Current Electricity: Why Does Same Current Pass Through Resistors?
In summary, current is continuous in a loop conductor and is affected by the resistors in a series combination. The voltage drops with each resistor in the series. In a parallel arrangement of two resistors with the same value, the current through both will be the same. Resistors decrease the potential of charges in a current loop by causing collisions that transfer energy from the electrons.
FizixFreak
154
why is current always same for series resistances i mean if a current passes through a resistor a then same current will pass through resistor b does the first resistor not reduces current
Current is continuous through a loop conductor (at least for a DC current or an AC current where the loop size is much smaller than a wavelength). Think of it as beeds on a string being pulled/pushed through a pipe...
Current is the flow of electrons, voltage tells us something about the force on the electrons.
The flow through the whole series is affected by both resistors all at once. The voltage drops with each resister in series.
i m not quite catching up here can you please elaborate
If the current in series combination isn't same everywhere, there'd be accumulation of free electrons at some place and the wire would go on charging up, but the wire must be electrically neutral, and there's no good reason for this not to be true unless in relative motion
I think this is a perfectly reasonable query for a beginner to make.
This is where the hydraulic analogy is appropriate (please don't spoil this thread with discussion other failings of this analogy)
Imagine that your series resistors are like pipes, one after the other.
If you keep pumping water into one end it has to come out of the other or burst the pipes. Of course the longer the pipes the harder you have to pump to push the water through.
Resistors are like this, if you push current into one end it has to come out of the other.
Of course the is something which is lost in passing the resistor. This is the voltage. The greater the resistance the greater the voltage loss.
Yes it does because the voltage across b is now less. Using I=E/R, if the resistance increases (by adding the second resistor), then the current will drop.
okay so i think i got it according to the analogy as the water moves through a pipe with a small diameter that pipe will be considered to offer higher resistance but the same amount of water will flow through the pipe just as it will pass through a pipe of larger diameter right?:confused:
I deliberately didn't mention the pipe diameter, I said longer.
But yes a smaller diameter pipe offers greater resistance to flow than a larger one so you have to pump harder to push the flow through.
Buckethead had a slightly different interpretation of you post and thinking about it he might have been right.
I though you meant putting one resistor after another (hence my comment about pipes).
This is called a series circuit and since there is only one path available all the current that flows into the first resistor , flows out and into the second one and so on, like water in the pipes.
Alternatively if you meant that you have one resistor connected to a supply (battey etc) and you change it for a different one will you get a different current, the answer is yes. The battery voltage will not change (within reason) but the current depends upon the total resistance seen by the battery.
let say i have two resistances in parallel arrangment of the same value now when the circuit is established will the currents through both be the same as the resistances have the same value ?
Yes.
russ_watters said:
Yes.
how do the resistors decrease the potential of the charges in a current loop i mean hoe do these resistors work?
The electrons bump into the materials that make up the resistor. Each collision leeches off energy from the electrons and transfers it as a vibration to the resistor's atomic lattice. This vibration is heat. So the resistors convert the kinetic energy of the electrons to heat via collisions. This is known as the Drude model if you would like to look it up.
Related to Current Electricity: Why Does Same Current Pass Through Resistors?
1. What is current electricity?
Current electricity is the flow of electric charge in a circuit. It is caused by the movement of electrons through a conductive material, such as a wire.
2. Why does current pass through resistors?
Current passes through resistors because resistors are designed to impede the flow of electrons, causing them to slow down and create a voltage drop. This resistance is necessary for proper functioning of a circuit.
3. How is current affected by resistors?
The amount of current that passes through a resistor is directly proportional to its resistance. This means that as the resistance increases, the current decreases, and vice versa.
4. What factors affect the amount of current that passes through resistors?
The amount of current that passes through a resistor is affected by its resistance, the voltage of the circuit, and the type of material the resistor is made of. Temperature can also play a role in the resistance of a material, which can affect the current.
5. Can resistors be used to control the amount of current in a circuit?
Yes, resistors can be used to control the amount of current in a circuit. By adjusting the resistance, you can change the amount of current that flows through a specific part of the circuit, helping to regulate the overall flow of electricity.
  • Electromagnetism
