UWB (Impulse) radar advantages over Pulsed radar
In summary, the advantages of using an Ultra Wide-Band (UWB) radar system over conventional radar include a higher bandwidth and accuracy for distance measurement. However, UWB systems are more difficult to make due to the high bandwidth. The accuracy of the measurement is determined by the pulse width, with shorter pulse widths resulting in higher accuracy and resolution. However, longer pulse widths can also be used as long as the return pulse can still be accurately measured. The accuracy is also affected by the PRF and the size of the object being measured.
Nabla_101
Hi,
I was wondering what the advantages are of using an Ultra Wide-Band (UWB) radar system (also known as impulse radar) where you transmit an extremely small pulse (sub-nanosecond), and hence a very large bandwidth, over conventional radar that use continuous waves or larger pulse widths.
I am interested in the case of distance measurement between two UWB transceivers using time-of-flight estimation, as opposed to a probing radar that detects echoes from objects it is probing (like millimeter-wave radar).
So consider a transmitter transmitting a gaussian pulse with a 300ps pulse width, then a receiver retransmitting it after a fixed, known delay, so the round trip time can be calculated by clocking the time at the reception of the pulse by the original transceiver.
I know accurate timers exist for getting an accurate distance estimation, even at the fast speed of light, but I don't see what the difference is between transmitting an extremely small pulse with a high bandwidth, as opposed to detecting the leading edge of a longer narrowband pulse, for example if you were pulse-code modulating a narrowband signal.
UWB radar systems are a lot more difficult to make due to the high bandwidth, so they must offer some advantages for them to even exist.
Thanks
There already exists distance measuring sets using laser time of flight and it is a lot simpler and accurate also, you aim it at something reflective and it measures the time of flight even for short distances of say 20 feet or less which would be a signal path time of around 40 nanoseconds so the laser must have a pulse width of around 1 nanosecond already which would give an accuracy of less than a foot, and the ones I saw were more like 1/8 th of an inch at 200 odd feet. That would imply a pulse width of a couple hundred picoseconds. Sounds to me like your proposed measurement system would be a lot more complex since the laser measurement system is in a hand held device that looks more like a thermal imaging tool.
Thanks, I'm aware of the laser positioning systems out there, but they are unsuitable for all applications, and UWB may offer more advantages in some cases. But I'm assuming the principle is exactly the same, and so how are range and accuracy requirements related to the required pulse width?
Say your requirement is to measure over a range of 1m to 20m, with a resolution of 1mm (Which I know laser systems can easily achieve - whether that's TOF or otherwise), then what is the maximum your pulse width is allowed to be based on these numbers? (Is there a formula relating them?)
This is where I'm struggling:
Minimum round trip time is 2*[1 metre (minimum range)] / [speed of light] = 6.67ns.
Time resolution required for distance resolution of 1mm = [0.001] / [speed of ight] = 3.33ps. This can be acheived by oversampling with a less accurate/expensive timer.
So say you have to transmit the entire pulse before you can receive the return pulse, then if your pulse width is 6ns, you will have completely transmitted it before you receive its rising edge (6.67ns later at the minimum distance). Then if you can measure the rising edge with an accuracy of 3.33ps, you will have met your accuracy and range requirements.
Therefore, it seems to me that the pulse width merely determines the minimum range of operation, while the accuracy is determined by the accuracy of your timer and the amount of oversampling used, which are two different things.
This is why I don't understand the implication that a smaller pulse width equals a higher accuracy/ distance resolution. I can't see how this is true, what am I missing?
Considering the case of a UWB radio system, shorter pulsewidth = considerably more noise, so therefore, why not just use longer pulse width, and have less noise if you can still get the required resolution?
Look up 'over the horizon radar', a cold war technology. They used pulse widths very long so a signal would go out and it was a low frequency, say 20 mhz, and the PRF was like 1/30th of a second, which gave a range of 186,242/30, about 6000 miles in that case. But if the PRF was faster, the return pulse would come back too many times and interfere with the outgoing pulses, so they had to have proper timing of the PRF (pulse recurrence frequency). The accuracy was related to the pulse width because, say you are looking at an aircraft, say a 747 which is something like the size of a football field. If you want to be able to get a radar visualization of that beast you need to have the pulse width a lot shorter than the size of the craft, if you have a relatively long pulse width the return would be muddled, the front of the craft and the back of the craft would come back together, there wouldn't be a way to tell the difference between the front of the craft and the back, you need to visualize the field front as it leaves the transmitter, it wouldn't matter if it was 100 mhz or 1 billion hertz if the pulse width was too long the front and back of the pulse would come back to the receiver and you can't tell the difference.
