^_^physicist
- 235
- 1
Today I was working through a handout my professor gave me on geodesics and stumbled upon the section on semigeodesic parameterization...and then I got lost.
I was able to follow the material through the point where the text points out that the first fundamental form will consist of:
I= E(du)^2 + G*(dv)^2, since the parametrization is orthogonal. The text then moves into an example of how if v were constant the differential equation for the geodesic
u''v'-u'v''+Av'-Bu' = 0 (where A and B's values can be derived from here: http://mathworld.wolfram.com/GeodesicCurvature.html )
becomes
-1/2*[tex]E_v[/tex]/G = 0.
Which makes sense, but then it gives an alternative statement later on that the above equation of the geodesic could also be expressed as
da/dv = - partial((G)^(1/2))/partial(u). Where a is defined as the angle the geodesics intersect the curves v=constant.
Whats worse is this alternative to the above was offered in the "theorems" section of the chapter and doesn't have a proof with it.
So two questions:
1) Wouldn't the angle be pi/2, since in a semigeodesic parameterization any geodesic would be orthogonal to the to the coordinate curves (in this case v=constant)?
2) Where are they getting the alternative expression...is is from Gauss-Bonnet? Or am I just reading the theorem incorrectly. In any case, where the heck is the text coming up with said "theorem." I don't want a proof, I just want a reasonable feel for where the heck they are getting it from. Because from their definations I just don't see the correlation.
becomes
So two questions:
