How fast Coil Springs are? Greatest mystery today?
In summary: If the spring is anchored at one end, the other end is free to move and it will reach its maximum velocity pretty quickly.
  • #36
Q_Goest said:
Perhaps looking at it from the perspective of a spring's natural frequency would help.
A spring, mass system oscilates at a natural frequency equal to √(k/m). As you decrease m, the frequency increases until you have only the mass of the spring itself operating. That frequency is the natural frequency of the spring as given by:
This is from efunda which provides the derivation.
This doesn't give velocity of any portion of the spring directly, but the motion of any point on the spring follows a sinusoidal path.
The highest velocity of any point on the spring then is at the free end of the spring when it passes through that point it would be at when the spring is stationary. That velocity is a function of how far the spring is initially compressed or the amplitude of the movement. The higher the initial compression, the higher the velocity as it passes through its unstressed shape.
I think velocity should be relatively straightforward to derive from this.
I can not do the math, but am very good at feel or whatever you want to call it. The max velocity would come before relaxed state, JMHO Because the last 20% of travel is at much less accelerating force, yet is pushing same mass same distance as the 50-70% extension. In fact maybe the total mass/distance is more.
Just my guess the max velocity would be about 80% of release distance.
  • #37
Hi Lynne, The efunda site I took the above equation from indicates this is the "first natural frequency" for a spring with no mass attached and I've described what I understand that shape to be. This seems to agree with the roymech.co.uk descrition here, so I'm pretty sure we can describe a spring with distributed mass using this equation as I've suggested. But this is getting away from my area of experise. I suspect you could get other modes developing (ie: second, third, etc... natural frequencies) so this assumes the spring will oscillate at its first natural frequency. I assume that's a safe assumption...
To go from frequency to determining position and velocity however is relatively straightforward. First, calculate the angular frequency ω (rad/s), by multiplying frequency times 2π. The position then is basically:
x=A*sin(ωt)
and velocity is:
v=A*cos(ωt)
where A is amplitude, or how far you compress or stretch the spring from its neutral location and t is time in seconds.
That's about it. If you have a specific spring in mind and want to see what this approach predicts for maximum velocity and if you don't feel comfortable doing the math, just provide:
  • wire diameter
  • nominal coil diameter (average of ID and OD)
  • number of coils
  • the generic type of material (ie: steel (includes music wire for example), stainless steel, copper alloy, etc...)
  • How far the spring is compressed from its neutral position before being released
  • #38
homemade said:
Don't know if this helps any but as a machinist I have encountered a condition called "float" many times in race engines. The compressive strength of the spring steel has to be increased ( stouter springs installed) in high rpm racing applications because the valves can't close fast enough for the compression stroke. Near 8500 rpm with standard springs and 10000+ with high performance. So with the compressed installed length - maximum compressed installed length rpm factored and graphed and float being the indication fail @ maximum speed you could set up a mechanical experiment to check the "speed of a spring". Heat is an issue here too.
Yes, That was first thing I did, and they came out slow, I excused it to being it has to push that heavy valve. Did all the math (lift and duration) and it came out about 40 fps. After that came here. Then did spring empirical speed test several ways, springs are just slow.
Thanks.
  • #39
x=A*sin(ωt)
and velocity is:
v=A*cos(ωt)
  • wire diameter
  • number of coils
Thanks, I am already on work another direction, so no longer needed, but appreciate it.
  • #40
I just want to chime in here because I'm genuinely interested in release characteristics of coil springs. I didn't read a lot of what was typed here as I'm pretty lazy, but one thing that i didn't see mentioned was the damping of the spring material itself. Simple fact of the matter is that to correctly model what is happening at the speeds a spring releases, you MUST model the damping of the material itself into the equations. Different types of steel will damp itself differently upon expansion. The company Swift prides itself on a special kind of steel that is stiffer than a typical coil spring, allowing them to get away with less coils for a given rate. Swift also touts a much more "responsive" spring I'm assuming due to its lower mass. The material itself could also have a lower damping rate in comparison, but I'm not sure this difference can be measured easily.
For a car application, i emplore you to google "shock dyno". A shock dyno essentially moves a shock through various velocities and measures the damping force in rebound and compression. In real aplications, the rebound speed of a spring will be damped by the shock absorber as well, so overall response will be damped even further. Shock dyno's start at 0 in/sec and go all the way to 8-14 in/sec. Most people stop at 8, but motorsports and OEM applications look at speeds double that rate as high end shock absorbers will have blow off mechanisms to dramatically decrease damping force at extremely high velocities. This is where spring response is important, and where a spring like swift would shine.
Overall, i don't think we're taking the right approach to modeling this situation. I feel it will be more of a spring/mass equation with a damper and spring acting in parallel, with both the spring and damper having a separate force and damping component for both (dampers are usually pressurized, which would provide a variable spring force).
  • General Engineering
22K
11K
  • Science Fiction and Fantasy Media
12K
