Newton's 3rd law not applicable to megnetic forces?
In summary, it seems that the professor at MIT has made a claim about magnetic forces that is not quite true.
mdeng
68
I just read the following from http://www.physicstoday.org/vol-57/iss-10/p11.html . Could anyone shed some details about the claim? Coming from a professor at MIT, it must be true.
Newton's third law states that for every action there's an equal and opposite reaction. Also, we generally assume that forces do not depend on velocity. Neither of those assumptions is quite true either; for example, they fail for magnetic forces between charged particles.
The magnetic force acting on an object depends explicitly on the object's velocity:
[tex]\vec F_{mag} = q \vec v \times \vec B[/tex]
Also, the magnetic forces exerted by two moving charges on each other are in general not equal in magnitude and opposite in direction. We account for this by assigning momentum to the electromagnetic field. The momentum per unit volume due to the electromagnetic field is
[tex]\vec g = \epsilon_0 \vec E \times \vec B[/tex]
See for example
http://farside.ph.utexas.edu/teaching/em/lectures/node90.html
http://farside.ph.utexas.edu/teaching/em/lectures/node91.html
In classical mechanics (excluding electromagnetism), Newton's Third Law is equivalent to conservation of total momentum. When electromagnetic forces are involved, the total momentum of the particles is not conserved. However, the total momentum of the partlcles and the electromagnetic field is conserved.
You can think of "momentum" as tiny balls that are "thrown" from one object to the other.
What one object loses, the other gains.
Or, that would be true if there was an INSTANTENOUS transmission of the tiny momentum ball.
This is true for the so-called "contact force interactions".
However, the electro-magnetic forces are NOT contact forces, and there is a non-zero timelag where the tiny ball of momentum lies in the electric field in between the two objects.
This, of course, is a pictorial description of the situation..
Jtbell, thanks for the pointers and your helpful summary.
It's interesting to see that the emitter of an electromagnetic wave is subject to a negative momentum change of value equal to that of the electromagnetic wave. What kind of electromagnetic radiation would be "unidirectional" to cause its emitter to move backwards? Ordinary electromagnetic radiation is outward toward all directions.
Thanks for the insights. I gather then the same goes for quantum particles that are subject to the strong force.
Possibly the trouble with the lack of a magnetic dipol isn't as much dependen on the concept "force", which is just a mathematical idea for the energy derivative in space.
- On the one hand the magnetic field in a solid like iron is the result of spin couplings.
- On the other hand it apears with electromagnetic waves and current flows in rings.
Would be interesting to find similarities or a superior explanation for these two systems ending up with the same force (effect).
Does anyone have an idea?
I wouldn't call it "radiation" which implies that the energy escapes to infinity. Most books (and those lecture notes) discuss electromagnetic field energy and momentum in the context of electromagnetic waves because that's a very practical application. But the field energy and momentum also exist in any other situation where [itex]\vec E \times \vec B[/itex] is nonzero (for momentum) and [itex]E^2 + B^2[/itex] is nonzero (for energy). Just calculate the total [itex]\vec E[/itex] and [itex]\vec B[/itex] at any given moment (produced for example by two charges moving past each other) and calculate the energy and momentum from those.
Isn't there a big, big difference between the two appearances of a magnetic field as I wrote above and the electrical and magnetical field vectors as the amplitude of electromagnetic waves?
I regard the E and B vector in an electromagnetic wave as the possibility or the potential to couple and interact with matter. Or does anyone here knows an example where B, let's say of light, really has an effect in such a way that a particle gets attracted, just because of the presence of a light beam?
1. What is Newton's 3rd law?
Newton's 3rd law states that for every action, there is an equal and opposite reaction. This means that whenever an object exerts a force on another object, the second object exerts an equal and opposite force back.
2. Why is Newton's 3rd law not applicable to magnetic forces?
Newton's 3rd law is not applicable to magnetic forces because they are not considered to be contact forces. Unlike physical forces such as pushing or pulling, magnetic forces act at a distance and do not involve direct contact between objects.
3. How do magnetic forces follow different rules than Newton's 3rd law?
Magnetic forces follow the rules of electromagnetism, which is a branch of physics that deals with the interactions between electrically charged particles. These rules are different from the rules of motion and forces described by Newton's laws.
4. Can you give an example of a magnetic force that does not follow Newton's 3rd law?
One example of a magnetic force that does not follow Newton's 3rd law is the force between two parallel wires carrying electric current in the same direction. According to Newton's 3rd law, the two wires should experience equal and opposite forces, but in this case, they experience forces in the same direction.
5. How is the concept of action and reaction still relevant in understanding magnetic forces?
Although Newton's 3rd law may not directly apply to magnetic forces, the concept of action and reaction is still relevant in understanding these forces. For example, when a magnet attracts an object, the object is also exerting a force on the magnet in the opposite direction. This shows that there is still a mutual interaction between the two objects, even if the forces are not equal and opposite.
