Power output of an anchored propeller
In summary: Hi Leon (AW). So you have turned your propeller to point vertically upwards, like a simple helicopter or powered gyrocopter, and wish to calculate the lift it produces? I reckon a google search should turn up a lot of useful information, you surely wouldn't be the first to ponder this!Good luck, and Happy Easter!
Leon (AW)
I have a motore with a propeller anchored to a load cell to measure the lift produced at varying power inputs. This is for a student activity I am running and I wanted to show that though more power in gives more lift there is a point after which efficiencey starts to go down again so I tried to also calculate the power output of the propellers to get the efficiency of the blades.
***Edit***:Thought of a better way of explaining this. if it was a fixed wing I would move it D distance in T time generating F force and my power would be F*D/T. but for a rotating blade the distance D it moves in T time depends how close to the end you are and I can't figure out how to calculate ecounting for that.
Any help would be great thanks.
***old thoughts***
I thought at first the propelor would effectively have potential energy as it applies a constant force like gravity does but the energey in goes up by time where the potential goes up by time squared.
I tried to calculate the speed it would have if not anchored by picking an arbitrary time and deviding by the mass however as you can see from the attachment that's wrong as it would accelerate for ever so the power out increases with time while the power in stays the same.
Any idea how I can work this?
Should my speed be the rotational speed of the propeller maybe? (or would that just give me the power output of the motor).
maybe I need to calculate the volumetric air flow from pressure (getting pressure from force and propeller area) and take speed from that.
I have googled it for hours but everything I have found either requires it moves or only measures forces. I likely have all the equations I need to figure this out I'm just not making the link somewhere between two of them. That's why I came here to see if anyone can point out the bit I am missing that will be obvious once I know it.
I'm usually pretty good with figuring this stuff out but I'm just drawing a blank this time and can't find an example online. I think it is because I am so used to figuring out power by measuring velocity and calculating out the force to put into a power equation whereas this time I am measuring the force and trying to calculate the velocity. Every time I try I get the power increasing with time.
So you are trying to build a efficiency curve, right?
satchurated said:
So you are trying to build a curve off efficiency
Yes, I know the power in but I can't figure out how to calculate power out.
You mean thrust..
satchurated said:
You mean thrust..
It is chained to a load cell I can read thrusting force of the screen. what I want is, knowing the mass of the object, how much power will that thrust be worth if i were to cut the chain.
if I cut the chain I could measure it's speed and calculate the thrust from it's mass. with the chain I can measure it's thrust so how do I calculate it's potential speed from it's mass.
If you're studying the dynamics of a multirotors, speed is not so important as you think
More power in will continually give more thrust (up to a limit) however the peak efficiency, where the law of diminishing returns starts to kick in, is not obvious on a power to thrust graph. It is obvious on a power into power out graph though.
One thing is power to thrust, which is different to speed as you talk. The force is not calculated as above, but in a way more complex because thrust needs to take into account the weight
If it's stationary, power out is zero :)
Alternatively, you could calculate the power in the fluid jet, which would be 0.5 times the mass flow rate of the fluid times the square of the jet velocity (and you'd have to somehow measure or estimate the jet velocity and mass flow rate). There is no simple conversion purely based on thrust though.
1. What factors affect the power output of an anchored propeller?
The power output of an anchored propeller is affected by several factors, including the size and shape of the propeller, the speed and direction of the water current, and the weight and design of the anchor.
2. How is the power output of an anchored propeller measured?
The power output of an anchored propeller is typically measured in watts or horsepower. This can be calculated using the formula P = T * ω, where P is power output, T is torque, and ω is angular velocity.
3. Can the power output of an anchored propeller be increased?
Yes, the power output of an anchored propeller can be increased by optimizing the design of the propeller, using a more powerful motor, or increasing the speed and direction of the water current.
4. What are the advantages of using an anchored propeller for power generation?
Anchored propellers are a reliable and efficient source of renewable energy. They can be used in various water environments and do not require a large infrastructure, making them a cost-effective option for power generation.
5. Are there any limitations to the power output of an anchored propeller?
Yes, there are some limitations to the power output of an anchored propeller. These include the size and strength of the propeller, the depth and speed of the water current, and potential interference from other objects in the water.
  • General Engineering
  • Electrical Engineering
  • Aerospace Engineering
10K
  • Electromagnetism
  • Mechanical Engineering