Overall resolution is related to the carrier frequency because you can only at best transmit one cycle and if the frequency is one mhz, a wavelength of 300 meters, even if you could only transmit one cycle you can't get better than 300 meters of resolution with that wavelength. If you send out 300 mhz, a wavelength of 1 meter, that is the max resolution even with one cycle of send pulse. So to get 1 mm resolution you need 300,000 mhz minimum frequency otherwise the front of an object and the back of the object would be sending signals back mixed together and can't recover information smaller than the wavelength of the sending pulse. So 1 mm resolution would require a single cycle pulse of 300 ghz, not sure if you can actually even generate a single cycle of that high a frequency. With light, you are in the hundreds of thousands of ghz so you don't have to send out, say, a single photon, you would send out a signal with many wavelengths together and the resolution would then be the composite size of the entire wavefront, say your sending out light at 1 micron, an IR frequency, and you send out 1000 cycles, then you would get your 1 mm accuracy. The size of the wavefront in that case would be about 1 mm long, which would be a pulse width of 1 picosecond. 1 meter at c is about 1 nanosecond so 1/1000 of a meter, 1 millimeter, would be 1 picosecond.
Don't know enough about the electronics to say if they can arrange a pulse width of 1 picosecond though. 1 cycle of 1 micron would be about 1 femtosecond long. I'm pretty sure there are laser systems that can give something like that cycle time but they are not going to be suitable for field use, more like laboratory specialty items for probing states of matter and such. There are actually sub femtosecond laser probes out there but you have to use higher frequencies, say 100 nm, where one photon would be 100 attoseconds long in time.
for your question!
There are several advantages of using UWB (Impulse) radar over pulsed radar. First, UWB radar has a much higher range resolution due to its extremely short pulse duration. This allows for better detection and identification of close-range targets, especially in cluttered environments. Additionally, UWB radar can provide higher accuracy in distance measurement due to its ability to accurately measure time-of-flight between pulses.
Another advantage of UWB radar is its ability to operate in a wider frequency band, which allows for better penetration through obstacles such as walls and foliage. This can be particularly useful in applications such as through-wall imaging or underground mapping.
Furthermore, UWB radar has a lower peak power requirement compared to pulsed radar, making it less susceptible to interference and easier to integrate into existing systems. This also results in lower electromagnetic interference, making it a more environmentally friendly option.
Overall, the high bandwidth and short pulse duration of UWB radar offer many advantages in terms of range resolution, accuracy, and interference reduction. However, as you mentioned, these systems can be more difficult to design and implement, but the benefits they offer make them a valuable tool in various applications.
Related to UWB (Impulse) radar advantages over Pulsed radar
What is UWB radar and how does it differ from pulsed radar?
UWB (Ultra-Wideband) radar is a type of radar system that uses short, low power pulses of electromagnetic energy to detect and track objects. Unlike pulsed radar, which uses longer pulses of energy, UWB radar emits very short pulses that are spaced closely together, resulting in a wider bandwidth of frequencies being transmitted.
What are the advantages of UWB radar over pulsed radar?
UWB radar offers several advantages over pulsed radar, including higher resolution, increased accuracy, and the ability to detect smaller objects. The short pulses used in UWB radar also allow for better target discrimination and reduced interference from other radar systems. Additionally, UWB radar can operate in crowded environments without causing interference to other systems.
How does UWB radar provide better resolution compared to pulsed radar?
The shorter pulses used in UWB radar allow for a higher range resolution, meaning that objects can be detected and located with greater precision. This is because the shorter pulses are able to distinguish between objects that are closer together, whereas longer pulses tend to blur together and make it more difficult to accurately locate a target.
Can UWB radar detect objects that pulsed radar cannot?
Yes, because UWB radar uses a wider bandwidth of frequencies, it is able to detect smaller objects that may not be detectable by pulsed radar. This makes UWB radar particularly useful for applications such as ground-penetrating radar, where the detection of small objects or variations in soil composition is important.
Are there any limitations to using UWB radar over pulsed radar?
While UWB radar offers many advantages, it does have some limitations. For example, UWB radar is usually limited to shorter range applications compared to pulsed radar. Additionally, UWB radar can be more expensive and complex to implement, making it less suitable for some applications where cost and simplicity are important factors.
  • Quantum Physics
23K
