Rat of reaction problems i have no idea how to do
In summary, the rate of a certain chemical reaction carried out at 45C is observed to be 280M/s. It is not possible to determine the rate of the reaction at 55C without additional information, but a rule of thumb states that the reaction will get twice as fast for every 10C increase in temperature. However, this is only an approximation of the actual rate.
alesia070
A certin chemical reaction is carried out at 45C and the rate observed is 280M/s. What will the rate of the reaction be at 55C?
i have no idea what equation to use for this problem could someone break it down for me step by step
In general this type of questions is solved with Arrhenius equation. However, you are not given enough information to use it.
My bet is that you are expected to use a rule of thumb that states that reaction gets twice faster when temperature grows by 10 deg C. Just remember that this is an approximation of approximation :wink:
it is important to have a strong understanding of the principles and equations involved in chemical reactions. In this case, we can use the Arrhenius equation to determine the rate of the reaction at a different temperature.
The Arrhenius equation states that the rate constant (k) of a reaction is directly proportional to the temperature (T) and the activation energy (Ea), and inversely proportional to the pre-exponential factor (A). It can be written as:
k = A * e^(-Ea/RT)
Where R is the gas constant (8.314 J/mol*K).
To solve this problem, we need to rearrange the equation to solve for the rate constant (k). This can be done by taking the natural logarithm (ln) of both sides:
ln(k) = ln(A) - (Ea/RT)
Now, we can substitute the given values into the equation. At 45C, the rate observed is 280M/s. This will be our k value. The temperature (T) is given as 45C, which we need to convert to Kelvin (K) by adding 273.15. So, T = 318.15 K. The activation energy (Ea) is not given, so we will assume a value of 50 kJ/mol. The pre-exponential factor (A) is also not given, so we will assume a value of 1.
Substituting these values into the equation, we get:
ln(280) = ln(1) - (50,000/8.314*318.15)
Solving for ln(280), we get:
ln(280) = -8.6
Now, we can use this value to solve for the rate constant (k) at 55C. We will use the same equation, but with a temperature of 55C (T = 328.15 K):
ln(k) = -8.6 - (50,000/8.314*328.15)
Solving for ln(k), we get:
ln(k) = -8.4
To get the value of k, we need to take the inverse natural logarithm (e^x) of both sides:
k = e^-8.4
Solving for k, we get:
k = 0.0002 M/s
Therefore, the rate of the reaction at 55C will be
1. What is a rate of reaction problem?
A rate of reaction problem involves determining the speed at which a chemical reaction occurs. It is usually measured in terms of the change in concentration of a reactant or product over time.
2. How do you calculate the rate of a reaction?
To calculate the rate of a reaction, you need to determine the change in concentration of a reactant or product over a specific time interval. This can be done by dividing the change in concentration by the corresponding change in time.
3. What factors affect the rate of a reaction?
The rate of a reaction can be affected by several factors, including temperature, concentration of reactants, surface area, and the presence of a catalyst. These factors can either increase or decrease the rate of a reaction.
4. How do you graph a rate of reaction problem?
To graph a rate of reaction problem, you need to plot the change in concentration over time on a graph. The slope of the line on the graph represents the rate of the reaction at that particular time interval.
5. Can you provide an example of a rate of reaction problem?
Sure, an example of a rate of reaction problem would be determining the rate of the reaction between hydrochloric acid and magnesium. This can be done by measuring the change in concentration of hydrogen gas over time as the reaction takes place.
  • Science Fiction and Fantasy Media
  • Materials and Chemical Engineering
