What is the reason that 1/x is not lebesgue integrable?
  • Thread starter onthetopo
  • Tags
    Reason
In summary, the reason why 1/x is not Lebesgue integrable on [0,1] while 1/x^2 is integrable is because 1/x^2 is bounded on the compact set [0,1] and therefore satisfies the Riemann integrability condition, making it Lebesgue integrable. However, 1/x is not bounded on [0,1] and does not satisfy the Riemann integrability condition, thus making it non-Lebesgue integrable. This can be proven using the theorem that states if a positive function is Riemann integrable on a compact set, it must also be Lebesgue integrable.
onthetopo
35
What is the reason that 1/x is not lebesgue integrable where as 1/x^2 is integrable. You can use any theorems: monotone convergence, dominated convergence you want.
Integrable where?
Probably in some unbounded region not containing zero; if the region contains zero then 1/x2 is not integrable, and if the region is bounded and does not contain zero, both are integrable.
[0,1]
Both 1/x and 1/(x^2) are not lebesgue integrable on [0,1]?
I thought 1/(x^2) is while 1/x isn't
Let X be a subset of R, let f(x)=x^-1, and g(x)=x^-2. If both f and g are bounded on X, this implies that X does not contain 0, implying that both f and g are continuous on X. Thus f and g are measurable on X. Furthermore, if X is compact and does not contain zero, things get much nicer, as the Riemann integrals are guaranteed to be finite, implying that the function must be Lebesgue integrable.
In general, let K be a compact set. If f, a positive valued function is Riemann integrable on K then, f belongs to L_1[K] (Lebesgue integrable on K). This is a nice theorem to use when one is trying to prove that a function is Lebesgue integrable( Using the fundamental theorem of calculus). However, if K=[0,1], both x^-1, and x^-2 are non Riemann integrable on the compact set [0,1]. So this does not help much.
In fact both 1/x and 1/x^2 are non Lebesgue integrable on [0,1]. I will just prove that 1/x is non Lebesgue integrable on [0,1] as the second case is very similar.
Proof:
Let A=[a,a+e], where a in [0,1], and e is small enough such that A is included in [0,1]. Now, let X_A be the characteristic function of A. Let us defined phi(x)=((a+e)^-1)X_A. phi is a simple function thus the Lebesgue integral of phi is equal to m(A)((a+e)^-1)=e((a+e)^-1), since m(A)=a+e-a=e. We observe then, that the integral of phi depends on the value of a in [0,1]. Now let a converge to 0, then the Lebesgue integral of phi converges to infinity. Now, we know that both phi and f belongs to L+ which is the set of all the positive measurable functions not necessarily Lebesgue integrable though. Also, we know that for any x, 1/x >= phi(x), thus, int(1/x)>=int(phi(x))= infinity. Hence 1/x is non-Lebesgue integrable.
Vignon S. Oussa
Well, 1/x2 ≥ 1/x on (0, 1].
Even better, in the extended real number set, 1/x2 ≥ 1/x on [0, 1].
Thanks for the reply. But on the extended real set, 1/x=1/x^2 at x=0 right. both are equal to +inf
I think the crucial step in your proof is 1/x >= phi(x)
where phi(x)=((a+e)^-1)X_A
May I ask why? This is a myth to me.
Ok let me clarify then. Take any x in (0,1].
Case1: if x does not belong to A,
phi(x) =((a+e)^-1)X_A(x)=((a+e)^-1)0=0
f(x)=1/x. Thus f(x)> 0 ---> f(x) = phi(x)
Case2: if x does belong to A
phi(x) =((a+e)^-1)X_A(x)=((a+e)^-1)1=((a+e)^-1)
x is in [a,a+e] thus x<=a+e, implying that 1/x >=((a+e)^-1). Thus f(x)>=((a+e)^-1)=phi(x) when x belongs to A
In conclusion, in either case we must always have f(x)>=phi(x) when x is in (0,1]. I hope I cleared things up for you
Vignon S. Oussa
both statements with " = " or ">= "are equivalent statements. Remember from logic theory that (True OR False) is equivalent to True.
Vignon S. Oussa
The lebesgue integral of phi = e/(a+e), no? So letting a -> 0 shows that the integral of phi goes to 1, not infinity.
It's considerably easier just to take the anti-derivatives: ln |x| and -1/x. These don't behave well as x approaches 0.
1. Why is 1/x not Lebesgue integrable?
The function 1/x is not Lebesgue integrable because it does not satisfy the Lebesgue integrability criterion. This criterion states that for a function to be Lebesgue integrable, its integral must be finite. However, the integral of 1/x from 0 to 1 is infinite, making it not Lebesgue integrable.
2. What is the Lebesgue integrability criterion?
The Lebesgue integrability criterion is a condition that a function must satisfy in order to be considered Lebesgue integrable. It states that the integral of the function over a given interval must be finite for the function to be Lebesgue integrable.
3. Can 1/x be Riemann integrable?
No, 1/x is not Riemann integrable either. This is because the Riemann integrability criterion also requires the integral of a function to be finite, and as mentioned before, the integral of 1/x from 0 to 1 is infinite.
4. What is the difference between Lebesgue integrability and Riemann integrability?
The main difference between Lebesgue integrability and Riemann integrability is the criterion that each uses to determine if a function is integrable. While the Lebesgue integrability criterion only requires the integral to be finite, the Riemann integrability criterion also requires the function to be bounded. This means that a function can be Lebesgue integrable but not Riemann integrable.
5. Are there other reasons why a function may not be Lebesgue integrable?
Yes, there are other reasons why a function may not be Lebesgue integrable. For example, a function may not be Lebesgue integrable if it has an infinite number of discontinuities or if it oscillates too rapidly. These conditions can also cause the integral of a function to be infinite, making it not Lebesgue integrable.
  • Calculus
  • Topology and Analysis
