Understanding Calculus: Derivatives, Tangents, and Slopes
In summary: No, sorry. Its just whenever I thought of Tangent, I thought it was the slope which was rise over run (Y / X). I clearly don't have much understanding here and you're acting more like a teacher rather someone to answer my question which I really appreciate by the way. So its good to think of surrounding the... slope with some other terms to help me understand it better.
zeromodz
246
Okay, I am new to calculus so can you guys just explain something to me.
What is exactly are you doing to a function when you differentiate or take the derivative of it? I thought that when you do that, you make an instantaneous solution to where something is at all times with respect to the other axis. Is that correct?
Also, whenever you see calculus in advanced physics, I don't understand. You can only use indefinite integrals and derivatives when you have a valid function right? So all these advanced physics problems need functions to go along with them right?
Thank you guys!
Hmm..
Try to formulate what the following quantity is, for non-zero h:
[tex]\frac{f(x+h)-f(x)}{h}[/tex]
Hint:
Draw an arbitray graph, pick two points on the x-axis ("x" and "x+h"), and think of h=(x+h)-x
arildno said:
Hmm..
Hint:
This formula gives you the difference of Y over X. In other words, it gives you a tangent line over the 2 points you select. Right? Thats what it does.
The derivative of a function is another function that gives the slope of the tangent line to the graph of the first function.
Well of course. In order to differentiate a function or find the antiderivative of one, you need a function to operate on.
Okay thank you so much. I understand this a lot better now.
Yes. And?
No, it does not.
a) First off, what do you call a straight line going through two points on the graph?
b) What, EXACTLY, is the QUANTITY you calculate?
A line is not a "quantity" in this sense!
arildno said:
No, it does not.
a)A secant line! sorry, I just knew that I just put tangent line down for some reason.
b) You are calculating the area under the curve?
zeromodz said:
a)A secant line!
Yes it is! :smile:
Is the area under the curve equal to the ratio between the difference of Y-values and X-values??
If not, what geometric interpretation does this ratio have?
arildno said:
Yes it is! :smile:
The ratio of Y over X is tangent. Since the derivative of tangent is sec^2, that is why i get a secant line right? Also, the formula [tex]\frac{f(x+h)-f(x)}{h}[/tex] is what gives you the area under the curve? Sorry I am evading your question with another, just trying to clear things up.
Ok.
Now I get some of your problems.
No, the calculated number will not be "tangent" to the curve here, but it WILL give you the tangent value associated with the angle formed by the secant line and the horizontal line formed at the point (x,f(x)).
You have a natural triangle here in the (x,y)-plane, with corners:
(x,f(x)), (x+h,f(x)) and (x+h,f(x+h))
We usually call that ratio the slope of the line.
Have you heard that expression?
arildno said:
Ok.
No, sorry. Its just whenever I thought of Tangent, I thought it was the slope which was rise over run (Y / X). I clearly don't have much understanding here and you're acting more like a teacher rather someone to answer my question which I really appreciate by the way. So its good to think of surrounding the angle with a triangle and then finding out the tangent angle of the triangle?
No, let us forget about that angle for now. Okay?
1. The most important to remember about that slope, is that it tells you how steep the secant line is between the two points on the graph. Agreed?
2. Now, a tangent line at some point on the graph is that line which a) intersects with graph there, and b) is equally steep as the curve itself there.
3. When you perform the limiting operation (letting h be smaller and smaller) in order to calculate the derivative, you are simply calculating the slopes of successive secant lines and, in the end, when your two points overlap (h=0), sit back with the slope of the tangent line at (x,f(x)), i.e, the slope of the curve itself
4. So, the derivative at some point tells you how steep the curve is at that point.
Okay thank you so much. I am going to take this info and start reading more about it. If I have any questions I will reply to this or PM you. Thank you so much.
Related to Understanding Calculus: Derivatives, Tangents, and Slopes
1. What is calculus?
Calculus is a branch of mathematics that deals with the study of continuous change and motion. It has two main branches: differential calculus, which studies the rate of change of a function; and integral calculus, which studies the accumulation of quantities.
2. What is the difference between differential and integral calculus?
Differential calculus focuses on the rate of change of a function, while integral calculus deals with the accumulation of quantities. In simple terms, differential calculus helps us find the slope of a curve at a specific point, while integral calculus helps us find the area under a curve.
3. Why is calculus important?
Calculus has many real-world applications and is essential in the fields of physics, engineering, economics, and many other areas. It allows us to model and analyze complex systems and make predictions about their behavior. Many modern technologies rely on calculus, such as computers, GPS systems, and medical imaging devices.
4. What are the basic concepts of calculus?
The basic concepts of calculus include limits, derivatives, and integrals. Limits are used to describe the behavior of a function as it approaches a particular value. Derivatives are used to calculate the rate of change of a function at a specific point. Integrals are used to calculate the area under a curve.
5. What are the common applications of calculus?
Calculus has many applications in various fields, such as physics, engineering, economics, and statistics. It is used to solve problems involving optimization, growth and decay, motion, and many other real-world scenarios. Some specific examples of applications include finding the maximum profit for a business, predicting population growth, and designing efficient structures and machines.
  • Calculus
