities.topicArticleId-11658,articleId-11616.html
ahhh okay, thanks, that's helped allot. so just to confirm, when you add 2 waves you get a wave which has 2 frequency's, and these 2 frequency's are the frequency's of the original 2 waves. And when you multiply two waves you use trig identity's to see the equivalent solution as a sum.
Is this correct?
Yes, that is correct (as long as you are talking about sine/cosine waves)
for your question. I can explain the origin of these "other" frequencies when multiplying cos waves using the Fourier transform. The Fourier transform is a mathematical tool that allows us to analyze a signal in the frequency domain, breaking it down into its individual frequency components. In simple terms, it takes a complex signal and decomposes it into simpler components.
When you multiply two cos waves together, you are essentially adding their individual frequency components. Let's take the example you provided of y=(cos(2*pi*0.8*x))*(cos(2*pi*0.9*x)). The individual frequency components of this signal can be represented as cos(2*pi*0.8*x) and cos(2*pi*0.9*x). When we multiply these two signals, we get:
y = (cos(2*pi*0.8*x))* (cos(2*pi*0.9*x))
= (1/2)(cos(2*pi*(0.8+0.9)*x)) + (1/2)(cos(2*pi*(0.8-0.9)*x))
= (1/2)(cos(2*pi*1.7*x)) + (1/2)(cos(2*pi*0.1*x))
This means that when we multiply two cos waves with similar frequencies, we get additional frequency components at the sum and difference of the two original frequencies. In this case, we get a frequency component at 1.7Hz (0.8+0.9) and at 0.1Hz (0.8-0.9). These are the "other" frequencies that seem to have come from nowhere.
In general, when multiplying two signals with different frequencies, the resulting signal will contain frequency components at the sum and difference of the original frequencies. This is known as the "beat frequency" phenomenon. The frequency components at the sum and difference frequencies are often referred to as "sidebands" and can be seen in the frequency spectrum of the multiplied signal.
I hope this explanation helps to clarify where these "other" frequencies come from when multiplying cos waves. The Fourier transform is a powerful tool in understanding the frequency components of a signal, and it can help us to better understand the complex nature of wave interactions.
FAQ: Where do "Other" Frequency's Come From when Multiplying Cos Waves?
1. Where do the "other" frequencies come from when multiplying cos waves?
The "other" frequencies that appear when multiplying cosine waves come from the process of Fourier analysis. This mathematical technique breaks down a complex wave into its individual frequency components. When two or more cos waves are multiplied, the resulting wave contains all of the frequency components from each individual wave.
2. Can these "other" frequencies be predicted?
Yes, the "other" frequencies can be predicted using the Fourier transform. This mathematical tool allows us to analyze a complex wave and determine the frequency components that make it up. By multiplying two or more cos waves, we can use the Fourier transform to predict the resulting wave's frequency components.
3. Do "other" frequencies always appear when multiplying cos waves?
Yes, "other" frequencies will always appear when multiplying cos waves. This is because the multiplication process combines all of the frequency components from each individual wave, resulting in a more complex wave with additional frequencies.
4. What is the significance of these "other" frequencies?
The "other" frequencies that appear when multiplying cos waves have important implications in signal processing and communication systems. By understanding and manipulating these frequencies, we can create complex waves with specific frequency components that are useful for various applications.
5. Are there ways to reduce or eliminate the "other" frequencies?
Yes, there are techniques such as filtering and modulation that can be used to reduce or eliminate the "other" frequencies in a wave. These techniques are commonly used in signal processing and communication systems to remove unwanted frequencies and improve the quality of the signal.
