Moments & Pendulum: Different Lengths, Same Oscillation?
In summary, the conversation discusses the relationship between forces, moments, and the time it takes for a pendulum to complete one oscillation. It is explained that the addition of the moments of two forces acting at different angles is equal to the moment of the net force. The use of moments is also used to explain why a longer pendulum will have a longer period compared to a shorter one. This is because the distance the pendulum has to cover to complete one oscillation is longer, resulting in a longer period. An approximation using small angles is also mentioned to explain this relationship.
sgstudent
739
if i have two forces acting at two different angles at a same spot will the addition of the moments of the two forces be the same as the moment whereby i take the net force of the two forces and get the moment of the net force of the same two forces?
is there a way to explain why for the same mass of the bob, two different lengths of the pendulum will have different times to have a complete oscillation using moments to explain it. Thanks for the help!
hi sgstudent! :smile:
yes … r x a + r x b = r x (a + b) :wink:
yes, the moment tells you the angular acceleration :smile:
Thanks tiny Tim. However, I don't really know the explanation using moments on why a longer pendulum will have longer periods than shorter ones. Since they are longer so won't their moment be greater? Thanks! :smile:
The longer the pendulum, the longer the distance it has to cover to complete one period. Why would you think the time to cover this longer distance would be shorter?
If you want a detailed answer:
Suppose the pedulum has mass m centered at distance L from the pivot. There is a downward force of strength -mg. But the pendulum mass can only move around the circumference of the circle or radius L and the component of force parallel to the circumference is [itex]-mg sin(\theta)[/itex] where [itex]\theta[/itex] is the angle the pendulum makes with the vertical.
If we measure [itex]\theta[/itex] in radians, the angle [itex]\theta[/itex] corresponds to a distance around the arc of [itex]s= L\theta[/itex] and so the linear velocity is [itex]v= ds/dt= L d\theta/dt[/itex] and the acceleration is [itex]a= dv/dt= L d^2/theta/dt^2[/itex]. Since "mass times acceleration= force", the motion is given by
[tex]ma= mL d^\theta/dt^2= -mg cos(\theta)[/tex]
That is a badly "non-linear" equation so there is no simple exact solution but there are a number of ways to approximate it. One is to note that for small angles, [itex]cos(\theta)[/itex] is approximately [itex]\theta[/itex] itself so we can approximate the equation by
[tex]mLd^2\theta/dt^2= -mg\theta[/tex]
That is a second order linear equation with constant coefficients. It has "characteristic equation" [itex]Lr^2=-g[/itex] which has "characteristic roots" [itex]\pm\sqrt{g/L}[/itex]. That, turn, tells us that two independent solutions are [itex]sin(\sqrt{gt/L}[/itex] and [itex]cos(\sqrt{gt/L}[/itex]. That will have period given by [itex]gt/L= 2\pi[/itex] so that [itex]t= 2L/g[/itex] which is directly proportional to L- the larger L, the longer the period.
I can confirm that the addition of the moments of two forces acting at different angles at the same spot will not be the same as the moment of the net force of the same two forces. This is because moments are calculated by multiplying the force by the distance from the pivot point, and the distance will be different for each of the two forces.
Regarding the question about the different lengths of a pendulum having different times for a complete oscillation, this can be explained using moments. The time for a complete oscillation of a pendulum is dependent on the length of the pendulum and the acceleration due to gravity. The longer the pendulum, the larger the moment of inertia, which means it takes longer for the pendulum to complete one oscillation. This is because the longer pendulum has a larger distance from the pivot point, resulting in a larger moment of inertia.
Additionally, the moment of inertia also affects the period of oscillation of the pendulum. A longer pendulum will have a longer period of oscillation compared to a shorter pendulum with the same mass. This can be explained by the equation T=2π√(I/mgL), where T is the period, I is the moment of inertia, m is the mass, g is the acceleration due to gravity, and L is the length of the pendulum.
In summary, the different lengths of a pendulum will have different times for a complete oscillation due to the differences in their moments of inertia, which is dependent on the length of the pendulum. I hope this explanation helps.
1. How does the length of a pendulum affect its oscillation?
The length of a pendulum affects its oscillation by changing the time it takes for the pendulum to complete one full swing, also known as its period. The longer the pendulum, the slower its period, and the shorter the pendulum, the faster its period. This is due to the relationship between the length of a pendulum and the force of gravity acting on it, known as the pendulum's period equation.
2. What is the relationship between the length of a pendulum and its period?
The relationship between the length of a pendulum and its period is described by the pendulum's period equation: T = 2π√(L/g), where T is the period in seconds, L is the length of the pendulum in meters, and g is the acceleration due to gravity (9.8 m/s²). This equation shows that the longer the pendulum, the slower its period, and the shorter the pendulum, the faster its period.
3. Can two pendulums with different lengths have the same period?
Yes, two pendulums with different lengths can have the same period. This phenomenon is known as isochronism and was first discovered by Galileo Galilei. It is possible for pendulums with different lengths to have the same period if the ratio of their lengths is equal to the square root of the ratio of their gravitational acceleration. For example, a pendulum with a length of 1 meter and a pendulum with a length of 4 meters will have the same period because 4/1 = √4/√1.
4. How does the angle of release affect the oscillation of a pendulum?
The angle of release does not affect the oscillation of a pendulum. According to the law of conservation of energy, the total energy of a pendulum remains constant throughout its motion. This means that the angle of release does not affect the period or the amplitude (distance from the center) of the pendulum's swing. The only factors that affect the oscillation of a pendulum are its length and the force of gravity.
5. Can a pendulum with a shorter length have a longer period than a pendulum with a longer length?
No, a pendulum with a shorter length cannot have a longer period than a pendulum with a longer length. According to the pendulum's period equation, the length of the pendulum is directly proportional to its period. This means that the longer the pendulum, the longer its period, and the shorter the pendulum, the shorter its period. Therefore, a pendulum with a shorter length will always have a shorter period than a pendulum with a longer length.
  • Mechanics
  • Mechanics
