Composite numbers and divisibility (2 problems)
And, HallsofIvy, I can't use that the product of three consecutive numbers is divisible by 6, because that's what I'm trying to prove in the first place. But I'll try the other one, thanks.In summary, the first problem involves proving that n3 - n is divisible by 6 if n is a natural number, and by 24 if n is an odd natural number. This can be solved by splitting into two cases, where n is even and n is odd, and using factorization and the fact that the product of three consecutive numbers is divisible by 6. The second problem involves showing that if n is a composite number, it has a divisor greater than or equal to n
Hannisch
116
First of all, I hope this problem is supposed to be here - I'm Swedish and in Sweden "calculus" & "precalculus" are rather odd terms. Anyway..
Prove that n3 - n is divisible by 6 if n is a natural number, and divisible by 24 if n is an odd natural number.
There were two problems similar to this before this one and I attempted to solve it in the way I solved those (and the way the book solved them, as well), which was to split n into its even case and odd case.
Even case:
n = 2k
(2k)3 - 2k = 8k3 - 2k , which obviously didn't help me much. But, as I'd used earlier for previous exercises, k can either be even or odd. If k is, say, even, k = 2s
8(2s)3 - 2(2s) = 64s3 - 4s .. and I can continue on, but nothing is divisible by 6..
And I've done the same for k = 2s + 1, which also doesn't work out. And I tried the odd case I mentioned earlier (n=2k +1) and that doesn't work out and I'm so close to screaming in frustration it's not even funny..
Show that if n is a composite number it has a divisor greater than or equal to n½.
My problem is that, yes, I absolutely and completely agree with the statement due to logic, but I've not a clue where to start the proof.. I'm not asking for someone to show me the proof, but a tip as to where to start?
Try proof by induction
assume true for n=k
Hk: k3-k=6A (A= integer)
so Hk+1=(k+1)3-(k+1)
expand and see if you can use k3-k=6A to show that Hk+1 is 6*something.
I wanted to use mathematical induction, but we're not supposed to have learned it yet (I just started a course at university, and we did induction at my previous school).
And so, I tried MI, with the result: 6A + 3k2 + 3k .. divisible by 3, but not by 6.
This problem is behaving very strangely, because at the same time I can plug in numbers and see that it is in fact true x/
Make a substitution k=k3-6A, and see what you will come up with. :smile:
6A+3(k3-6A)2+3(k3-6A) ?
For the divisible by six, did you try just factoring the expression? Then your subbing in trick (2k+1) will work for the second half.
For your second proof (that a composite number has a factor greater than [tex]\sqrt{n}[/tex], did you try contradiction?
Even case:
n = 2k
Well, as pointed out by rock.freak667 in some earlier post, Proof of Induction can be used here.
But, if you really want to solve the problem by splitting up into 2 cases, where n is even, and n is odd, you can try to factor. Like this:
Even case:
n = 2k
Notice that the final expression is already divisible by 2, so what's left is to prove that the rest is divisible by 3. And it's done. So,
= 2(4k3 - k)
= 2k(4k2 - 1)
= 2k(2k - 1)(2k + 1)
Look at the final expression, can you see why it's divisible by 6?
Hint:
- Is it divisible by 2? Why?
- Is it divisible by 3? And why?
And for the case where n is odd, you can tackle it in pretty much the same manner. Let's see if you still get suck. :)
If n is a composite number, then there must exists some number a, and b, such that: n = ab, right? :)
Now, let's do a little bit thinking, can both a, and b be less than n½?
I wouldn't use induction.
[itex]n^3- n= n(n^2- 1)= (n-1)n(n+1)[/itex], the product of three consecutive numbers. You should show that, of any three consecutive numbers, at least one must be even and at least one must be a multiple of 3 so their product is a multiple of 6.
If n is odd, then both n-1 and n+1 are even. Further, of two consecutive even numbers, 2k and 2k+2, one is a multiple of 4. (Look at the cases where k is even or odd.)
Thanks for that last thing, that's exactly what I needed! :)
And no, both a and b can't be less than n½, because there's no way it could become n. The thing is, I fully understand the logic, that either it's n½ * n½ or a>n½ * b<n½ (or the other way around, obviously).. but I can't get how to put it in mathematical language ..
Ok, that's what we call http://en.wikipedia.org/wiki/Proof_by_contradiction" , i.e, you are asked to prove some statement P. Now, you assume that you don't have P (i.e, P is false), and from there, try to find the contradiction.
So, start from assuming that: "that composite number has a divisor greater than or equal to n½" is a false statement. Can you write out the negation of that statement? And then, what happens?
Oh yeah, I'd completely forgotten Proof by Contradicton.. hum. We never focused on it much.
Anyway, I'd say something like:
n=ab, a<n½, b<n½
so, n < n½ * n½, but since it's the same base, n½ * n½ should be n1, and there's our contradiction.
That's at least how I remember proof by contradiction..
1. What is the definition of a composite number?
A composite number is a positive integer that can be divided evenly by at least one other positive integer, in addition to 1 and itself.
2. How can you determine if a number is composite or prime?
A number is composite if it has more than two factors, while a prime number only has two factors (1 and itself). To determine if a number is composite, you can try dividing it by every number from 2 to the square root of the number. If any of these divisions result in a whole number, then the number is composite.
3. What is the smallest composite number?
The smallest composite number is 4, as it can be divided evenly by 1, 2, and 4.
4. How can you find all the factors of a composite number?
To find all the factors of a composite number, you can use a factor tree or list out all the possible combinations of numbers that multiply to equal the composite number. For example, the factors of 12 are 1, 2, 3, 4, 6, and 12.
5. How do you know if a number is divisible by another number?
A number is divisible by another number if the remainder of the division is 0. This can also be shown using the division symbol, where the number on the left is the dividend and the number on the right is the divisor. If the result is a whole number, then the number is divisible by the other number.
